I'm using FMS 4.0. I'm trying to use the Remote SharedObject, which I've I used in the past, but nothing seems to work. Even the most simple example doesn't work. No events are triggered on the SO instance (no NetStatusEvent or SyncEvent). No exceptions, no nothing.
import flash.net.NetConnection;
import flash.net.SharedObject;
import flash.events.NetStatusEvent;
import flash.events.AsyncErrorEvent;
import flash.events.SyncEvent;
import flash.utils.Timer;
import flash.events.TimerEvent;
var nc:NetConnection = new NetConnection();
var so:SharedObject;
var url:String = "rtmp://127.0.0.1/live";
var tm:Timer = new Timer(1000);
nc.client = {};
nc.addEventListener(NetStatusEvent.NET_STATUS, function(event:NetStatusEvent):void {
trace("nc netstatus event", event.info.code);
if (event.info.code !== "NetConnection.Connect.Success") {
return;
so = SharedObject.getRemote("settings", nc.uri, true);
so.client = {};
so.addEventListener(AsyncErrorEvent.ASYNC_ERROR, trace);
so.addEventListener(NetStatusEvent.NET_STATUS, function(event:NetStatusEvent):void {
trace("so netstatus event", event.info.code);
so.addEventListener(SyncEvent.SYNC, function(event:SyncEvent):void {
trace("so synced");
trace("time", so.data.time);
so.connect(nc);
tm.start();
tm.addEventListener(TimerEvent.TIMER, function(event:TimerEvent):void {
trace("tick");
so.setProperty("time", new Date().toString());
nc.connect(url);
I'm using the Developer license, so SharedObjects should work.
Use an app other than live and vod. It seems signed apps do not allow shared object creation.
However if you need to use the live service functionality and shared objects together, you can user the main.asc script available in samples instead of the far file.
