Footnotes
Sep 26, 2012 6:17 AM
Hi Everyone,
I have a Word file where the endnotes start from 30. When I place this file into Indesign, ID renumbers the endnotes from 1. Is there a way to make Indesign start the notes at 30 like the Word file?
Appreciate any help.
    Sep 26, 2012 7:38 AM   in reply to gwhPoster
    You need to make it a new section. Then in the Footnote Numbering (Type>Document Footnote Options) choose the starting number.
    Sep 26, 2012 9:01 AM   in reply to gwhPoster
    Are the note markers in the body of the text correctly numbered?
    I've never had to deal with end notes from word, but if memory serves they just get placed as an ordinary story or as text tacked on to the end of the main story. Does ID format them as a numbered list? If so you should be able to selct the start number from the numbered list options. If not, I suppose you could use Find/Chnage to remove the plain text numbering and convert to a numbered list style.
    Sep 26, 2012 9:22 AM   in reply to gwhPoster
    No, no. You misunderstood.
    The numbered list only applies to the notes themselves, not the markers in the running text. As I said, I've never dealt with this situation, so I'm spitballing. Do the markers change if you go into the footnote options and change the start number? If not, I think it's probably scriptable to loop through the doc and find superscripts and replace them with new numbers starting at 30.
    Sep 26, 2012 5:38 PM   in reply to gwhPoster
    I don't know that there is a script already, so yes, you should ask in the scripting forum. Explain trhe whole thing, or put a link to this thread.
    Sep 26, 2012 7:00 PM   in reply to gwhPoster
    For footnote and endnote issues, the first place I look is Peter Kahrel's site.  It looks as though his note on managing cross-references for his system for adding Dynamic Endnotes to IDCS4 and later may fit your needs.
    David
