I just reinstalled Photoshop CS6. I'm running OS X 10.8.2 .
I use the Nik plugins suite, and reinstalled them as well. Now whenever I try to use one of those plugins I get the error "Could not complete the ... command because of a problem with the filter module interface."
The reinstallation was a bit of a struggle due to issues on Adobe's end, and I am hesitatnt to just dive in and reinstall without wome idea as to what might cause these errors.
Any insight appreciated.
Stu
Not sure I know what you mean by "disabling the Nik filter folder".
I have the latest updates for the Nik filters and they are compatible with CS6.
Since yesterday I tried uninstalling the Nik filters, manually locating and removing every file related to Nik/Nik Software, redownloading the Nik installers, uninstalling/reinstalling Photoshop, and reinstalling the Nik filters. Same result.
I am pretty sure this is something on the Photoshop end, but am not sure what to do next. Maybe repeat the above and use the Creative Suite cleaner before reinstalling?
Stu
Thoughtful and helpful answer, Chris, thanks for that.
If it is a bug in the Nik plugins why did they work perfectly before I had to uninstall/reinstall Photoshop? In addition, the error message fails two of the three tests of a good UI element: while it is clear why I care, it is not clear what (specifically) the error means and what I should do to remedy it.
I don't know, since I don't know the nature of the bug in Nik's code.
They have had problems in the past due to just small OS updates.
The error message tells you what happened (an error in the plugin interface), as much as is known - and Photoshop doesn't know what the specific error was in the plugin, so has no idea how to tell you to fix it.
A plug-in can choose to put up its own error messages programmatically, and make them as verbose as it likes, but it generally gets to provide only limited information back to Photoshop. I believe the message you're seeing occurs due to the plug-in returning code "paramErr" back to Photoshop.
-Noel
