Need the Medial for these two products:
Adobe Acrobat 9 Pro - Volume License
Adobe Acrobat 10 Standard - Volume license
I have the key for both. All is legal, however, for some crazy reason Adobe does not allow download of previous versions of its products.
I need a link to download or a copy of ISO if anyone has it.
Willing to pay for DVD cost and shipping if needed.
Thank you,
Please send response to [emaill adress removed by host]
Glad to help Sharon!
FYI everyone else on this thread - After confirming Sharon's volume licenses within the Licensing system (for our volume license customers), I enabled ESDs for Acrobat 9 Pro and Acrobat X Std.
-David
Hi Sharon,
You can download Acrobat 9 Professional and Acrobat X Standard from the following links.
Please follow the steps as mentioned below as the download links would only work fom the page specified.
The workflow is :
1. Login to www.adobe.com with your adobe id and password
2. Navigate to the page : https://www.adobe.com/cfusion/tdrc/index.cfm?product=contribute&loc=en _us
3. Copy and paste the links one at a time on the address bar and hit enter :
Adobe Acrobat 9 Pro English Windows
http://trials2.adobe.com/Applications/Acrobat/APEX/9/APEX9_Win_WEB_WWEFG.7z
http://trials2.adobe.com/Applications/Acrobat/APEX/9/APEX9_Win_WEB_WWEFG.exe
For Adobe Acrobat X Pro English Windows
http://trials3.adobe.com/AdobeProducts/APRO/10/win32/AcrobatPro_10_Web_WWEFD.7z
http://trials3.adobe.com/AdobeProducts/APRO/10/win32/AcrobatPro_10_Web_WWEFD.exe
4. Save the files.
5. After both the files have been saved, run the .exe file.
Note : If you enter your serial key for Acrobat X Standard into the product download for Acrobat X Pro above, you should get the Standard version and (subset) features.
Please revert in case of any issues.
Ravi
It gets me to a location to download:
Download a free trial of Contribute 6.5
Thank you,
Sharon Jahanfard
[signature deleted by host]
Hi Sharon,
Please follow my instructions carefully mentioned above.(Seems you stuck at Step 2 and did not look further :-))
Though its the Contribute download page but you have to copy the respective links of Acrobat and paste it on the browser address bar and hit enter and save the files.
Ravi.
I did get a small download file the prompted me to run, but it immediately generated an error that not all files are present.
Thank you,
Sharon Jahanfard
[email signature deleted by host]
Hi Sharon,
Request you to please follow my instructions carefully mentioned above.
In step 4 I did mention to save both the files not to run the file.
If you run any .exe file, it would give the error that all files are not present.
Save both the files with .7z and .exe extension at the same location.
.7z is the compressed folder containing the installation files and folders and .exe file is the extractor.
So download and save both the files and then run the .exe, that would initiate the installation.
Ravi.
I finally managed to download it, thanks for your patience (I wonder why they don’t provide an FTP link…). However, please note the following:
- My adobe 9 Volume License key was not accepted – “invalid Serial” – This serial was provided by Adobe customer service and it is under one of the cases in my account
- Adobe 10 Pro download did accept my Acrobat 10 Pro Key, but did not accept my Adobe 10 standard key
By the way, FYI the version 10 download 7z file was not found but the exe was a full extractable file.
Thank you,
Hi Sharon,
The installer for Retail version and Volume license is different for Acrobat 9. You cannot serialize a retail version Acrobat 9 with Volume license serial number and vice versa.
The download link given above for Acrobat 9 Pro is for retail version.
However, it works for Acrobat X. If you have purchased download version of Acrobat 9 Pro then you can login to your Volume licensing account and download it. Try the steps below,
1. Log in to your account at http://www.licensing.adobe.com.
2. On the main page, from the menu on the left, under Licenses, click Download Software.
3. If you are a contact on multiple accounts, you may need to select the relevant end user/deploy-to ID from the menu at the top of the page. Otherwise, all your available downloads appear automatically. If you have a lot of downloads, you can add a filter to help you locate the right product.
4. Click the product name to view download details.
5. You have two options for downloading your software: Download and Download Manager.
Premjit
That is what I am trying to explain to you and your team all along.
I have purchased Adobe Acrobat Pro VERSION X Volume License.
I needed to downgrade my license because of a proprietary software that has not been updated to work with Version 10.
The reason I purchased a Volume license its because I am allowed to downgrade my license.
I DO NOT HAVE THE MEDIA FOR VERSION 9.
I NEED to download VERSION 9 Professional – VOLUME LICENSE!!!!
Thank you,
I have a similar issue. I have a license key. My laptop was wiped clean and need to reinstall Adobe Standard X but cannot find a link that works. I followed Sharon's instruction but got nowhere.
If you purchased the volume license for Acrobat through Adobe, you should be able to download the software via the Licensing Portal: https://licensing.adobe.com
If you purchased the volume license through a reseller, they should be able to provide you with the media (disc or download) that you're looking for.
-David
If it was that easy I would not have created this post.
The downloads are not available at https://licensing.adobe.com
Thank you,
Sharon Jahanfard
[signature removed by host]
Hi Sharon,
I believe I've been able to make the changes necessary. Could you try logging into the Licensing website again?
Let me know!
-David
Thanks, you have been able to do something that no one could.
I really appreciate it.
Thank you,
Sharon Jahanfard
-David
I have same problem as Sharon.
What do I do?
In my Adobe's download page only appears XI version to download.
I need the Acrobat 9 Pro - LICENSE VOLUME!
Thank you,
Rosangela Braga.
I have followed these directions and it's not working.
I paid for Acrobat 9 Pro while I was a volunteer at a non-profit that had volume licensing.
My email address is apparently not the one that allows me to use the volume licensing site to download media.
My serial # is not being accepted.
Adobe seems to think it's OK to require paying customers to use chat and then jump through multiple hoops to get what we paid for.
I am frustrated with this process and will not be purchasing licenses from Adobe again.
I DO however want to install the software I paid for.
Please advise?
Hi David,
we have the same issue and we cannot use our license for acrobat pro9 on the downloaded versions (from the links posted above).
It seems that you have resolved Sharon's problem, could ou please help with our's as well.
Thanks in advance
This doesn't appear to work anymore. I followed the steps to the T, logged in, navigated to cold fusion demo download then manually copied over links for Acrobat downloads. Only to receive an "Access Denied" error message from those download URLs. This is a disappointing experience handling the nightmare of reinstalling a product that I paid a decent amount of money for. Adobe's customer support for these products has been horrible at best (and it looks like others are having the same experience).
I don't think you inherit the right to reinstall a volume license as an individual. The license remains with the original licensee and you continue to use it only at their discretion. At least, that seems to be how it is: indeed, organisations who have resold volume licenses have found the whole lot blocked. You would absolutely need the volume install media, and you'll probably need help from the original organisation. Adobe don't support sub-licensees of volume licenes.
