Operandom
How to share remoteclass with netGroup?
Sep 25, 2012 8:56 AM
Hi!
I try to share instance of a class between two applications but the message receive is just an object and not the instance of the class and when I try to convert it into a class, I get a "null" value.
Here some infos about what I done:
a exemple class:
[Bindable]
[RemoteClass(alias="com.brand.Message")]
public class Message
     // Some properties
I send it with netGroup:
_netGroup.sendToNearest(message, neighbor.address);
So on the other application I receive the Message instance as an Object so I try to convert it to Message:
var message:Message = event.info.message as Message;
But message is "null" when it's done...
So, is it possible to receive automaticly the good object type (here "Message") and, if not, how to convert it?
Thx!!
  • kglad
    Jul 21, 2002
    Sep 25, 2012 9:49 AM   in reply to Operandom
    only a serializable object can be sent.  you can serialize your object by using describeType().  you would then need to read the resulting xml and recreate the object using those data.
  • kglad
    Jul 21, 2002
    Sep 25, 2012 12:11 PM   in reply to Operandom
    are you creating a bytearray of your object to serialize it?
  • kglad
    Jul 21, 2002
    Sep 25, 2012 2:05 PM   in reply to Operandom
    nvm.  you're using p2p networking for all recipients have access to that class.
