How do I install Adobe Flash Player on Ubuntu 32bit ARMv7 Little Endian machine?
Sep 16, 2012 10:19 AM
Tags: #flash #ubuntu #arm #armle
How do I install Adobe Flash Player on Ubuntu (12.04) 32bit ARMv7 Little Endian machine? The .tar.gz and .deb files contains shared libraries for i386 target.
    Sep 16, 2012 11:52 PM   in reply to AananthCN
    [topic moved to Flash Player forum]
    Sep 17, 2012 3:46 AM   in reply to AananthCN
    Hello,
    Welcome to Adobe Forums.
    You can follow these steps :
    1) Login with "root" user on your Ubuntu 12.04
    2) Launch "Terminal" (Keyboard Shortcut : Ctrl +Alt +T)
    3) Type this command and hit Enter : sudo apt-get install flashplugin-installer
    4) Launch Firefox and check do you have Flash Player (http://www.adobe.com/software/flash/about/)
    Vikram
    Sep 24, 2012 3:02 AM   in reply to AananthCN
    Hello,
    There is a procedure of Manual Installation of Adobe Flash Player on Ubuntu, follow these steps :
    1. Open http://get.adobe.com/flashplayer/otherversions/
    2. Choose Linux 32-bit on Step 1
    3. Choose Flash Player 11.2 (tar.gz) on Step 2, download the file
    4. Once download is complete, right click on the flie (tar.gz) and click on "Extract here"
    5. Launch Terminal (Keyboard Shortcut : Ctrl+Alt+T)
    6. Go to that location where you extracted the file
    7. Run this command : sudo mv libflashplayer.so \/usr/lib/firefox-addons/plugins
    8. Launch Mozilla Firefox and check do you have Adobe Flash Player
    Vikram
    Feb 4, 2013 4:46 PM   in reply to AananthCN
    A few days ago I actually had Flash under Firefox and Kubuntu 12.10 working correctly, but some update or other seems to have killed it -- in two stages.   First, I wasn't able to play Flash pages on the Flash Media server -- I kept getting the "not available" error.   In my attempts to correct that I instead made things worse; now I can't view any Flash pages at all.
    I've done the obvious things.  I've installed, uninstalled, and reinstalled flashplugin-installer.  I've downloaded both the 32-bit and 64-bit versions of that package and tried to install the software from the downloaded packages instead of from the repositories.  I've copied libflashplayer.so to /usr/lib/firefox-addons/plugins.  Nothing seems to help.
    I'm running out of ideas.
    Feb 6, 2013 1:12 PM   in reply to P W Abrahams
    desktop arm7 is an unsupported platform for flash player.  the desktop flash player will not work as i am told it utilizes intel instructions and the mobile version is tightly integrated with the android OS most functionality would not work under Linux Ubuntu.
