changing shapes by dragging on them?
Sep 24, 2012 8:12 AM
What key is used in conjunction with these shapes to be able to change their shape? I remember using an older version of FW and I took a shape and was able to drag on something to change it from a rectangle into a tab.
    Sep 24, 2012 6:43 PM   in reply to media kat
    Have you trried the Auto Shape Properties panel?
    Sep 24, 2012 9:20 PM   in reply to media kat
    I think experimentation is essential—but the tool tips that appear when hovering over the yellow points will generally give you the information needed.
    In the Pie Chart example, dragging on the points adjusts the position of the segments, while Alt/Opt-dragging will allow you to add new segments. The former isn't explicitly stated, but the latter is, presumably because Alt-Opt-dragging is not assumed. Personally, I'd just click-and-drag on a yellow point, unless it specifically says otherwise. (The developers of these Auto Shapes want them to be usable; so they'll let you know if you need to do something special via tooltips.)
