This question was posted in response to the following article: http://help.adobe.com/en_US/ColdFusion/9.0/Developing/WSc3ff6d0ea77859461172e0811cbec22c24-7a0a.html
I think the line:
{mygrid.id@none}"onSuccess="ColdFusion.Grid.refresh('mygrid', true)">
is missing a ")' and a comma. I think the line should read:
{mygrid.id@none})",onSuccess="ColdFusion.Grid.refresh('mygrid', true)">.
In Support for CFCs outside webroot it states:
In addition to accessing CFCs using relative or absolute path, you can also use any of the following methods to access CFCs:
logical mappings (defined in the ColdFusion Administrator)
Yet when I try that I get the error:
The path to the CFC must be specified as a full path, or as a relative path from the current template, without the use of mappings.
My version of CF from the Administrator page is:
Version 9,0,1,274733
What am I missing?
I've been having this same problem. Not sure how I fixed it, but try A) to make sure the mapping is in CF Admin; B) the folder and file have at least read and execute permissions for the account logging on to run CF; and 3) that you are using forward slashes as folder delimiters (ie, "/mapped/path/to/file.cfm").
^_^
I ran out of query string allowed length. it says: HTTP Error 404.15 - Not Found
The request filtering module is configured to deny a request where the query string is too long.
Is there a way to bind cfc with HTTP form post method??
