CF 10 docs seem a tad thin on the subject of silent / unattended / scripted installation and configuration.
I need to find a fully automated (scripted) way to do these things:
1) install of ColdFusion 10 server in standalone mode
2) create additional servers instances
3) configure each server instance separately (settings, data sources, mappings, etc)
Is this currently possible with CF 10? If yes, where's the documentation?
I'm aiming for a Chef cookbook for performing unattended CF10 installations on a farm of headless Linux hosts. Manual configuration through the Administrator UI is a definite deal breaker here.
Thanks in advance!
Best regards,
Jan
For convenience, a summary..
How to silently:
1a) install ColdFusion 10 server software: 4721871
1b) complete default server instance installation: 4722100
2) create additional servers instances: 4722350
3) configure each server instance separately: 4724683
Related files:
Br,
Jan
[Updated in 2021, by Charlie A, to correct the links offered. They were to Jan's various comments in this thread, but they had the form/url of the old forums, so
...Copy link to clipboard
Jan, I can confirm there’s no reference to a silent install in the CF 10 Install guide (searched the PDF), but while there is also was no reference to it in CF9 install guide, there was in fact a blog entry from the CF team about how to do it for CF9:
http://blogs.adobe.com/cfdoc/2009/10/performing_a_silent_installation_of_coldfusion_9.html
It’s hard to know if that info would help with CF10, given the change from Jrun to Tomcat, but you may want to try it (if you have a good setup to recover if it doesn’t), or I’d recommend that you post a comment there asking if it’s possible to use that for CF10.
If you do give it a try, please do reply here (and there) to let others know how it went, if they may look for this solution and find either in a search result.
Hope that helps.
/charlie
I just got the list of silent installation variables for cf10
#Silent properties for ColdFusion 10
INSTALLER_UI=SILENT
#Valid Values are full/trial/developer SILENT_LICENSE_MODE=full
SILENT_SERIAL_NUMBER=XXXX-XXXX-XXXX-XXXX-XXXX-XXXX
#Use when it is upgrade
SILENT_PREV_SERIAL_NUMBER=
#Valid values are ear/war/standalone SILENT_INSTALLER_TYPE=standalone
SILENT_INSTALL_ODBC=true
SILENT_INSTALL_SAMPLES=true
SILENT_INSTALL_JNBRIDGE=true
SILENT_INSTALL_ADMIN=true
SILENT_INSTALL_SOLR=true
SILENT_INSTALL_FOLDER=C:\\ColdFusion10
#enable secure profile, IP addresses from which Administrator can be accessed.
SILENT_ENABLE_SECURE_PROFILE=true
SILENT_ADMIN_IP=
SILENT_ADMIN_USERNAME=admin
SILENT_ADMIN_PASSWORD=Adm1n$
SILENT_ENABLE_RDS=false
#Provide password when enable RDS is true
SILENT_RDS_PASSWORD=
#remote username/password
SILENT_JETTY_USERNAME=admin
SILENT_JETTY_PASSWORD=Adm1n$
#Context Root for J2ee Installation
SILENT_CONTEXT_ROOT=
#automatically check for serverupdates. SILENT_AUTO_ENABLE_UPDATES=true
#Migration (applicable to non-windows OSes only) SILENT_MIGRATE_COLDFUSION=
SILENT_PREV_CF_MIGR_DIR=
I noticed that in Windows servers, passwords set in the silent installation do not do well with some special characters.
I've also noticed some discussion about touching the admin page after installation to complete the install. I think that just first touch of the admin page just triggers migration wizards. This can be bypassed by revising the file adminconfig.xml located under %installation_root%/cfusion/lib and changing <runsetupwizard>true</runsetupwizard> to <runsetupwizard>false</runsetupwizard>
I'll try to folow up later with how I am installing on our servers.
One more observation related to the silent installation response file: It is highly sensitive to white space.
Having eg. "SILENT_INSTALL_SOLR=true " (space between "true" and end of line) will result in Solr not being installed.
So, if you're not getting the expected results from a silent install, make white space visible in your text editor and take a closer look at the response file.
Br,
Jan
Hi.
I gave it a go this morning and it seems that the CF 10 installer supports a response file like previous versions did.
Installation steps:
installer.profile (example)
INSTALLER_UI=SILENT
SILENT_LICENSE_MODE=developer
#SILENT_SERIAL_NUMBER=XXXX-XXXX-XXXX-XXXX-XXXX-XXXX
SILENT_CONTEXT_ROOT=/
SILENT_RUNTIME_USER=coldfusion
SILENT_INSTALL_FOLDER=/opt/coldfusion10
# Optional components and services
#Passwords
SILENT_ADMIN_PASSWORD=xxxxxxxxx
SILENT_RDS_PASSWORD=xxxxxxxxx
This puts ColdFusion 10 software on a host with little effort, but it's not really ready to run an application yet. Got us a few steps closer to that goal nevertheless.
Tero Pikala kindly shared his setup scripts for CF 9. They contain nice tricks involving curl and hacking neo-security.xml for automating step 6 and additional server instance creation. It's basically a simulated browser approach. I'll take a look at that next.
Br,
Jan
Ok. To automate step 6 as well, you need to
Because neo-security.xml is a pile of ugly-printed wddx mess not even meant to be human-readable, I wrote a small shell script called neo-security-config.sh to aid in modifying it. It's available here: http://pastebin.com/jAVStuJ6.
Here's my current installation script:
# Install CF
sudo ./ColdFusion_10_WWEJ_linux64.bin -f installer.profile
# Disable admin security
sudo ./neo-security-config.sh /opt/coldfusion10/cfusion false
# Start up the CF server instance and wait for a moment
sudo /opt/coldfusion10/cfusion/bin/coldfusion start; sleep 15
# Simulate a browser request on the admin UI to complete installation
wget --delete-after http://localhost:8500/CFIDE/administrator/index.cfm?configServer=true
# Stop the CF server instance
sudo /opt/coldfusion10/cfusion/bin/coldfusion stop
# Re-enable admin security
sudo ./neo-security-config.sh /opt/coldfusion10/cfusion true
This script installs ColdFusion 10 with no need for operator intervention, in less than 3 minutes (ymmv).
Br,
Jan
2) Create additional server instances
In addressing need #2, working around CF 10's cross-site request forgery (CSRF) protection turned out to be the biggest hurdle.
Anyway, here's the code:
#!/bin/bash
# Create additional server instances
SERVER_NAMES="server-a server-b server-c"
COOKIEFILE="/tmp/curl-cookies-$$.txt"
CURL_CMD="curl --noproxy localhost --cookie-jar $COOKIEFILE --cookie $COOKIEFILE -s"
ENTMANURL="http://localhost:8500/CFIDE/administrator/entman"
touch $COOKIEFILE
NEXTPAGE=`$CURL_CMD $ENTMANURL/index.cfm | sed -n 's/.*action="\(addserver.cfm?servertype=addlocal[^"]*\).*/\1/p'`
NEXTPAGE=`$CURL_CMD $ENTMANURL/$NEXTPAGE | sed -n 's/.*action="\(processaddserver.cfm?[^"]*\).*/\1/p'`
for SERVER_NAME in $SERVER_NAMES; do
echo $SERVER_NAME
$CURL_CMD -d "serverName=$SERVER_NAME&directory=/opt/coldfusion10/$SERVER_NAME" $ENTMANURL/$NEXTPAGE > /dev/null
done
rm $COOKIEFILE
Not exactly pretty. Please let me know if you have a simpler way of doing this.
Great stuff. Thanks for sharing, Jan. Hope it may help others.
That said, I would still propose that you bring this up on the blog entry on the CF9 silent installer, to see what the Adobe folks may have to say. I would even propose that you offer a link back to this thread here (http://forums.adobe.com/message/4722350), so that others reading that entry could find what you've shared, if for some reason Adobe doesn't respond.
Glad the suggestion got you in the right direction, and thanks for documenting the details for getting it working as you have.
Charlie, commenting the original blog post is an excellent idea, thanks. I tried it, but it says "Sorry, comments are closed for this item."
I posted the comment on the CF10 online documentation page Installing ColdFusion 10 instead.
Wow, bummer. I just confirmed that, too. Really surprises me. I will contact folks at Adobe to get more info, if any.
/charlie
Step 3) configure each server instance separately (settings, data sources, mappings, etc)
Automated server instance configuration is possible using the CF Administator API. Take a look at "CFIDE.adminapi" in eg. http://localhost:8500/CFIDE/componentutils/componentdoc.cfm for details.
Server instance configuration steps:
In code:
CF_INSTANCE=/opt/coldfusion10/server-a
sudo $CF_INSTANCE/bin/coldfusion stop
sudo ./neo-security-config.sh $CF_INSTANCE false
sudo cp configure.cfm $CF_INSTANCE/wwwroot/
sudo $CF_INSTANCE/bin/coldfusion start; sleep 15
CF_HTTP_PORT=`grep Http11Protocol $CF_INSTANCE/runtime/conf/server.xml | sed -n 's/.*port="\([0-9]*\).*/\1/p'`
curl --noproxy localhost http://localhost:$CF_HTTP_PORT/configure.cfm
sudo rm $CF_INSTANCE/wwwroot/configure.cfm
sudo ./neo-security-config.sh $CF_INSTANCE true
You could also do this without disabling security, but then you'd need to include the admin password in configure.cfm.
With this, I believe my three automation requirements are now satisfied. The solution is not as clean as I'd like, but usable.
Br,
Jan
How to silently:
Related files:
Br,
Jan
[Updated in 2021, by Charlie A, to correct the links offered. They were to Jan's various comments in this thread, but they had the form/url of the old forums, so were all just dropping users at the top of this thread. I changed them to point to the new comment URL/location.]
I know this is an old post, but I thought I'd point out the following chef cookbook: https://github.com/wharton/chef-coldfusion10. This cookbook installs ColdFusion 10, applies updates, can configure Apache if using opscode's apache2 cookbook, and has providers that allow you to easily configure multiple instances via the admin api. The cookbook has been under development for over a year and more enhancements are planned (for example a wsconfig LWRP). For more information see the cookbook README.
(Disclamier: I'm the primary author of the cookbook.)
For any who may come along to this thread later, the CF docs did eventually get updated to have what had been in the CF9 ones (for for some reason were not there at the time of this thread, in 2012, in the CF10 docs):
https://helpx.adobe.com/coldfusion/installing/installing-coldfusion-silently.html
