GS3333
Divs are shifting after inserting spry menu bar
Sep 25, 2012 8:54 PM
I have tried so much that it has driven me crazy. Initailly I created this site by APdivs and it came out perfect and worked great, except it was not fluid and looked bad on bigger browser and screen size. I decided to change it to fluid way. Now I am in bad shape as soon as I put a horizontal spry menu bar. it shifts the columns to the left and leaves a blank space next to the column 3. I am out of idea, how to fix it. As soon as I take the menu bar out, it works perfect. and columns are stretched to the end on both sides.
Here is the link of test page
www.hpbsurgery.net
This is what I have tried-nothing worked
put menu bar in container
put menu bar in header div
Put mebu bar in a horizontal div inside header div.
changed the size and dimension of menu bar
Any help would be greatly appreciated as I am running out of time.
Thanks much all....
    Sep 26, 2012 3:30 AM   in reply to GS3333
    I'm not see what you are describing...have you fixed it? If not what browser is this happening in?
    Sep 26, 2012 11:46 AM   in reply to GS3333
    You appear confused about how to use CSS classes and IDs.  Classes (.className) can be used multiple times in layouts as for re-usable styles.  IDs (#IDName) can be used only one time per page -- as for layout regions or when JavaScript is needed to act upon it.
    Try copying and pasting this code into a new blank page.  Hopefully it will make more sense than what you have now.
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml">
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <title>Untitled Document</title>
    <link href="http://www.hpbsurgery.net/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css" />
    <script src="http://www.hpbsurgery.net/SpryMenuBar.js" type="text/javascript"></script>
    <!--NEW LAYOUT-->
    <style type="text/css">
    body {
    margin:0;
    font-family:Arial, Helvetica, sans-serif;
    font-size: 16px;
    width:100%;
    min-width:400px;
    max-width: 1280px;
    background-color: silver;
    overflow:hidden; /*for float containment*/
    #header {
    width: 100%;
    padding: 0px;
    background-color: pink;
    margin: 0px;
    #horizontalmenu {
    min-height: 43px;
    width: 100%;
    overflow: hidden;
    margin: 0px;
    #leftbar {
    background-color: aqua;
    float:left;
    width: 18%; /**combined width and padding = 22%**/
    padding:2%;
    #middlebar {
    background-color: white;
    float:left;
    width: 52%; /**combined width and padding = 56%**/
    padding:2%;
    #rightbar    {
    background-color: green;
    color:white;
    float:right;
    padding:2%;
    #credential {
    clear:both;
    display:block;
    background-color: gold;
    width: 100%;
    padding:2%
    #footer {
    background-color: maroon;
    width: 100%;
    color:white;
    padding:2%;
    </style>
    </head>
    <body>
    <div id="header">
    #header
    <ul id="MenuBar1" class="MenuBarHorizontal">
    <li><a class="MenuBarItemSubmenu" href="#">Item 1</a>
    <ul>
    <li><a href="#">Item 1.1</a></li>
    <li><a href="#">Item 1.2</a></li>
    <li><a href="#">Item 1.3</a></li>
    </ul>
    </li>
    <li><a href="#">Item 2</a></li>
    <li><a class="MenuBarItemSubmenu" href="#">Item 3</a>
    <ul>
    <li><a class="MenuBarItemSubmenu" href="#">Item 3.1</a>
    <ul>
    <li><a href="#">Item 3.1.1</a></li>
    <li><a href="#">Item 3.1.2</a></li>
    </ul>
    </li>
    <li><a href="#">Item 3.2</a></li>
    <li><a href="#">Item 3.3</a></li>
    </ul>
    </li>
    <li><a href="#">Item 4</a></li>
    </ul>
    <!--END #HEADER--></div>
    <div id="leftbar">#leftbar</div>
    <div id="middlebar">#middlebar</div>
    <div id="rightbar">#rightbar</div>
    <div id="credential">#credential</div>
    <div id="footer">#footer</div>
    </body>
    </html>
    Nancy O.
