When attempting to create CHM for a large RoboHelp 10 project, the process fails with the following error:
HHA Version 4.74.8702
htmlproc.cpp(114) : Assertion failure: (pszTmp == m_pCompiler->m_pHtmlMem->psz)
There are 2400 topics in the project. Some 'out of memory' errors have recently been displayed when working on the project. I have followed some basic advice which I have found on the forums to change the path for the output file. I have also created a new Single Source Layout, and tried a variety of settings within the HTML Help Options dialog, with no success. I would really appreciate some advice. Thanks very much.
Try HHA Version 4.74.8702 in Google.
Here's one result that may apply.
http://stackoverflow.com/questions/124206/html-help-workshop-crashes-on-compiling-a-chm
Thanks for the advice. I followed the sugestions to move the project to a directory closer to the root drive, as well to use smaller folder names, but no luck getting Microsoft HTML help to compile.
So what's the path name now?
You may also want to ensure there are no spaces in the CHM file name. Also are you merging CHMs together?
Thanks very much for your replies. The path is C:\CHM for SS. There are also no spaces in the fil name. The problem was resolved by a colleague this morning - it turns out that this problem occurred using the previous RoboHelp version (Version 5), which prompted them to write a script to fix an issue with the index. After running the script, I managed to create the CHM without any problems. I don't know exactly what the script does, I'm afraid.
Best wishes,
Mark
Hi, this script you mentioned is from Adobe? You know how to find it?
Thank you.
Hi, sorry for not getting back to you earlier. The script was written in-house so I'm afraid is not freely available. Best wishes, D
When generating a .CHM file, I get a "There is not enough memory available for this task. Quick one or more programs to increase the available memory, and then try again" message. Any suggestions?
Lisa
Errrr......maybe do as the message suggests? Quit some of the open applications and try again.
Hi there
These out of memory messages are often red herrings.
I think I'd first determine if it's project specific. Try creating a new project. Compile a CHM. Did it work? If so, that tells you that RoboHelp and your computer is working okay. If not, there is something to address with RoboHelp. Perhaps reinstalling.
Assuming you have proven RoboHelp to be okay, you now focus on the project. Work with a backup copy. Delete half the topics and see if things work. If not, delete half of what's left. Rinse and repeat until you find the culprit. Likely you will find it is a single topic causing the problem.
Cheers... Rick
Thanks, I will play around with it today. I notice I have two new folders: !chm_tmp_folder_0 and !chm_tmp_folder_1. I've never seen these before. Is this a clue as to what the problem is?
Lisa
Hi Lisa
I believe that during the compilation process a temp folder is created and then removed after the process successfully ends. Because the compilation is failing, it sounds like the temp folders aren't being removed.
Cheers... Rick
Is there a quick fix to this?
Unfortunately not. Detective work has to be done. Have you tried what I suggested earlier? If so, what were the results?
Cheers... Rick
Thanks for your help, Rick. It turns out I had an unwanted Index keywords. I renamed the .hhk file and things work fine now.
~Lisa
