Hi. I have created a form in Dreamweaver CS5 that uses spry validation successfully. Once the form is submitted, the user is redirected to the home page. But I don't want that redirect.
My question is, how can I have the validated page redirect to a custom thank you page I designed? I don't know the exact code/syntax to write to make it do what I want and, even if I had the code, I wouldn't know exactly where it should be placed. Please help if you can. Here's the source code. )BTW, when I use Dreamweaver Behaviors to add a URL redirect, it ignores the required validation and simply allows you to click the submit button and redirect.) Many thanks!
<!DOCTYPE HTML>
<html>
<head>
<meta charset="UTF-8">
<link href="../_css/main.css" rel="stylesheet" media="screen, projection">
<link href="../_css/forms.css" rel="stylesheet" media="screen, projection">
<title></title>
<!--[if lt IE 9]>
<script src="http://ie7-js.googlecode.com/svn/version/2.1(beta4)/IE9.js"></script><![endif]-->
<script src="../SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<link href="../SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css">
<script type="text/javascript">
<!-- **** I think the line of code for the redirect is here??...I just don't know how to write the code to redirect to the page I want ***** -->
function MM_goToURL() { //v3.0
var i, args=MM_goToURL.arguments; document.MM_returnValue = false;
for (i=0; i<(args.length-1); i+=2) eval(args[i]+".location='"+args[i+1]+"'");
</script>
</head>
<body>
<header id="pageHeader">
<a href="../index.htm"><img src="../_images/logo.gif" width="170" height="91" alt="HMN logo" id="logo"></a>
<img src="../_images/tagline.png" width="296" height="92" alt="HMN tagline" id="tagline">
</header>
<nav id="mainNav">
<ul>
<li><a href="../index.htm">Home</a></li>
<li><a href="../press.htm">Press</a></li>
<li><a href="../about.htm">About</a></li>
<li><a href="../contact.htm">Contact</a></li>
</ul>
</nav>
<br class="clear">
<div class="headerContact">
</div>
<article>
<!-- The file webformmailer.php sits on the web server at godaddy.com in case that matters -->
<section id="Request">
<p id="intro">To request your link for the downloadable <span id="highlight">Media Kit</span>, please provide the following information:</p>
<form name="Request" method="post" action="../../webformmailer.php"> <p id="formCaption">Fields marked with * are required.</p>
<p><span id="sprytextfield1">
<label for="first_name">First Name:*</label>
<input type="text" name="first_name" id="first_name">
<span class="textfieldRequiredMsg">(required)</span></span></p>
<p><span id="sprytextfield2">
<label for="last_name">Last Name:*</label>
<input type="text" name="last_name" id="last_name">
<p><span id="sprytextfield3">
<label for="company">Company:*</label>
<input type="text" name="company" id="company">
<p>
<label for="address">Address:</label>
<input type="text" name="address" id="address">
</p>
<p>
<label for="address_2">Address 2:</label>
<input type="text" name="address_2" id="address_2">
</p>
<p>
<label for="city">City:</label>
<input type="text" name="city" id="city">
</p>
<p>
<label for="state">State:</label>
<input type="text" name="state" id="state">
</p>
<p>
<label for="zip">Zip:</label>
<input type="text" name="zip" id="zip">
</p>
<p><span id="sprytextfield4">
<label for="email">Email:*</label>
<input type="text" name="email" id="email">
<span class="textfieldRequiredMsg">(required)</span><span class="textfieldInvalidFormatMsg">Invalid format.</span></span> </p>
<p>
<input name="submit" type="image" id="submit" onClick="MM_goToURL('parent','media_kit_download.htm');return document.MM_returnValue" src="../_images/btn_submit.png">
</p>
<p> </p>
</form>
<p>
</p>
</div>
</div>
</section>
</article>
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "none", {validateOn:["blur"]});
var sprytextfield2 = new Spry.Widget.ValidationTextField("sprytextfield2", "none", {validateOn:["blur"]});
var sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3", "none", {validateOn:["blur"]});
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4", "email", {validateOn:["blur"]});
</script>
</body>
</html>
What you have quoted is a function MM_goToURL that is being called on submission.
In your form below, you'll see where MM_goToURL takes the user on submission. I've highlighted this URL.
I'm assuming this is the page the contact form is on by itself. Change the bold URL above to whatever custom page you want the user to see when they submit the form.
Thanks for replying. The URL you've bolded is actually the correct page I'd like the redirect to go to when the form is successfully submitted after validation. But for some reason, that URL request is being ignored and the redirect brings me back to the index page in the root directory. I don't see anywhere in the code that makes the request to do that. Unless that's a default behavior if I've gotten the redirect wrong?
I don't know if this is helpful, but there is also a .js file that Dreamweaver created and attached to the above HTML source file. The .js file appears to have all the spry code validation including code for features and widgets I'm not even using. I searched through the code several times trying to identify where there might be a redirect to the index page but didn't recognize anything that made sense to me. Here is the complete, unedited file:
// SpryValidationTextField.js - version 0.38 - Spry Pre-Release 1.6.1
// Copyright (c) 2006. Adobe Systems Incorporated.
// All rights reserved.
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions are met:
// * Redistributions of source code must retain the above copyright notice,
// this list of conditions and the following disclaimer.
// * Redistributions in binary form must reproduce the above copyright notice,
// this list of conditions and the following disclaimer in the documentation
// and/or other materials provided with the distribution.
// * Neither the name of Adobe Systems Incorporated nor the names of its
// contributors may be used to endorse or promote products derived from this
// software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
// AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
// IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
// ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
// LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
// CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
// SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
// INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
// CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
// ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
// POSSIBILITY OF SUCH DAMAGE.
(function() { // BeginSpryComponent
if (typeof Spry == "undefined") window.Spry = {}; if (!Spry.Widget) Spry.Widget = {};
Spry.Widget.BrowserSniff = function()
var b = navigator.appName.toString();
var up = navigator.platform.toString();
var ua = navigator.userAgent.toString();
this.mozilla = this.ie = this.opera = this.safari = false;
var re_opera = /Opera.([0-9\.]*)/i;
var re_msie = /MSIE.([0-9\.]*)/i;
var re_gecko = /gecko/i;
var re_safari = /(applewebkit|safari)\/([\d\.]*)/i;
var r = false;
if ( (r = ua.match(re_opera))) {
this.opera = true;
this.version = parseFloat(r[1]);
} else if ( (r = ua.match(re_msie))) {
this.ie = true;
} else if ( (r = ua.match(re_safari))) {
this.safari = true;
this.version = parseFloat(r[2]);
} else if (ua.match(re_gecko)) {
var re_gecko_version = /rv:\s*([0-9\.]+)/i;
r = ua.match(re_gecko_version);
this.mozilla = true;
this.windows = this.mac = this.linux = false;
this.Platform = ua.match(/windows/i) ? "windows" :
(ua.match(/linux/i) ? "linux" :
(ua.match(/mac/i) ? "mac" :
ua.match(/unix/i)? "unix" : "unknown"));
this[this.Platform] = true;
this.v = this.version;
if (this.safari && this.mac && this.mozilla) {
this.mozilla = false;
Spry.is = new Spry.Widget.BrowserSniff();
Spry.Widget.ValidationTextField = function(element, type, options)
type = Spry.Widget.Utils.firstValid(type, "none");
if (typeof type != 'string') {
this.showError('The second parameter in the constructor should be the validation type, the options are the third parameter.');
return;
if (typeof Spry.Widget.ValidationTextField.ValidationDescriptors[type] == 'undefined') {
this.showError('Unknown validation type received as the second parameter.');
return;
options = Spry.Widget.Utils.firstValid(options, {});
this.type = type;
if (!this.isBrowserSupported()) {
//disable character masking and pattern behaviors for low level browsers
options.useCharacterMasking = false;
this.init(element, options);
//make sure we validate at least on submit
var validateOn = ['submit'].concat(Spry.Widget.Utils.firstValid(this.options.validateO n, []));
validateOn = validateOn.join(",");
this.validateOn = 0;
this.validateOn = this.validateOn | (validateOn.indexOf('submit') != -1 ? Spry.Widget.ValidationTextField.ONSUBMIT : 0);
this.validateOn = this.validateOn | (validateOn.indexOf('blur') != -1 ? Spry.Widget.ValidationTextField.ONBLUR : 0);
this.validateOn = this.validateOn | (validateOn.indexOf('change') != -1 ? Spry.Widget.ValidationTextField.ONCHANGE : 0);
if (Spry.Widget.ValidationTextField.onloadDidFire)
this.attachBehaviors();
else
Spry.Widget.ValidationTextField.loadQueue.push(this);
Spry.Widget.ValidationTextField.ONCHANGE = 1;
Spry.Widget.ValidationTextField.ONBLUR = 2;
Spry.Widget.ValidationTextField.ONSUBMIT = 4;
Spry.Widget.ValidationTextField.ERROR_REQUIRED = 1;
Spry.Widget.ValidationTextField.ERROR_FORMAT = 2;
Spry.Widget.ValidationTextField.ERROR_RANGE_MIN = 4;
Spry.Widget.ValidationTextField.ERROR_RANGE_MAX = 8;
Spry.Widget.ValidationTextField.ERROR_CHARS_MIN = 16;
Spry.Widget.ValidationTextField.ERROR_CHARS_MAX = 32;
/* validation parameters:
* - characterMasking : prevent typing of characters not matching an regular expression
* - regExpFilter : additional regular expression to disalow typing of characters
* (like the "-" sign in the middle of the value); use for partial matching of the currently typed value;
* the typed value must match regExpFilter at any moment
* - pattern : enforce character on each position inside a pattern (AX0?)
* - validation : function performing logic validation; return false if failed and the typedValue value on success
* - minValue, maxValue : range validation; check if typedValue inside the specified range
* - minChars, maxChars : value length validation; at least/at most number of characters
Spry.Widget.ValidationTextField.ValidationDescriptors = {
'none': {
'custom': {
'integer': {
characterMasking: /[\-\+\d]/,
regExpFilter: /^[\-\+]?\d*$/,
validation: function(value, options) {
if (value == '' || value == '-' || value == '+') {
return false;
var regExp = /^[\-\+]?\d*$/;
if (!regExp.test(value)) {
return false;
options = options || {allowNegative:false};
var ret = parseInt(value, 10);
if (!isNaN(ret)) {
var allowNegative = true;
if (typeof options.allowNegative != 'undefined' && options.allowNegative == false) {
allowNegative = false;
if (!allowNegative && value < 0) {
ret = false;
} else {
ret = false;
return ret;
'real': {
characterMasking: /[\d\.,\-\+e]/i,
regExpFilter: /^[\-\+]?\d(?:|\.,\d{0,2})|(?:|e{0,1}[\-\+]?\d{0,})$/i,
validation: function (value, options) {
var regExp = /^[\+\-]?[0-9]+([\.,][0-9]+)?([eE]{0,1}[\-\+]?[0-9]+)?$/;
return false;
var ret = parseFloat(value);
if (isNaN(ret)) {
ret = false;
return ret;
'currency': {
formats: {
'dot_comma': {
characterMasking: /[\d\.\,\-\+\$]/,
regExpFilter: /^[\-\+]?(?:[\d\.]*)+(|\,\d{0,2})$/,
var ret = false;
//2 or no digits after the comma
if (/^(\-|\+)?\d{1,3}(?:\.\d{3})*(?:\,\d{2}|)$/.test(value) || /^(\-|\+)?\d+(?:\,\d{2}|)$/.test(value)) {
value = value.toString().replace(/\./gi, '').replace(/\,/, '.');
return ret;
'comma_dot': {
regExpFilter: /^[\-\+]?(?:[\d\,]*)+(|\.\d{0,2})$/,
var ret = false;
if (/^(\-|\+)?\d{1,3}(?:\,\d{3})*(?:\.\d{2}|)$/.test(value) || /^(\-|\+)?\d+(?:\.\d{2}|)$/.test(value)) {
value = value.toString().replace(/\,/gi, '');
return ret;
'email': {
characterMasking: /[^\s]/,
var rx = /^[\w\.-]+@[\w\.-]+\.\w+$/i;
return rx.test(value);
'date': {
var formatRegExp = /^([mdy]+)[\.\-\/\\\s]+([mdy]+)[\.\-\/\\\s]+([mdy]+)$/i;
var valueRegExp = this.dateValidationPattern;
var formatGroups = options.format.match(formatRegExp);
var valueGroups = value.match(valueRegExp);
if (formatGroups !== null && valueGroups !== null) {
var dayIndex = -1;
var monthIndex = -1;
var yearIndex = -1;
for (var i=1; i<formatGroups.length; i++) {
switch (formatGroups[i].toLowerCase()) {
case "dd":
dayIndex = i;
break;
case "mm":
monthIndex = i;
break;
case "yy":
case "yyyy":
yearIndex = i;
break;
if (dayIndex != -1 && monthIndex != -1 && yearIndex != -1) {
var maxDay = -1;
var theDay = parseInt(valueGroups[dayIndex], 10);
var theMonth = parseInt(valueGroups[monthIndex], 10);
var theYear = parseInt(valueGroups[yearIndex], 10);
// Check month value to be between 1..12
if (theMonth < 1 || theMonth > 12) {
return false;
// Calculate the maxDay according to the current month
switch (theMonth) {
case 1: // January
case 3: // March
case 5: // May
case 7: // July
case 8: // August
case 10: // October
case 12: // December
maxDay = 31;
break;
case 4: // April
case 6: // June
case 9: // September
case 11: // November
maxDay = 30;
break;
case 2: // February
if ((parseInt(theYear/4, 10) * 4 == theYear) && (theYear % 100 != 0 || theYear % 400 == 0)) {
maxDay = 29;
} else {
maxDay = 28;
break;
// Check day value to be between 1..maxDay
if (theDay < 1 || theDay > maxDay) {
return false;
// If successfull we'll return the date object
return (new Date(theYear, theMonth - 1, theDay)); //JavaScript requires a month between 0 and 11
} else {
return false;
'time': {
// HH:MM:SS T
var formatRegExp = /([hmst]+)/gi;
var valueRegExp = /(\d+|AM?|PM?)/gi;
//mast match and have same length
if (formatGroups.length != valueGroups.length) {
return false;
var hourIndex = -1;
var minuteIndex = -1;
var secondIndex = -1;
//T is AM or PM
var tIndex = -1;
var theHour = 0, theMinute = 0, theSecond = 0, theT = 'AM';
for (var i=0; i<formatGroups.length; i++) {
case "hh":
hourIndex = i;
break;
case "mm":
minuteIndex = i;
break;
case "ss":
secondIndex = i;
break;
case "t":
case "tt":
tIndex = i;
break;
if (hourIndex != -1) {
var theHour = parseInt(valueGroups[hourIndex], 10);
if (isNaN(theHour) || theHour > (formatGroups[hourIndex] == 'HH' ? 23 : 12 )) {
return false;
if (minuteIndex != -1) {
var theMinute = parseInt(valueGroups[minuteIndex], 10);
if (isNaN(theMinute) || theMinute > 59) {
return false;
if (secondIndex != -1) {
var theSecond = parseInt(valueGroups[secondIndex], 10);
if (isNaN(theSecond) || theSecond > 59) {
return false;
if (tIndex != -1) {
var theT = valueGroups[tIndex].toUpperCase();
if (
formatGroups[tIndex].toUpperCase() == 'TT' && !/^a|pm$/i.test(theT) ||
formatGroups[tIndex].toUpperCase() == 'T' && !/^a|p$/i.test(theT)
return false;
var date = new Date(2000, 0, 1, theHour + (theT.charAt(0) == 'P'?12:0), theMinute, theSecond);
return date;
} else {
return false;
'credit_card': {
characterMasking: /\d/,
var regExp = null;
options.format = options.format || 'ALL';
switch (options.format.toUpperCase()) {
case 'ALL': regExp = /^[3-6]{1}[0-9]{12,18}$/; break;
case 'VISA': regExp = /^4(?:[0-9]{12}|[0-9]{15})$/; break;
case 'MASTERCARD': regExp = /^5[1-5]{1}[0-9]{14}$/; break;
case 'AMEX': regExp = /^3(4|7){1}[0-9]{13}$/; break;
case 'DISCOVER': regExp = /^6011[0-9]{12}$/; break;
case 'DINERSCLUB': regExp = /^3(?:(0[0-5]{1}[0-9]{11})|(6[0-9]{12})|(8[0-9]{12}))$/; break;
return false;
var digits = [];
var j = 1, digit = '';
for (var i = value.length - 1; i >= 0; i--) {
if ((j%2) == 0) {
digit = parseInt(value.charAt(i), 10) * 2;
digits[digits.length] = digit.toString().charAt(0);
if (digit.toString().length == 2) {
digits[digits.length] = digit.toString().charAt(1);
} else {
digit = value.charAt(i);
digits[digits.length] = digit;
j++;
var sum = 0;
for(i=0; i < digits.length; i++ ) {
sum += parseInt(digits[i], 10);
if ((sum%10) == 0) {
return true;
return false;
'zip_code': {
formats: {
'zip_us9': {
pattern:'00000-0000'
'zip_us5': {
pattern:'00000'
'zip_uk': {
characterMasking: /[\dA-Z\s]/,
//check one of the following masks
// AN NAA, ANA NAA, ANN NAA, AAN NAA, AANA NAA, AANN NAA
return /^[A-Z]{1,2}\d[\dA-Z]?\s?\d[A-Z]{2}$/.test(value);
'zip_canada': {
pattern: 'A0A 0A0'
'zip_custom': {}
'phone_number': {
formats: {
//US phone number; 10 digits
'phone_us': {
pattern:'(000) 000-0000'
'phone_custom': {}
'social_security_number': {
pattern:'000-00-0000'
'ip': {
characterMaskingFormats: {
'ipv4': /[\d\.]/i,
'ipv6_ipv4': /[\d\.\:A-F\/]/i,
'ipv6': /[\d\.\:A-F\/]/i
return Spry.Widget.ValidationTextField.validateIP(value, options.format);
'url': {
//fix for ?ID=223429 and ?ID=223387
/* the following regexp matches components of an URI as specified in http://tools.ietf.org/html/rfc3986#page-51 page 51, Appendix B.
scheme = $2
authority = $4
path = $5
query = $7
fragment = $9
var URI_spliter = /^(([^:\/?#]+):)?(\/\/([^\/?#]*))?([^?#]*)(\?([^#]*))?(#(.*))?/;
var parts = value.match(URI_spliter);
if (parts && parts[4]) {
//encode each component of the domain name using Punycode encoding scheme: http://tools.ietf.org/html/rfc3492
var host = parts[4].split(".");
var punyencoded = '';
for (var i=0; i<host.length; i++) {
punyencoded = Spry.Widget.Utils.punycode_encode(host[i], 64);
if (!punyencoded) {
return false;
} else {
if (punyencoded != (host[i] + "-")) {
host[i] = 'xn--' + punyencoded;
host = host .join(".");
//the encoded domain name is replaced into the original URL to be validated again later as URL
value = value.replace(URI_spliter, "$1//" + host + "$5$6$8");
//fix for ?ID=223358 and ?ID=223594
//the following validates an URL using ABNF rules as defined in http://tools.ietf.org/html/rfc3986 , Appendix A., page 49
//except host which is extracted by match[1] and validated separately
* userinfo= (?:(?:[a-z0-9\-\._~\!\$\&\'\(\)\*\+\,\;\=:]|%[0-9a-f]{2,2})*\@)?
* host= (?:((?:(?:[a-z0-9][a-z0-9\-]*[a-z0-9]|[a-z0-9])\.)*(?:[a-z][a-z0-9\-] *[a-z0-9]|[a-z])|(?:\[[^\]]*\]))
* pathname= (?:\/(?:[a-z0-9\-\._~\!\$\&\'\(\)\*\+\,\;\=\:\@]|%[0-9a-f]{2,2})*)*
* query= (?:\?(?:[a-z0-9\-\._~\!\$\&\'\(\)\*\+\,\;\=\:\@\/\?]|%[0-9a-f]{2,2})* )?
* anchor= (?:\#(?:[a-z0-9\-\._~\!\$\&\'\(\)\*\+\,\;\=\:\@\/\?]|%[0-9a-f]{2,2})* )?
var regExp = /^(?:https?|ftp)\:\/\/(?:(?:[a-z0-9\-\._~\!\$\&\'\(\)\*\+\,\;\=:]|%[0 -9a-f]{2,2})*\@)?(?:((?:(?:[a-z0-9][a-z0-9\-]*[a-z0-9]|[a-z0-9])\.)*(? :[a-z][a-z0-9\-]*[a-z0-9]|[a-z])|(?:\[[^\]]*\]))(?:\:[0-9]*)?)(?:\/(?: [a-z0-9\-\._~\!\$\&\'\(\)\*\+\,\;\=\:\@]|%[0-9a-f]{2,2})*)*(?:\?(?:[a- z0-9\-\._~\!\$\&\'\(\)\*\+\,\;\=\:\@\/\?]|%[0-9a-f]{2,2})*)?(?:\#(?:[a -z0-9\-\._~\!\$\&\'\(\)\*\+\,\;\=\:\@\/\?]|%[0-9a-f]{2,2})*)?$/i;
var valid = value.match(regExp);
if (valid) {
//extract the address from URL
var address = valid[1];
if (address) {
if (address == '[]') {
return false;
if (address.charAt(0) == '[' ) {
//IPv6 address or IPv4 enclosed in square brackets
address = address.replace(/^\[|\]$/gi, '');
return Spry.Widget.ValidationTextField.validateIP(address, 'ipv6_ipv4');
} else {
if (/[^0-9\.]/.test(address)) {
return true;
} else {
//check if hostname is all digits and dots and then check for IPv4
return Spry.Widget.ValidationTextField.validateIP(address, 'ipv4');
} else {
return true;
} else {
return false;
2.2.1. Preferred
x:x:x:x:x:x:x:x, where the 'x's are the hexadecimal values of the eight 16-bit pieces of the address.
Examples:
FEDC:BA98:7654:3210:FEDC:BA98:7654:3210
1080:0:0:0:8:800:200C:417A
Note that it is not necessary to write the leading zeros in an
individual field, but there must be at least one numeral in every
field (except for the case described in 2.2.2.).
2.2.2. Compressed
The use of "::" indicates multiple groups of 16-bits of zeros.
The "::" can only appear once in an address. The "::" can also be
used to compress the leading and/or trailing zeros in an address.
1080:0:0:0:8:800:200C:417A --> 1080::8:800:200C:417A
FF01:0:0:0:0:0:0:101 --> FF01::101
0:0:0:0:0:0:0:1 --> ::1
0:0:0:0:0:0:0:0 --> ::
2.5.4 IPv6 Addresses with Embedded IPv4 Addresses
IPv4-compatible IPv6 address (tunnel IPv6 packets over IPv4 routing infrastructures)
::0:129.144.52.38
IPv4-mapped IPv6 address (represent the addresses of IPv4-only nodes as IPv6 addresses)
::ffff:129.144.52.38
The text representation of IPv6 addresses and prefixes in Augmented BNF (Backus-Naur Form) [ABNF] for reference purposes.
[ABNF http://tools.ietf.org/html/rfc2234]
IPv6address = hexpart [ ":" IPv4address ]
IPv4address = 1*3DIGIT "." 1*3DIGIT "." 1*3DIGIT "." 1*3DIGIT
IPv6prefix = hexpart "/" 1*2DIGIT
hexpart = hexseq | hexseq "::" [ hexseq ] | "::" [ hexseq ]
hexseq = hex4 *( ":" hex4)
hex4 = 1*4HEXDIG
Spry.Widget.ValidationTextField.validateIP = function (value, format)
var validIPv6Addresses = [
//preferred
/^(?:[a-f0-9]{1,4}:){7}[a-f0-9]{1,4}(?:\/\d{1,3})?$/i,
//various compressed
/^[a-f0-9]{0,4}::(?:\/\d{1,3})?$/i,
/^:(?::[a-f0-9]{1,4}){1,6}(?:\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:){1,6}:(?:\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:)(?::[a-f0-9]{1,4}){1,6}(?:\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:){2}(?::[a-f0-9]{1,4}){1,5}(?:\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:){3}(?::[a-f0-9]{1,4}){1,4}(?:\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:){4}(?::[a-f0-9]{1,4}){1,3}(?:\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:){5}(?::[a-f0-9]{1,4}){1,2}(?:\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:){6}(?::[a-f0-9]{1,4})(?:\/\d{1,3})?$/i,
//IPv6 mixes with IPv4
/^(?:[a-f0-9]{1,4}:){6}(?:\d{1,3}\.){3}\d{1,3}(?:\/\d{1,3})?$/i,
/^:(?::[a-f0-9]{1,4}){0,4}:(?:\d{1,3}\.){3}\d{1,3}(?:\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:){1,5}:(?:\d{1,3}\.){3}\d{1,3}(?:\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:)(?::[a-f0-9]{1,4}){1,4}:(?:\d{1,3}\.){3}\d{1,3}(? :\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:){2}(?::[a-f0-9]{1,4}){1,3}:(?:\d{1,3}\.){3}\d{1,3 }(?:\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:){3}(?::[a-f0-9]{1,4}){1,2}:(?:\d{1,3}\.){3}\d{1,3 }(?:\/\d{1,3})?$/i,
/^(?:[a-f0-9]{1,4}:){4}(?::[a-f0-9]{1,4}):(?:\d{1,3}\.){3}\d{1,3}(?:\ /\d{1,3})?$/i
var validIPv4Addresses = [
//IPv4
/^(\d{1,3}\.){3}\d{1,3}$/i
var validAddresses = [];
if (format == 'ipv6' || format == 'ipv6_ipv4') {
validAddresses = validAddresses.concat(validIPv6Addresses);
if (format == 'ipv4' || format == 'ipv6_ipv4') {
validAddresses = validAddresses.concat(validIPv4Addresses);
var ret = false;
for (var i=0; i<validAddresses.length; i++) {
if (validAddresses[i].test(value)) {
ret = true;
break;
if (ret && value.indexOf(".") != -1) {
//if address contains IPv4 fragment, it must be valid; all 4 groups must be less than 256
var ipv4 = value.match(/:?(?:\d{1,3}\.){3}\d{1,3}/i);
if(!ipv4) {
return false;
ipv4 = ipv4[0].replace(/^:/, '');
var pieces = ipv4.split('.');
if (pieces.length != 4) {
return false;
for (var i=0; i< pieces.length; i++) {
if (pieces[i] == '') {
return false;
var piece = parseInt(pieces[i], 10);
if (isNaN(piece) || piece > 255 || !regExp.test(pieces[i]) || pieces[i].length>3 || /^0{2,3}$/.test(pieces[i])) {
return false;
if (ret && value.indexOf("/") != -1) {
// if prefix-length is specified must be in [1-128]
var prefLen = value.match(/\/\d{1,3}$/);
if (!prefLen) return false;
var prefLenVal = parseInt(prefLen[0].replace(/^\//,''), 10);
if (isNaN(prefLenVal) || prefLenVal > 128 || prefLenVal < 1) {
return false;
return ret;
Spry.Widget.ValidationTextField.onloadDidFire = false;
Spry.Widget.ValidationTextField.loadQueue = [];
Spry.Widget.ValidationTextField.prototype.isBrowserSupported = function()
return Spry.is.ie && Spry.is.v >= 5 && Spry.is.windows
Spry.is.mozilla && Spry.is.v >= 1.4
Spry.is.safari
Spry.is.opera && Spry.is.v >= 9;
Spry.Widget.ValidationTextField.prototype.init = function(element, options)
this.element = this.getElement(element);
this.errors = 0;
this.flags = {locked: false, restoreSelection: true};
this.options = {};
this.event_handlers = [];
this.validClass = "textfieldValidState";
this.focusClass = "textfieldFocusState";
this.requiredClass = "textfieldRequiredState";
this.hintClass = "textfieldHintState";
this.invalidFormatClass = "textfieldInvalidFormatState";
this.invalidRangeMinClass = "textfieldMinValueState";
this.invalidRangeMaxClass = "textfieldMaxValueState";
this.invalidCharsMinClass = "textfieldMinCharsState";
this.invalidCharsMaxClass = "textfieldMaxCharsState";
this.textfieldFlashTextClass = "textfieldFlashText";
if (Spry.is.safari) {
this.flags.lastKeyPressedTimeStamp = 0;
switch (this.type) {
case 'phone_number':options.format = Spry.Widget.Utils.firstValid(options.format, 'phone_us');break;
case 'currency':options.format = Spry.Widget.Utils.firstValid(options.format, 'comma_dot');break;
case 'zip_code':options.format = Spry.Widget.Utils.firstValid(options.format, 'zip_us5');break;
case 'date':
options.format = Spry.Widget.Utils.firstValid(options.format, 'mm/dd/yy');
break;
case 'time':
options.format = Spry.Widget.Utils.firstValid(options.format, 'HH:mm');
options.pattern = options.format.replace(/[hms]/gi, "0").replace(/TT/gi, 'AM').replace(/T/gi, 'A');
break;
case 'ip':
options.format = Spry.Widget.Utils.firstValid(options.format, 'ipv4');
options.characterMasking = Spry.Widget.ValidationTextField.ValidationDescriptors[this.type].char acterMaskingFormats[options.format];
break;
//retrieve the validation type descriptor to be used with this instance (base on type and format)
//widgets may have different validations depending on format (like zip_code with formats)
var validationDescriptor = {};
if (options.format && Spry.Widget.ValidationTextField.ValidationDescriptors[this.type].form ats) {
if (Spry.Widget.ValidationTextField.ValidationDescriptors[this.type].for mats[options.format]) {
Spry.Widget.Utils.setOptions(validationDescriptor, Spry.Widget.ValidationTextField.ValidationDescriptors[this.type].form ats[options.format]);
} else {
Spry.Widget.Utils.setOptions(validationDescriptor, Spry.Widget.ValidationTextField.ValidationDescriptors[this.type]);
//set default values for some parameters which were not aspecified
options.useCharacterMasking = Spry.Widget.Utils.firstValid(options.useCharacterMasking, false);
options.hint = Spry.Widget.Utils.firstValid(options.hint, '');
options.isRequired = Spry.Widget.Utils.firstValid(options.isRequired, true);
options.additionalError = Spry.Widget.Utils.firstValid(options.additionalError, false);
if (options.additionalError)
options.additionalError = this.getElement(options.additionalError);
//set widget validation parameters
//get values from validation type descriptor
//use the user specified values, if defined
options.characterMasking = Spry.Widget.Utils.firstValid(options.characterMasking, validationDescriptor.characterMasking);
options.regExpFilter = Spry.Widget.Utils.firstValid(options.regExpFilter, validationDescriptor.regExpFilter);
options.pattern = Spry.Widget.Utils.firstValid(options.pattern, validationDescriptor.pattern);
options.validation = Spry.Widget.Utils.firstValid(options.validation, validationDescriptor.validation);
if (typeof options.validation == 'string') {
options.validation = eval(options.validation);
options.minValue = Spry.Widget.Utils.firstValid(options.minValue, validationDescriptor.minValue);
options.maxValue = Spry.Widget.Utils.firstValid(options.maxValue, validationDescriptor.maxValue);
options.minChars = Spry.Widget.Utils.firstValid(options.minChars, validationDescriptor.minChars);
options.maxChars = Spry.Widget.Utils.firstValid(options.maxChars, validationDescriptor.maxChars);
Spry.Widget.Utils.setOptions(this, options);
Spry.Widget.Utils.setOptions(this.options, options);
Spry.Widget.ValidationTextField.prototype.destroy = function() {
if (this.event_handlers)
for (var i=0; i<this.event_handlers.length; i++) {
Spry.Widget.Utils.removeEventListener(this.event_handlers[i][0], this.event_handlers[i][1], this.event_handlers[i][2], false);
try { delete this.element; } catch(err) {}
try { delete this.input; } catch(err) {}
try { delete this.form; } catch(err) {}
try { delete this.event_handlers; } catch(err) {}
try { this.selection.destroy(); } catch(err) {}
try { delete this.selection; } catch(err) {}
var q = Spry.Widget.Form.onSubmitWidgetQueue;
var qlen = q.length;
for (var i = 0; i < qlen; i++) {
if (q[i] == this) {
q.splice(i, 1);
break;
Spry.Widget.ValidationTextField.prototype.attachBehaviors = function()
if (this.element) {
if (this.element.nodeName == "INPUT") {
this.input = this.element;
} else {
this.input = Spry.Widget.Utils.getFirstChildWithNodeNameAtAnyLevel(this.element, "INPUT");
if (this.input) {
if (this.maxChars) {
this.input.removeAttribute("maxLength");
this.putHint();
this.compilePattern();
if (this.type == 'date') {
this.compileDatePattern();
this.input.setAttribute("AutoComplete", "off");
this.selection = new Spry.Widget.SelectionDescriptor(this.input);
this.oldValue = this.input.value;
var self = this;
this.event_handlers.push([this.input, "keydown", function(e) { if (self.isDisabled()) return true; return self.onKeyDown(e || event); }]);
this.event_handlers.push([this.input, "keypress", function(e) { if (self.isDisabled()) return true; return self.onKeyPress(e || event); }]);
if (Spry.is.opera) {
this.event_handlers.push([this.input, "keyup", function(e) { if (self.isDisabled()) return true; return self.onKeyUp(e || event); }]);
this.event_handlers.push([this.input, "focus", function(e) { if (self.isDisabled()) return true; return self.onFocus(e || event); }]);
this.event_handlers.push([this.input, "blur", function(e) { if (self.isDisabled()) return true; return self.onBlur(e || event); }]);
this.event_handlers.push([this.input, "mousedown", function(e) { if (self.isDisabled()) return true; return self.onMouseDown(e || event); }]);
var changeEvent =
Spry.is.mozilla || Spry.is.opera || Spry.is.safari?"input":
Spry.is.ie?"propertychange":
"change";
this.event_handlers.push([this.input, changeEvent, function(e) { if (self.isDisabled()) return true; return self.onChange(e || event); }]);
if (Spry.is.mozilla || Spry.is.safari) {
//oninput event on mozilla does not fire ondragdrop
this.event_handlers.push([this.input, "dragdrop", function(e) { if (self.isDisabled()) return true; self.removeHint();return self.onChange(e || event); }]);
} else if (Spry.is.ie){
//ondrop&onpropertychange crash on IE
this.event_handlers.push([this.input, "drop", function(e) { if (self.isDisabled()) return true; return self.onDrop(e || event); }]);
Spry.Widget.Utils.addEventListener(this.event_handlers[i][0], this.event_handlers[i][1], this.event_handlers[i][2], false);
// submit
this.form = Spry.Widget.Utils.getFirstParentWithNodeName(this.input, "FORM");
if (this.form) {
// if no "onSubmit" handler has been attached to the current form, attach one
if (!this.form.attachedSubmitHandler && !this.form.onsubmit) {
this.form.onsubmit = function(e) { e = e || event; return Spry.Widget.Form.onSubmit(e, e.srcElement || e.currentTarget) };
this.form.attachedSubmitHandler = true;
if (!this.form.attachedResetHandler) {
Spry.Widget.Utils.addEventListener(this.form, "reset", function(e) { e = e || event; return Spry.Widget.Form.onReset(e, e.srcElement || e.currentTarget) }, false);
this.form.attachedResetHandler = true;
// add the currrent widget to the "onSubmit" check queue;
Spry.Widget.Form.onSubmitWidgetQueue.push(this);
Spry.Widget.ValidationTextField.prototype.isDisabled = function() {
return this.input && (this.input.disabled || this.input.readOnly) || !this.input;
Spry.Widget.ValidationTextField.prototype.getElement = function(ele)
if (ele && typeof ele == "string")
return document.getElementById(ele);
return ele;
Spry.Widget.ValidationTextField.addLoadListener = function(handler)
if (typeof window.addEventListener != 'undefined')
window.addEventListener('load', handler, false);
else if (typeof document.addEventListener != 'undefined')
document.addEventListener('load', handler, false);
else if (typeof window.attachEvent != 'undefined')
window.attachEvent('onload', handler);
Spry.Widget.ValidationTextField.processLoadQueue = function(handler)
Spry.Widget.ValidationTextField.onloadDidFire = true;
var q = Spry.Widget.ValidationTextField.loadQueue;
q[i].attachBehaviors();
Spry.Widget.ValidationTextField.addLoadListener(Spry.Widget.Validation TextField.processLoadQueue);
Spry.Widget.ValidationTextField.addLoadListener(function(){
Spry.Widget.Utils.addEventListener(window, "unload", Spry.Widget.Form.destroyAll, false);
Spry.Widget.ValidationTextField.prototype.setValue = function(newValue) {
this.flags.locked = true;
this.input.value = newValue;
this.flags.locked = false;
this.oldValue = newValue;
if (!Spry.is.ie) {
this.onChange();
* save the state of the input (selection and value) so we can revert to it
* should call this just before modifying the input value
Spry.Widget.ValidationTextField.prototype.saveState = function()
this.selection.update();
Spry.Widget.ValidationTextField.prototype.revertState = function(revertValue)
if (revertValue != this.input.value) {
this.input.readOnly = true;
this.input.value = revertValue;
this.input.readOnly = false;
if (Spry.is.safari && this.flags.active) {
this.input.focus();
if (this.flags.restoreSelection) {
this.selection.moveTo(this.selection.start, this.selection.end);
this.redTextFlash();
Spry.Widget.ValidationTextField.prototype.removeHint = function()
if (this.flags.hintOn) {
this.input.value = "";
this.flags.hintOn = false;
this.removeClassName(this.element, this.hintClass);
this.removeClassName(this.additionalError, this.hintClass);
Spry.Widget.ValidationTextField.prototype.putHint = function()
if(this.hint && this.input && this.input.type == "text" && this.input.value == "") {
this.flags.hintOn = true;
this.input.value = this.hint;
this.addClassName(this.element, this.hintClass);
this.addClassName(this.additionalError, this.hintClass);
Spry.Widget.ValidationTextField.prototype.redTextFlash = function()
var self = this;
this.addClassName(this.element, this.textfieldFlashTextClass);
setTimeout(function() {
self.removeClassName(self.element, self.textfieldFlashTextClass)
}, 100);
Spry.Widget.ValidationTextField.prototype.doValidations = function(testValue, revertValue)
if (this.isDisabled()) return false;
if (this.flags.locked) {
return false;
if (testValue.length == 0 && !this.isRequired) {
this.errors = 0;
return false;
var mustRevert = false;
var continueValidations = true;
if (!this.options.isRequired && testValue.length == 0) {
continueValidations = false;
var errors = 0;
var fixedValue = testValue;
//characterMasking - test if all characters are valid with the characterMasking (keyboard filter)
if (this.useCharacterMasking && this.characterMasking) {
for(var i=0; i<testValue.length; i++) {
if (!this.characterMasking.test(testValue.charAt(i))) {
errors = errors | Spry.Widget.ValidationTextField.ERROR_FORMAT;
fixedValue = revertValue;
mustRevert = true;
break;
//regExpFilter - character mask positioning (additional mask to restrict some characters only in some position)
if (!mustRevert && this.useCharacterMasking && this.regExpFilter) {
if (!this.regExpFilter.test(fixedValue)) {
mustRevert = true;
//pattern - testValue matches the pattern so far
if (!mustRevert && this.pattern) {
var currentRegExp = this.patternToRegExp(testValue.length);
if (!currentRegExp.test(testValue)) {
mustRevert = true;
} else if (this.patternLength != testValue.length) {
//testValue matches pattern so far, but it's not ok if it does not have the proper length
//do not revert, but should show the error
if (fixedValue == '') {
errors = errors | Spry.Widget.ValidationTextField.ERROR_REQUIRED;
if (!mustRevert && this.pattern && this.useCharacterMasking) {
var n = this.getAutoComplete(testValue.length);
if (n) {
fixedValue += n;
if(!mustRevert && this.minChars !== null && continueValidations) {
if (testValue.length < this.minChars) {
errors = errors | Spry.Widget.ValidationTextField.ERROR_CHARS_MIN;
if(!mustRevert && this.maxChars !== null && continueValidations) {
if (testValue.length > this.maxChars) {
errors = errors | Spry.Widget.ValidationTextField.ERROR_CHARS_MAX;
//validation - testValue passes widget validation function
if (!mustRevert && this.validation && continueValidations) {
var value = this.validation(fixedValue, this.options);
if (false === value) {
} else {
this.typedValue = value;
if(!mustRevert && this.validation && this.minValue !== null && continueValidations) {
var minValue = this.validation(this.minValue.toString(), this.options);
if (minValue !== false) {
if (this.typedValue < minValue) {
errors = errors | Spry.Widget.ValidationTextField.ERROR_RANGE_MIN;
if(!mustRevert && this.validation && this.maxValue !== null && continueValidations) {
var maxValue = this.validation(this.maxValue.toString(), this.options);
if (maxValue !== false) {
if( this.typedValue > maxValue) {
errors = errors | Spry.Widget.ValidationTextField.ERROR_RANGE_MAX;
//an invalid value was tested; must make sure it does not get inside the input
if (this.useCharacterMasking && mustRevert) {
this.revertState(revertValue);
this.errors = errors;
this.fixedValue = fixedValue;
return mustRevert;
Spry.Widget.ValidationTextField.prototype.onChange = function(e)
if (Spry.is.opera && this.flags.operaRevertOnKeyUp) {
return true;
if (Spry.is.ie && e && e.propertyName != 'value') {
return true;
if (this.flags.drop) {
//delay this if it's a drop operation
var self = this;
self.flags.drop = false;
self.onChange(null);
}, 0);
return;
return true;
if (this.keyCode == 8 || this.keyCode == 46 ) {
var mustRevert = this.doValidations(this.input.value, this.input.value);
if ((mustRevert || this.errors) && this.validateOn & Spry.Widget.ValidationTextField.ONCHANGE) {
var self = this;
setTimeout(function() {self.validate();}, 0);
return true;
var mustRevert = this.doValidations(this.input.value, this.oldValue);
if ((!mustRevert || this.errors) && this.validateOn & Spry.Widget.ValidationTextField.ONCHANGE) {
var self = this;
return true;
Spry.Widget.ValidationTextField.prototype.onKeyUp = function(e) {
if (this.flags.operaRevertOnKeyUp) {
this.setValue(this.oldValue);
Spry.Widget.Utils.stopEvent(e);
this.selection.moveTo(this.selection.start, this.selection.start);
this.flags.operaRevertOnKeyUp = false;
return false;
if (this.flags.operaPasteOperation) {
window.clearInterval(this.flags.operaPasteOperation);
this.flags.operaPasteOperation = null;
Spry.Widget.ValidationTextField.prototype.operaPasteMonitor = function() {
if (this.input.value != this.oldValue) {
if (mustRevert) {
} else {
this.onChange();
Spry.Widget.ValidationTextField.prototype.compileDatePattern = function ()
var dateValidationPatternString = "";
var groupPatterns = [];
var fullGroupPatterns = [];
var autocompleteCharacters = [];
var formatRegExp = /^([mdy]+)([\.\-\/\\\s]+)([mdy]+)([\.\-\/\\\s]+)([mdy]+)$/i;
var formatGroups = this.options.format.match(formatRegExp);
if (formatGroups !== null) {
case "dd":
groupPatterns[i-1] = "\\d{1,2}";
fullGroupPatterns[i-1] = "\\d\\d";
dateValidationPatternString += "(" + groupPatterns[i-1] + ")";
autocompleteCharacters[i-1] = null;
break;
case "mm":
break;
case "yy":
dateValidationPatternString += "(\\d\\d)";
break;
case "yyyy":
groupPatterns[i-1] = "\\d{1,4}";
fullGroupPatterns[i-1] = "\\d\\d\\d\\d";
dateValidationPatternString += "(\\d\\d\\d\\d)";
break;
default:
groupPatterns[i-1] = fullGroupPatterns[i-1] = Spry.Widget.ValidationTextField.regExpFromChars(formatGroups[i]);
dateValidationPatternString += "["+ groupPatterns[i-1] + "]";
autocompleteCharacters[i-1] = formatGroups[i];
this.dateValidationPattern = new RegExp("^" + dateValidationPatternString + "$" , "");
this.dateAutocompleteCharacters = autocompleteCharacters;
this.dateGroupPatterns = groupPatterns;
this.dateFullGroupPatterns = fullGroupPatterns;
this.lastDateGroup = formatGroups.length-2;
Spry.Widget.ValidationTextField.prototype.getRegExpForGroup = function (group)
var ret = '^';
for (var j = 0; j <= group; j++) ret += this.dateGroupPatterns[j];
ret += '$';
return new RegExp(ret, "");
Spry.Widget.ValidationTextField.prototype.getRegExpForFullGroup = function (group)
var ret = '^';
for (var j = 0; j < group; j++) ret += this.dateGroupPatterns[j];
ret += this.dateFullGroupPatterns[group];
Spry.Widget.ValidationTextField.prototype.getDateGroup = function(value, pos)
if (pos == 0) return 0;
var test_value = value.substring(0, pos);
for (var i=0; i <= this.lastDateGroup; i++)
if (this.getRegExpForGroup(i).test(test_value)) return i;
return -1;
Spry.Widget.ValidationTextField.prototype.isDateGroupFull = function(value, group)
return this.getRegExpForFullGroup(group).test(value);
Spry.Widget.ValidationTextField.prototype.isValueValid = function(value, pos, group)
return this.getRegExpForGroup(group).test(test_value);
Spry.Widget.ValidationTextField.prototype.isPositionAtEndOfGroup = function (value, pos, group)
return this.getRegExpForFullGroup(group).test(test_value);
Spry.Widget.ValidationTextField.prototype.nextDateDelimiterExists = function (value, pos, group)
var autocomplete = this.dateAutocompleteCharacters[group+1];
if (value.length < pos + autocomplete.length)
return false;
else
var test_value = value.substring(pos, pos+autocomplete.length);
if (test_value == autocomplete)
return true;
return false;
Spry.Widget.ValidationTextField.prototype.onKeyPress = function(e)
if (this.flags.skp) {
this.flags.skp = false;
return false;
if (e.ctrlKey || e.metaKey || !this.useCharacterMasking) {
return true;
if ( (e.timeStamp - this.flags.lastKeyPressedTimeStamp)<10 ) {
return true;
this.flags.lastKeyPressedTimeStamp = e.timeStamp;
return false;
if (this.keyCode == 8 || this.keyCode == 46) {
var mr = this.doValidations(this.input.value, this.input.value);
if (mr) {
return true;
var pressed = Spry.Widget.Utils.getCharacterFromEvent(e);
if (pressed && this.characterMasking) {
if (!this.characterMasking.test(pressed)) {
return false;
if(pressed && this.pattern) {
var currentPatternChar = this.patternCharacters[this.selection.start];
if (/[ax]/i.test(currentPatternChar)) {
//convert the entered character to the pattern character case
if (currentPatternChar.toLowerCase() == currentPatternChar) {
pressed = pressed.toLowerCase();
} else {
pressed = pressed.toUpperCase();
var autocomplete = this.getAutoComplete(this.selection.start);
if (this.selection.start == this.oldValue.length) {
if (this.oldValue.length < this.patternLength) {
if (autocomplete) {
var futureValue = this.oldValue.substring(0, this.selection.start) + autocomplete + pressed;
var mustRevert = this.doValidations(futureValue, this.oldValue);
if (!mustRevert) {
this.setValue(this.fixedValue);
this.selection.moveTo(this.fixedValue.length, this.fixedValue.length);
} else {
this.setValue(this.oldValue.substring(0, this.selection.start) + autocomplete);
this.selection.moveTo(this.selection.start + autocomplete.length, this.selection.start + autocomplete.length);
return false;
} else {
this.setValue(this.input.value);
return false;
} else if (autocomplete) {
return false;
var futureValue = this.oldValue.substring(0, this.selection.start) + pressed + this.oldValue.substring(this.selection.start + 1);
if (!mustRevert) {
autocomplete = this.getAutoComplete(this.selection.start + 1);
this.selection.moveTo(this.selection.start + 1 + autocomplete.length, this.selection.start + 1 + autocomplete.length);
} else {
return false;
if (pressed && this.type == 'date' && this.useCharacterMasking)
var group = this.getDateGroup(this.oldValue, this.selection.start);
if (group != -1) {
if ( (group % 2) !=0 )
group ++;
if (this.isDateGroupFull(this.oldValue, group))
if(this.isPositionAtEndOfGroup(this.oldValue, this.selection.start, group))
if(group == this.lastDateGroup)
this.redTextFlash(); return false;
else
// add or jump over autocomplete delimiter
if (this.nextDateDelimiterExists(this.oldValue, this.selection.start, group))
if (pressed == autocomplete)
return false;
if (this.isDateGroupFull(this.oldValue, group+2))
// need to overwrite first char in the next digit group
else
futureValue = this.oldValue.substring(0, this.selection.start) + pressed + this.oldValue.substring(this.selection.start);
if (!this.isValueValid(futureValue, this.selection.start + 1, group +2 ))
else
this.setValue (futureValue);
this.selection.moveTo(this.selection.start + 1, this.selection.start + 1);
return false;
else
var insertedValue = autocomplete + pressed;
futureValue = this.oldValue.substring(0, this.selection.start) + insertedValue + this.oldValue.substring(this.selection.start);
if (!this.isValueValid(futureValue, this.selection.start + insertedValue.length, group +2 ))
// block this type
insertedValue = autocomplete;
this.selection.moveTo(this.selection.start + insertedValue.length, this.selection.start + insertedValue.length);
else
return false;
else
// it's not the end of the full digits group
// overwrite
var movePosition = 1;
if (!this.isValueValid(futureValue, this.selection.start + 1, group))
else
if(this.isPositionAtEndOfGroup(futureValue, this.selection.start+1, group))
if (group != this.lastDateGroup)
if (this.nextDateDelimiterExists(futureValue, this.selection.start + 1, group))
movePosition = 1 + autocomplete.length;
else
futureValue = this.oldValue.substring(0, this.selection.start) + pressed + autocomplete + this.oldValue.substring(this.selection.start + 1);
this.selection.moveTo(this.selection.start + movePosition, this.selection.start + movePosition);
return false;
else
// date group is not full
// insert
if (!this.isValueValid(futureValue, this.selection.start + 1, group) && !this.isValueValid(futureValue, this.selection.start + 1, group+1))
else
futureValue = this.oldValue;
movePosition = 1;
else
else
return false;
return false;
Spry.Widget.ValidationTextField.prototype.onKeyDown = function(e)
this.saveState();
this.keyCode = e.keyCode;
if (e.ctrlKey) {
if (pressed && 'vx'.indexOf(pressed.toLowerCase()) != -1) {
var self = this;
this.flags.operaPasteOperation = window.setInterval(function() { self.operaPasteMonitor();}, 1);
return true;
if (this.keyCode != 8 && this.keyCode != 46 && Spry.Widget.Utils.isSpecialKey(e)) {
return true;
if (mr) {
return true;
//DELETE
if (this.useCharacterMasking && this.pattern && this.keyCode == 46) {
if (e.ctrlKey) {
//delete from selection until end
this.setValue(this.input.value.substring(0, this.selection.start));
} else if (this.selection.end == this.input.value.length || this.selection.start == this.input.value.length-1){
//allow key if selection is at end (will delete selection)
return true;
} else {
this.flags.operaRevertOnKeyUp = true;
if (Spry.is.mozilla && Spry.is.mac) {
this.flags.skp = true;
return false;
//BACKSPACE
if (this.useCharacterMasking && this.pattern && !e.ctrlKey && this.keyCode == 8) {
if (this.selection.start == this.input.value.length) {
//delete with BACKSPACE from the end of the input value only
var n = this.getAutoComplete(this.selection.start, -1);
this.setValue(this.input.value.substring(0, this.input.value.length - (Spry.is.opera?0:1) - n.length));
//cant stop the event on Opera, we'll just preserve the selection so delete will act on it
this.selection.start = this.selection.start - 1 - n.length;
this.selection.end = this.selection.end - 1 - n.length;
} else if (this.selection.end == this.input.value.length){
//allow BACKSPACE if selection is at end (will delete selection)
return true;
} else {
return false;
return true;
Spry.Widget.ValidationTextField.prototype.onMouseDown = function(e)
if (this.flags.active) {
//mousedown fires before focus
//avoid double saveState on first focus by mousedown by checking if the control has focus
//do nothing if it's not focused because saveState will be called onfocus
this.saveState();
Spry.Widget.ValidationTextField.prototype.onDrop = function(e)
//mark that a drop operation is in progress to avoid race conditions with event handlers for other events
//especially onchange and onfocus
this.flags.drop = true;
this.removeHint();
this.saveState();
this.flags.active = true;
this.addClassName(this.element, this.focusClass);
this.addClassName(this.additionalError, this.focusClass);
Spry.Widget.ValidationTextField.prototype.onFocus = function(e)
return;
this.removeHint();
if (this.pattern && this.useCharacterMasking) {
this.setValue(this.input.value + autocomplete);
this.selection.moveTo(this.input.value.length, this.input.value.length);
this.saveState();
Spry.Widget.ValidationTextField.prototype.onBlur = function(e)
this.flags.active = false;
this.removeClassName(this.element, this.focusClass);
this.removeClassName(this.additionalError, this.focusClass);
this.flags.restoreSelection = false;
this.flags.restoreSelection = true;
if (this.validateOn & Spry.Widget.ValidationTextField.ONBLUR) {
this.validate();
var self = this;
setTimeout(function() {self.putHint();}, 10);
return true;
Spry.Widget.ValidationTextField.prototype.compilePattern = function() {
if (!this.pattern) {
return;
var compiled = [];
var regexps = [];
var patternCharacters = [];
var idx = 0;
var c = '', p = '';
for (var i=0; i<this.pattern.length; i++) {
c = this.pattern.charAt(i);
if (p == '\\') {
if (/[0ABXY\?]/i.test(c)) {
regexps[idx - 1] = c;
} else {
regexps[idx - 1] = Spry.Widget.ValidationTextField.regExpFromChars(c);
compiled[idx - 1] = c;
patternCharacters[idx - 1] = null;
p = '';
continue;
regexps[idx] = Spry.Widget.ValidationTextField.regExpFromChars(c);
compiled[idx] = null;
patternCharacters[idx] = c;
} else if (c == '\\') {
compiled[idx] = c;
patternCharacters[idx] = '\\';
} else {
compiled[idx] = c;
patternCharacters[idx] = null;
idx++;
p = c;
this.autoCompleteCharacters = compiled;
this.compiledPattern = regexps;
this.patternCharacters = patternCharacters;
this.patternLength = compiled.length;
Spry.Widget.ValidationTextField.prototype.getAutoComplete = function(from, direction) {
if (direction == -1) {
var n = '', m = '';
while(from && (n = this.getAutoComplete(--from) )) {
m = n;
return m;
var ret = '', c = '';
for (var i=from; i<this.autoCompleteCharacters.length; i++) {
c = this.autoCompleteCharacters[i];
if (c) {
ret += c;
} else {
break;
return ret;
Spry.Widget.ValidationTextField.regExpFromChars = function (string) {
//string contains pattern characters
var ret = '', character = '';
for (var i = 0; i<string.length; i++) {
character = string.charAt(i);
switch (character) {
case '0': ret += '\\d';break;
case 'A': ret += '[A-Z]';break;
// case 'A': ret += '[\u0041-\u005A\u0061-\u007A\u0100-\u017E\u0180-\u0233\u0391-\u03CE\u 0410-\u044F\u05D0-\u05EA\u0621-\u063A\u0641-\u064A\u0661-\u06D3\u06F1- \u06FE]';break;
case 'a': ret += '[a-z]';break;
// case 'a': ret += '[\u0080-\u00FF]';break;
case 'B': case 'b': ret += '[a-zA-Z]';break;
case 'x': ret += '[0-9a-z]';break;
case 'X': ret += '[0-9A-Z]';break;
case 'Y': case 'y': ret += '[0-9a-zA-Z]';break;
case '?': ret += '.';break;
case '1':case '2':case '3':case '4':case '5':case '6':case '7':case '8':case '9':
ret += character;
break;
case 'c': case 'C': case 'e': case 'E': case 'f': case 'F':case 'r':case 'd': case 'D':case 'n':case 's':case 'S':case 'w':case 'W':case 't':case 'v':
ret += character;
break;
default: ret += '\\' + character;
return ret;
Spry.Widget.ValidationTextField.prototype.patternToRegExp = function(len) {
var ret = '^';
var end = Math.min(this.compiledPattern.length, len);
for (var i=0; i < end; i++) {
ret += this.compiledPattern[i];
ret += '$';
ret = new RegExp(ret, "");
return ret;
Spry.Widget.ValidationTextField.prototype.resetClasses = function() {
var classes = [this.requiredClass, this.invalidFormatClass, this.invalidRangeMinClass, this.invalidRangeMaxClass, this.invalidCharsMinClass, this.invalidCharsMaxClass, this.validClass];
for (var i=0; i < classes.length; i++)
this.removeClassName(this.element, classes[i]);
this.removeClassName(this.additionalError, classes[i]);
Spry.Widget.ValidationTextField.prototype.reset = function() {
this.removeHint();
this.oldValue = this.input.defaultValue;
this.resetClasses();
if (Spry.is.ie) {
//this will fire the onpropertychange event right after the className changed on the container element
//IE6 will not fire the first onpropertychange on an input type text after a onreset handler if inside that handler the className of one of the elements inside the form has been changed
//to reproduce: change the className of one of the elements inside the form from within the onreset handler; then the onpropertychange does not fire the first time
this.input.forceFireFirstOnPropertyChange = true;
this.input.removeAttribute("forceFireFirstOnPropertyChange");
var self = this;
Spry.Widget.ValidationTextField.prototype.validate = function() {
//possible states: required, format, rangeMin, rangeMax, charsMin, charsMax
if (this.validateOn & Spry.Widget.ValidationTextField.ONSUBMIT) {
this.removeHint();
if(!this.flags.active) {
var self = this;
if (this.isRequired && this.errors & Spry.Widget.ValidationTextField.ERROR_REQUIRED) {
this.addClassName(this.element, this.requiredClass);
this.addClassName(this.additionalError, this.requiredClass);
return false;
if (this.errors & Spry.Widget.ValidationTextField.ERROR_FORMAT) {
this.addClassName(this.element, this.invalidFormatClass);
this.addClassName(this.additionalError, this.invalidFormatClass);
return false;
if (this.errors & Spry.Widget.ValidationTextField.ERROR_RANGE_MIN) {
this.addClassName(this.element, this.invalidRangeMinClass);
this.addClassName(this.additionalError, this.invalidRangeMinClass);
return false;
if (this.errors & Spry.Widget.ValidationTextField.ERROR_RANGE_MAX) {
this.addClassName(this.element, this.invalidRangeMaxClass);
this.addClassName(this.additionalError, this.invalidRangeMaxClass);
return false;
if (this.errors & Spry.Widget.ValidationTextField.ERROR_CHARS_MIN) {
this.addClassName(this.element, this.invalidCharsMinClass);
this.addClassName(this.additionalError, this.invalidCharsMinClass);
return false;
if (this.errors & Spry.Widget.ValidationTextField.ERROR_CHARS_MAX) {
this.addClassName(this.element, this.invalidCharsMaxClass);
this.addClassName(this.additionalError, this.invalidCharsMaxClass);
return false;
this.addClassName(this.element, this.validClass);
this.addClassName(this.additionalError, this.validClass);
return true;
Spry.Widget.ValidationTextField.prototype.addClassName = function(ele, className)
if (!ele || !className || (ele.className && ele.className.search(new RegExp("\\b" + className + "\\b")) != -1))
return;
ele.className += (ele.className ? " " : "") + className;
Spry.Widget.ValidationTextField.prototype.removeClassName = function(ele, className)
if (!ele || !className || (ele.className && ele.className.search(new RegExp("\\b" + className + "\\b")) == -1))
return;
ele.className = ele.className.replace(new RegExp("\\s*\\b" + className + "\\b", "g"), "");
Spry.Widget.ValidationTextField.prototype.showError = function(msg)
alert('Spry.Widget.TextField ERR: ' + msg);
* SelectionDescriptor is a wrapper for input type text selection methods and properties
* as implemented by various browsers
Spry.Widget.SelectionDescriptor = function (element)
this.element = element;
this.update();
Spry.Widget.SelectionDescriptor.prototype.update = function()
if (Spry.is.ie && Spry.is.windows) {
var sel = this.element.ownerDocument.selection;
if (this.element.nodeName == "TEXTAREA") {
if (sel.type != 'None') {
try{var range = sel.createRange();}catch(err){return;}
if (range.parentElement() == this.element){
var range_all = this.element.ownerDocument.body.createTextRange();
range_all.moveToElementText(this.element);
for (var sel_start = 0; range_all.compareEndPoints('StartToStart', range) < 0; sel_start ++){
range_all.moveStart('character', 1);
this.start = sel_start;
// create a selection of the whole this.element
for (var sel_end = 0; range_all.compareEndPoints('StartToEnd', range) < 0; sel_end++){
this.end = sel_end;
this.length = this.end - this.start;
// get selected and surrounding text
this.text = range.text;
} else if (this.element.nodeName == "INPUT"){
try{this.range = sel.createRange();}catch(err){return;}
this.length = this.range.text.length;
var clone = this.range.duplicate();
this.start = -clone.moveStart("character", -10000);
clone.collapse(false);
this.end = -clone.moveStart("character", -10000);
this.text = this.range.text;
} else {
var tmp = this.element;
var selectionStart = 0;
var selectionEnd = 0;
try { selectionStart = tmp.selectionStart;} catch(err) {}
try { selectionEnd = tmp.selectionEnd;} catch(err) {}
if (selectionStart == 2147483647) {
selectionStart = 0;
if (selectionEnd == 2147483647) {
selectionEnd = 0;
this.start = selectionStart;
this.end = selectionEnd;
this.length = selectionEnd - selectionStart;
this.text = this.element.value.substring(selectionStart, selectionEnd);
Spry.Widget.SelectionDescriptor.prototype.destroy = function() {
try { delete this.range} catch(err) {}
try { delete this.element} catch(err) {}
Spry.Widget.SelectionDescriptor.prototype.move = function(amount)
this.range.move("character", amount);
this.range.select();
} else {
try { this.element.selectionStart++;}catch(err) {}
this.update();
Spry.Widget.SelectionDescriptor.prototype.moveTo = function(start, end)
var ta_range = this.element.createTextRange();
this.range = this.element.createTextRange();
this.range.move("character", start);
this.range.moveEnd("character", end - start);
var c1 = this.range.compareEndPoints("StartToStart", ta_range);
if (c1 < 0) {
this.range.setEndPoint("StartToStart", ta_range);
var c2 = this.range.compareEndPoints("EndToEnd", ta_range);
if (c2 > 0) {
this.range.setEndPoint("EndToEnd", ta_range);
this.range = this.element.ownerDocument.selection.createRange();
this.range.move("character", -10000);
this.start = this.range.moveStart("character", start);
this.end = this.start + this.range.moveEnd("character", end - start);
} else {
this.start = start;
try { this.element.selectionStart = start;} catch(err) {}
this.end = end;
try { this.element.selectionEnd = end;} catch(err) {}
this.ignore = true;
this.update();
Spry.Widget.SelectionDescriptor.prototype.moveEnd = function(amount)
this.range.moveEnd("character", amount);
} else {
try { this.element.selectionEnd++;} catch(err) {}
this.update();
Spry.Widget.SelectionDescriptor.prototype.collapse = function(begin)
this.range.collapse(begin);
} else {
if (begin) {
try { this.element.selectionEnd = this.element.selectionStart;} catch(err) {}
} else {
try { this.element.selectionStart = this.element.selectionEnd;} catch(err) {}
this.update();
// Spry.Widget.Form - common for all widgets
if (!Spry.Widget.Form) Spry.Widget.Form = {};
if (!Spry.Widget.Form.onSubmitWidgetQueue) Spry.Widget.Form.onSubmitWidgetQueue = [];
if (!Spry.Widget.Form.validate) {
Spry.Widget.Form.validate = function(vform) {
var isValid = true;
var isElementValid = true;
if (!q[i].isDisabled() && q[i].form == vform) {
isElementValid = q[i].validate();
isValid = isElementValid && isValid;
return isValid;
if (!Spry.Widget.Form.onSubmit) {
Spry.Widget.Form.onSubmit = function(e, form)
if (Spry.Widget.Form.validate(form) == false) {
return false;
return true;
if (!Spry.Widget.Form.onReset) {
Spry.Widget.Form.onReset = function(e, vform)
if (!q[i].isDisabled() && q[i].form == vform && typeof(q[i].reset) == 'function') {
q[i].reset();
return true;
if (!Spry.Widget.Form.destroy) {
Spry.Widget.Form.destroy = function(form)
for (var i = 0; i < Spry.Widget.Form.onSubmitWidgetQueue.length; i++) {
if (q[i].form == form && typeof(q[i].destroy) == 'function') {
q[i].destroy();
i--;
if (!Spry.Widget.Form.destroyAll) {
Spry.Widget.Form.destroyAll = function()
if (typeof(q[i].destroy) == 'function') {
q[i].destroy();
i--;
// Spry.Widget.Utils
if (!Spry.Widget.Utils) Spry.Widget.Utils = {};
Spry.Widget.Utils.punycode_constants = {
base : 36, tmin : 1, tmax : 26, skew : 38, damp : 700,
initial_bias : 72, initial_n : 0x80, delimiter : 0x2D,
maxint : 2<<26-1
Spry.Widget.Utils.punycode_encode_digit = function (d) {
return String.fromCharCode(d + 22 + 75 * (d < 26));
Spry.Widget.Utils.punycode_adapt = function (delta, numpoints, firsttime) {
delta = firsttime ? delta / this.punycode_constants.damp : delta >> 1;
delta += delta / numpoints;
for (var k = 0; delta > ((this.punycode_constants.base - this.punycode_constants.tmin) * this.punycode_constants.tmax) / 2; k += this.punycode_constants.base) {
delta /= this.punycode_constants.base - this.punycode_constants.tmin;
return k + (this.punycode_constants.base - this.punycode_constants.tmin + 1) * delta / (delta + this.punycode_constants.skew);
* returns a Punicode representation of a UTF-8 string
* adapted from http://tools.ietf.org/html/rfc3492
Spry.Widget.Utils.punycode_encode = function (input, max_out) {
var inputc = input.split("");
input = [];
for(var i=0; i<inputc.length; i++) {
input.push(inputc[i].charCodeAt(0));
var output = '';
var h, b, j, m, q, k, t;
var input_len = input.length;
var n = this.punycode_constants.initial_n;
var delta = 0;
var bias = this.punycode_constants.initial_bias;
var out = 0;
for (j = 0; j < input_len; j++) {
if (input[j] < 128) {
if (max_out - out < 2) {
return false;
output += String.fromCharCode(input[j]);
out++;
h = b = out;
if (b > 0) {
output += String.fromCharCode(this.punycode_constants.delimiter);
out++;
while (h < input_len) {
for (m = this.punycode_constants.maxint, j = 0; j < input_len; j++) {
if (input[j] >= n && input[j] < m) {
m = input[j];
if (m - n > (this.punycode_constants.maxint - delta) / (h + 1)) {
return false;
delta += (m - n) * (h + 1);
n = m;
if (input[j] < n ) {
if (++delta == 0) {
return false;
if (input[j] == n) {
for (q = delta, k = this.punycode_constants.base; true; k += this.punycode_constants.base) {
if (out >= max_out) {
return false;
t = k <= bias ? this.punycode_constants.tmin : k >= bias + this.punycode_constants.tmax ? this.punycode_constants.tmax : k - bias;
if (q < t) {
break;
output += this.punycode_encode_digit(t + (q - t) % (this.punycode_constants.base - t));
out++;
q = (q - t) / (this.punycode_constants.base - t);
output += this.punycode_encode_digit(q);
out++;
bias = this.punycode_adapt(delta, h + 1, h == b);
delta = 0;
h++;
delta++, n++;
return output;
Spry.Widget.Utils.setOptions = function(obj, optionsObj, ignoreUndefinedProps)
if (!optionsObj)
return;
for (var optionName in optionsObj)
if (ignoreUndefinedProps && optionsObj[optionName] == undefined)
continue;
obj[optionName] = optionsObj[optionName];
Spry.Widget.Utils.firstValid = function() {
var ret = null;
for(var i=0; i<Spry.Widget.Utils.firstValid.arguments.length; i++) {
if (typeof(Spry.Widget.Utils.firstValid.arguments[i]) != 'undefined') {
ret = Spry.Widget.Utils.firstValid.arguments[i];
break;
return ret;
Spry.Widget.Utils.specialCharacters = ",8,9,16,17,18,20,27,33,34,35,36,37,38,40,45,144,192,63232,";
Spry.Widget.Utils.specialSafariNavKeys = "63232,63233,63234,63235,63272,63273,63275,63276,63277,63289,";
Spry.Widget.Utils.specialNotSafariCharacters = "39,46,91,92,93,";
Spry.Widget.Utils.specialCharacters += Spry.Widget.Utils.specialSafariNavKeys;
if (!Spry.is.safari) {
Spry.Widget.Utils.specialCharacters += Spry.Widget.Utils.specialNotSafariCharacters;
Spry.Widget.Utils.isSpecialKey = function (ev) {
return Spry.Widget.Utils.specialCharacters.indexOf("," + ev.keyCode + ",") != -1;
Spry.Widget.Utils.getCharacterFromEvent = function(e){
var keyDown = e.type == "keydown";
var code = null;
var character = null;
if(Spry.is.mozilla && !keyDown){
if(e.charCode){
character = String.fromCharCode(e.charCode);
} else {
code = e.keyCode;
} else {
code = e.keyCode || e.which;
if (code != 13) {
character = String.fromCharCode(code);
if (keyDown) {
} else {
if (Spry.Widget.Utils.specialCharacters.indexOf("," + code + ",") != -1) {
character = null;
} else {
if(Spry.is.opera) {
character = null;
} else {
return character;
Spry.Widget.Utils.getFirstChildWithNodeNameAtAnyLevel = function(node, nodeName)
var elements = node.getElementsByTagName(nodeName);
if (elements) {
return elements[0];
return null;
Spry.Widget.Utils.getFirstParentWithNodeName = function(node, nodeName)
while (node.parentNode
&& node.parentNode.nodeName.toLowerCase() != nodeName.toLowerCase()
&& node.parentNode.nodeName != 'BODY') {
node = node.parentNode;
if (node.parentNode && node.parentNode.nodeName.toLowerCase() == nodeName.toLowerCase()) {
return node.parentNode;
} else {
return null;
Spry.Widget.Utils.destroyWidgets = function (container)
if (typeof container == 'string') {
container = document.getElementById(container);
if (typeof(q[i].destroy) == 'function' && Spry.Widget.Utils.contains(container, q[i].element)) {
q[i].destroy();
i--;
Spry.Widget.Utils.contains = function (who, what)
if (typeof who.contains == 'object') {
return what && who && (who == what || who.contains(what));
} else {
var el = what;
while(el) {
if (el == who) {
return true;
el = el.parentNode;
return false;
Spry.Widget.Utils.addEventListener = function(element, eventType, handler, capture)
try
if (element.addEventListener)
element.addEventListener(eventType, handler, capture);
else if (element.attachEvent)
element.attachEvent("on" + eventType, handler, capture);
catch (e) {}
Spry.Widget.Utils.removeEventListener = function(element, eventType, handler, capture)
try
if (element.removeEventListener)
element.removeEventListener(eventType, handler, capture);
else if (element.detachEvent)
element.detachEvent("on" + eventType, handler, capture);
catch (e) {}
Spry.Widget.Utils.stopEvent = function(ev)
try
this.stopPropagation(ev);
this.preventDefault(ev);
catch (e) {}
* Stops event propagation
* @param {Event} ev the event
Spry.Widget.Utils.stopPropagation = function(ev)
if (ev.stopPropagation)
ev.stopPropagation();
else
ev.cancelBubble = true;
* Prevents the default behavior of the event
Spry.Widget.Utils.preventDefault = function(ev)
if (ev.preventDefault)
ev.preventDefault();
else
ev.returnValue = false;
})(); // EndSpryComponent
Just to be thorough, I'm including this .php file code which is also associated with the HTML file in my original post.
This is the entire contents of webformmailer.php, which is the file GoDaddy put in the root directory of my hosting account upon my request to make my form results emailable. That part of the form function is working successfully.
But I was thinking could there maybe be something in their .php file that's causing the incorrect redirect? And if so, how would I counter that instruction...hopefully, without having to get into the .php file if possible?
<?php
if ( !isset($_SERVER['SPI'])) {
die();
if (!isset($_SERVER['DOCUMENT_ROOT'])) {
echo("CRITICAL: we seem to be running outside of the norm.\n");
header("Location: http://".$_SERVER["HTTP_HOST"]."/");
die("CRITICAL: Document root unavailable.\n");
$request_method = $_SERVER["REQUEST_METHOD"];
if($request_method == "GET") {
$query_vars = $_GET;
elseif ($request_method == "POST") {
$query_vars = $_POST;
reset($query_vars);
function customsort($a,$b) {
// $a is array for form vars, $b is comma seperated case sensitive field order
// this is case sensitive -- good idea to hrc that.
$data = array();
if ( strstr($b,',') == FALSE ) {
$b = $b.",";
$ordering = split(',',$b);
foreach ($ordering as $orderitem) {
if ( ($orderitem != null) && ($orderitem != "") ) {
if (isset($a[$orderitem])) {
$data[$orderitem] = $a[$orderitem];
foreach ($a as $key=>$val) {
$data[$key] = $a[$key];
return $data;
function xmlentities($string) {
return str_replace ( array('&', '"', "'", '<', '>'), array('&', '"', ''', '<', '>'), $string);
$t = date("U");
$formhomedir = preg_replace('/.*\/home\/content/','',$_SERVER['DOCUMENT_ROOT']);
$formhomedir = explode('/',$formhomedir);
if (count($formhomedir) <= 4) {
$formhome="/home/content/".$formhomedir[1]."/".$formhomedir[2]."/data /";
else {
$formhome="/home/content/".$formhomedir[1]."/".$formhomedir[2]."/".$f ormhomedir[3]."/".$formhomedir[4]."/data/";
$file_order = ".default";
$file_format = ".text";
$file_interval = ".15m";
$field_order = "";
if (isset($query_vars['form_order'])) {
if ($query_vars['form_order'] != "alpha") {
$field_order=$query_vars['form_order'];
$file_order=".custom";
$query_vars = customsort($query_vars,$field_order);
else {
switch ($query_vars['form_order']) {
case "alpha":
uksort($query_vars,'strnatcasecmp');
$file_order=".alpha";
break;
default:
$file_order=".default";
break;
if (isset($query_vars['form_format'])) {
switch ($query_vars['form_format']) {
case "csv":
$file_format = ".csv";
break;
case "html":
$file_format = ".html";
break;
case "xml":
$file_format = ".xml";
break;
case "text":
case "default":
default:
break;
if (isset($query_vars['form_delivery'])) {
switch ($query_vars['form_delivery']) {
case "hourly":
$file_interval = ".60m";
break;
case "hourly_digest":
$file_interval = ".60mc";
break;
case "daily":
$file_interval = ".24h";
break;
case "daily_digest":
$file_interval = ".24hc";
break;
case "digest":
$file_interval = ".15mc";
break;
case "default":
default:
break;
$file = $formhome."form_".$t.$file_order.$file_format.$file_interval;
$fp = fopen($file,"w");
reset($query_vars);
switch ($file_format) {
case ".csv":
$csvkeys = "";
$csvvals= "";
$firsttime = "";
while (list ($key, $val) = each ($query_vars)) {
if ( ($key == "form_order") ||
($key == "form_format") ||
($key == "form_delivery") ||
($key == "redirect") ) {
else {
if ($csvkeys != "") {
$firsttime=",";
$tmpkey=escapeshellcmd($key);
$csvkeys = $csvkeys.$firsttime."'".$tmpkey."'";
$tmpval=escapeshellcmd($val);
$csvvals = $csvvals.$firsttime."'".$tmpval."'";
fputs($fp,"$csvkeys\n");
fputs($fp,"$csvvals\n");
break;
case ".html":
fputs($fp,"<table border=\"1\" cellspacing=\"1\" cellpadding=\"2\">\n");
break;
case ".xml":
fputs($fp,"<form>\n");
break;
reset($query_vars);
if ($key == "redirect") {
$landing_page = $val;
else {
case ".html":
fputs($fp,"\t<tr>\n");
fputs($fp,"\t\t<td><b>$key</b></td>\n");
fputs($fp,"\t\t<td>$val</td>\n");
fputs($fp,"\t</tr>\n");
break;
case ".csv":
// content is already output
break;
case ".xml":
fputs($fp,"\t<field>\n");
fputs($fp,"\t\t<fieldname>".xmlentities($key)."</fieldname>\n");
fputs($fp,"\t\t<fieldvalue>".xmlentities($val)."</fieldvalue>\n");
fputs($fp,"\t</field>\n");
break;
case ".text":
default:
fputs($fp,$key.": ".$val."\n");
break;
case ".html":
fputs($fp,"</table>\n");
break;
case ".xml":
fputs($fp,"</form>\n");
break;
fclose($fp);
if ($landing_page != "") {
header("Location: http://".$_SERVER["HTTP_HOST"]."/$landing_page");
else {
You could try changing this:
else {
to: (thankyou.html is a custom page you can set up)
else {
header("Location: http://www.yourDomain.com/thankyou.html");
OR try the other way around if the above doesn't work. I don't know what the $landing_page variable is refering to:
else {
Genius! That worked. I only tried part one and it was successful. What a relief. Thank you.
I do still have an issue however. I have two fill-in forms with validation on the website. I can use the solution you've provided to redirect Form #1. How do I redirect Form#2 to a thankyou#2.htm page?
Sorry if this is improper netiquette...do I need to begin a new thread for this additional question?
Thanks, Sudarshan. I really appreciate your help. I started to strip out client details from the webpage and things began to break. Maybe this is silly since the site will very soon be live. But before I have client approval, I'm concerned with breaching confidentiality.
Now that's a question I don't have an answer for. If you have two forms it may be better to put the 'redirect' in the webformmailer.php file. Can you show me what is in that? Then you can send one form to webformmailer_1.php and the other to webformmailer_2.php for processing
Oh, that's actually what I did...put the redirect in the webformmailer.php file. The file, in its entirety, is copied above in my post of 5:17am. I just replaced the bit at the end as you'd suggested.
I did exactly that and it worked! Which is great.
My only concern is that, since webformmailer.php is a file written and maintained by GoDaddy, if they make changes to it or how their servers respond to it, I may have issues. Does that seem unlikely? Am I overthinking this?
Yeah, sorry I provided the solution and then forgot lol!
It's highly unlikely that they would make changes to the servers that would stop the php script running on their servers. The php just looks to me like standard php, nothing particularly associated specifically with GoDaddy.
Well its good to overthink because that will eliminate a lot of issues!
I think your safe.
