Is it possible to pull in an external rtmp link and use it as live source. Instread of using FME as the live source, I would like to re-stream another RTMP link.
I've done this with ease in another rtmp streaming server, it's been while since I've done something like this using FMS/AMS.
Thank you in advance.
This is the code I have thus far. I see this in my logs;
Connected to Akamai : NetConnection.Connect.Success
Publish??? : NetStream.Connect.Success
application.onAppStart = function(){
nc = new NetConnection();
nc.connect("rtmp://cpxxxxx.live.edgefcs.net/live/xxxxxxxxxx");
nc.onStatus = function(infonc){
if(info.code == "NetConnection.Connect.Success"){
trace("Connected to Akamai : " + infonc.code);
ns = new NetStream(nc);
ns.setBufferTime(1);
ns.attach("mylivestream");
ns.publish("mylivestream", "live");
ns.onStatus = function(infons){
trace("\nPublish??? : " + infons.code);
if(info.code == "NetStream.Publish.Start"){
trace("\nPublished : " + infons.code);
I also have application.onConnect for the client and see my client connect, but nothing plays.
Yet another update.
I have enabled IDENT on my AMS server, allowing me to use the Akamai flash test page.
When the client connects I see in my server application log:
Sending error message: Method not found (getStreamLength).
Also the client reports ERROR STREAM NOT FOUND.
Which allows me to confirm the publish of the stream is not working.
Any guidancewould be great, thanks.
Hey Adrian,
You need to use the Stream.play() method in order to play a live stream on server.
This method accepts the remote NetConnection apart from the stream name.
SSAS will look something like this,
application.myRemoteConn = new NetConnection();
application.myRemoteConn.onStatus = function(info)
if (info.code == "NetConnection.Connect.Success")
application.myStream = Stream.get("foo");
if (application.myStream)
//play the stream from remote server once connection is successful
application.myStream.play("Movie1", 0, -1, true, application.myRemoteConn);
//connect to remote server where stream is already published
application.myRemoteConn.connect(rtmp://movie.com/movieApp);
If successful, this is like a client (e.g. FMLE) publishing a live stream to the server.
Once this is done, you then need to use the NetStream object on server (similar to the code snippet that you provided in comment above) to attach to that live stream and start publishing to another remote server.
Thank you very much, I shall try it.
I don't want to publish it to another server, this is my desired work flow
Has to be all within SSAS.
1) connect to akamai
2) pull in stream from akamai
3) make stream available on the same fms server that pulled in the Akamai stream.
Is this possible? I managed to do it in 30 minutes on WOWZA. I am on my second day so far with AMS.
In that case you can skip the suggestion related to NetStream.
Only the first step is required for your solution.
Isn't the script shared by Vijay working for you. This does the same
1. Create a netConnection. Connect to remote net connection.
2. Create a local stream foo.
3. Play a remote stream "movie1" into foo. That means foo is getting data from remote stream Movie1.
Let us know, if this doesn't work..
Yes, after reading up more on publish, I do not need it, thanks for the guidence.
This is my new code. I can only get it to load if I wrap the server I am connecting to in quotes, like this "remoteservername".
trace("Starting Live Service...");
nc.connect("rtmp://REMOTESERVERNAME/live");
nc.onStatus = function(info){
trace("Connection to remote server status " + info.code + "\n");
mystream = Stream.get("foo");
mystream.play("REMOTESTREAMNAME@NUMBERS", 0, -1, true, nc);
When I connect I get the message: stream name "foo" was not found on the server. I think I am very very close. Thanks again for the help.
I have added some debugging traces, here is what I get.
myStream: NetStream.Publish.Start
myStream: NetStream.Play.Reset
myStream: NetStream.Play.StreamNotFound
myStream: NetStream.Play.Stop
I know the live stream I am pulling is good, as it works within the Akamai support flash test page. Stuck again
My bad…I suggested and you wrote the script with mystream.play("REMOTESTREAMNAME@NUMBERS", 0, -1, true, nc);
It should actually be mystream.play("REMOTESTREAMNAME@NUMBERS", -1, -1, true, nc);
With starttime as zero, it will look for a VOD stream. Instead use -1 to play a live stream.
Hope it works this time.
Thats ok. I am sure I checked it aswell.
Many thanks for the update.
myStream: NetStream.Play.Start
myStream: NetStream.Play.PublishNotify
Looks better, however I can still not connect to rtmp://myFMSSERVER/myAPP/foo
UPDATE: my appname has to be live, same as the remote server I am pulling from.
Try this and let me know what do you see,
http://www.osmf.org/dev/2.0gm/debug.html?src=rtmp:///foo
Thanks. My server is not hosted locally,so I just updated the source.
Akamai test player works, however our one does not and my solution has to fit.
Server Console
Unloaded application instance live/_definst_
netconnect status: NetConnection.Connect.Success
Sending error message: Method not found (onBWDone).
Sending error message: Method not found (onFCSubscribe).
Accepted a connection from IP:x.x.x.x, referrer: http://x.x.x/x.swf, pageurl: http://x.x.x/x
Sending error message: Method not found (FCSubscribe).
Wireshark dump
fmsVer...FMS/5,0,1,1076..capabilities.@o........mode.?.............level...status..code...NetConnection.Connect.Success..description...Connection succeeded...objectEncoding...........data.......version..
5,0,1,1076......B.....
..............a...........createStream.@........C.....g....FCSubscribe............Lfoo..............._result.@.........?.............y........onStatus.............level...error..code...NetConnection.Call.Failed..description...Method not found (FCSubscribe)
My asc is copied from samples/live with the changes to pull in an external source. I know I'm freaking close.
Thanks once again for your help.
Seems you are using an OSMF based player.
Please check out these forum posts on OSMF. They had the same problem like yours. You might get some help here.
http://forums.adobe.com/message/4236547
http://forums.adobe.com/thread/749212
http://forums.adobe.com/thread/967854
Thanks, I have already looked at this and am completely lost.
http://www.therealtimeweb.com/index.cfm/2011/12/20/fcsubscribe-with-osmf
Regarding this code, where do I put it?
I have finally figured it out and its all working correctly, thank you for the guidence.
Hi Adrian,
We have same requirment, something like this.
1. FMLE is streaming to AMS1.
2. Need to feed same FMLE stream to AMS2, AMS3.
3. finall we will have same streaming getting pulled/pushed to all AMS in my cluster.
Can you help me to do this? seems this was your requirment.
you are pulling stream from Akamai and feeding same to server where you are running you NetConnect().
SJ
This is possible using multipoint publishing mechanism provided by Adobe.
