Hey all,
I'm running Premiere Pro v. 6.0.2 on Mountain Lion 10.8.2, with a standard ATI Radeon 5770 in a 3.33 GHz 6-Core Mac Pro 5,1.
Whenever I try to open the program OR a file, I get the following message:
"Premiere Pro has encountered an error.
[/Volumes/BuildDisk/builds/slightlybuilt/shared/adobe/MediaCore/ASL/Fo undation/Make/Mac/../../Src/DirectoryRegistry.cpp-283]"
The strangest thing is that I just used Premiere yesterday, and after quitting it last night, tried to open the same file and got this message. I thought maybe the file was corrupted but I get the message just by launching without even opening via a project file. I then updated from 10.8.1 to 10.8.2 in the hopes that something internally might get fixed and it did not rememdy the problem. I have been scouring forums and most have pointed to resetting the permissions in the Home folder which I did both through Terminal and the "resetpassword" Repair Utility method. It still won't open! This has been very frustrating and I would greatly appreciate any advice to get this sorted out.
As a side note, whenever I open After Effects (11.0.1), it "unexpectedly quits" without an error log. I was also able to open this at least since I've had Mountain Lion, although I did not use it as recently as Premiere.
I appreciate any help and please let me know if you need any more information. Thank you!
I'm not a Mac user so I can't offer much advice other than to recommend uninstalling everything and using the adobe cleaner utility after the uninstall is completed. Then re-install everything, hopefully that should fix the problem. Sorry I don't have any info on what actually caused the issue though.
But I'm going to assume that something has obviously gotten corrupted somehow. I honestly think that uinstalling is probably going to be the easiest solution here.
Here is a link to the cleaner utlity.
On a Mac, the Home folder (named after your username) is the root of everything that installed applications use to generate and save different important system files to help them run properly. I had tried to move the Documents folder to an external hard drive so some of Adobe's media cache wouldn't eat up space on my startup drive, but in doing so I accidentally lost the original documents folder instead of simply copying it. All I had to do in the end was go back into the home directory and make a new folder exactly titled "Documents" and when I reopened premiere, it was able to create the necessary files again and everything has worked perfectly since!
There is a similar process on the Windows side http://forums.adobe.com/thread/1007934?tstart=0
