Image conversion settings
Apr 18, 2012 Apr 18, 2012
This question was posted in response to the following article: http://help.adobe.com/en_US/robohelp/robohtml/WS58A8F266-0345-4a92-AE66-24F1832E8C6F.html
2.5K
Apr 19, 2012 Apr 19, 2012
Thanks, everyone.
I have made the changes in the Image conversion settings topic (the changes will be available in the next web update).
Here's the two options and their description:
Use Distiller to generate image
Select this option to generate web-friendly image formats from graphics linked and inserted in FrameMaker documents. You should use this option especially if you have vector graphics formats, such as EPS or AI, or graphics with text content in them.
Do not regenerate images
Select this opt
I have a couple of questions. First, I cannot find "Use PDF to Generate Image" in the image conversion settings - I think it should be "Use Distiller to Generate Image".
Additionally I see "Do Not Regenerate Images" option whic is not described in the topic - how does it work? If I select both "Use Distiller to Generate Image" and "Do not Regenerate Images" - what happens?
Hi there and welcome to our community
Silly question here. Are you using Adobe RoboHelp? If so, then you need to provide more detail about exactly what you are doing and how you are getting to these settings.
If not, you have posted to the wrong place and we need to figure out where exactly you need to be in order to get better help. If you aren't using RoboHelp, please advise us on exactly which of the Adobe products you are using.
Cheers... Rick
They're in the right place - just the wrong thread - this has to do with the conversion settings for FrameMaker docs, Rick.
Hmmm, as I read it I could see where there could be a multitude of applications that were being talked about.
Should I move this to the Framemaker Integration category?
Cheers... Rick
yes, it's one of those Community Help comments - the system knows it's the RH help, but doesn't know the "right" place to put it on the forum.
Hi Jeff
Indeed I did see that and I'm very well aware of how and why these posts end up here. (I'm also a Community Help moderator)
My point, however, is that we constantly see folks end up in the totally wrong place. For example, they could have been using InDesign, searched the Adobe site and arrived at Community Help and found some obscure RoboHelp topic that mentions a PDF setting and mistakenly assumed that by asking the question in that topic that it was the right place to be. Hence my reason for questioning the product they were actually using.
Cheers... Rick
I kind of got the impression that the OP had fired up their help and fired off a question about what they were seeing and what the help file said. I haven't bothered to put any screenshots in my FM source files, so I can't really help the OP in their question about what the other field does.
That's the old language - help text hasn't been updated - see http://blogs.adobe.com/techcomm/2011/06/troubleshooting-framemaker-content-conversion-in-robohelp-%e2%80%93-part-2images.html
Thanks, everyone.
Select this option to save time if you are re-importing FrameMaker documents and don’t need to update the images in the imported content.
Oct 02, 2012 Oct 02, 2012
Nandini, thank you very much for your explnations!
Apr 17, 2013 Apr 17, 2013
Hi Peter
We converted large doc set from Fram 9 to RH 9, with the only image setting "Do Not Regenerate Images". All of our images were resized, we now have 10,000 useless images. Any idea why these were resized? Or better, any fix? Its a big mess.
Hi DD,
You may have better luck using FM10 with RH9, or using FM9 with RH8, as the products are historically off by 1 rev # since the introduction of TCS.
I have the best luck with eliminating both the Use Distiller and the Do Not Regen options during conversion. Have you tried this yourself yet?
-Matt
Matt R. Sullivan
co-author Publishing Fundamentals: Unstructured FrameMaker 11
P: 714.798.7596 | C: 714.585.2335 | matt@mattrsullivan.com
@mattrsullivan LinkedIn facebook mattrsullivan.com
So have you seen this image reduction issue?
Apr 18, 2013 Apr 18, 2013
no, not personally, though someone was mentioning last week that the 1st image in their book was resizing. Are you using the grouping or folder features within your book? I had a thought that these features might have contributed somehow. Just a guess tho.
-Matt
Aug 28, 2013 Aug 28, 2013
I've asked this elsewhere too, but I thought it worth attaching this to the actual Online Help page: where it says "Use Distiller To Generate ImageSelect this option to generate web-friendly image formats from graphics linked and inserted in FrameMaker documents. You should use this option especially if you have vector graphics formats, such as EPS or AI, or graphics with text content in them." - how do you specify the Job Options used by Distiller in this circumstance?
RoboHelp Documentation
Download Adobe RoboHelp
