I have installed CF 8.0.1 in my machine and I want to upgrade it to CF 9 because it is the version required by our software. Any ideas is greatly appreciated.
Thanks in advance!
Don't upgrade to CF 9; upgrade to CF 9.0.2. It is the best CF 9 build, containing all the upgrades and hotfixes and consisting of just one installation.
Unless you're using Verity. The chief difference between 9.0.1 and 9.0.2 is that Verity was (mostly) removed. If using Verity, go to 9.0.1, and start planning to migrate your search collections from Verity to Solr, because Verity ain't there after 9.0.1.
Adam
Indeed. Thanks for that, Adam.
I wouldn't attempt an "upgrade", I'd install 9.0.1 in parallel, and duplicate your site on the CF9 server and fully regression & load test it. Then once it's tested OK, switch over to the CF9 server, leave the CF8 server there in place for a while, then once the CF9 version has proven itself in a live environment, switch off the CF8 version.
Adam
Solid advice for an existing CF 8 live site. However, the way I read it, Chiemen06 is currently in a development environment.
If so, then I'd say onwards to 9.0.2! There is no need for him to linger about with 9.0.1, unless he is using Verity. Even then, if I remember correctly, there is always the option to migrate collections from Verity to Solr in CF 9.0.2.
Verity is gone from 9.0.2, so I would be surprised if there was. I see no reference to Verity or migration in 9.0.2's CFAdmin.
Adam
You see it right. There is no Verity in 9.0.2. I should point out that, when I mention migration of Verity to 9.0.2 or indeed 10, I mean Verity-migrated-to-Solr. I did come across a Verity-to-Solr tool some months ago. I'll go verify and report back.
They were there in previous versions of CF. But by the time you're on 9.0.2, it's too late.
Adam
Thank you all for the reply. I did Adam's suggestion. It worked and I was able to migrate my datasources and mappings. The problem I have now is when I updated it to 9.0.1 , I got a blank white screen for my CF Admin. Looking at the application log, this is the error:
"Object Instantiation Exception.Class not found: coldfusion.security.ESAPIUtils The specific sequence of files included or processed is: C:\ColdFusion9\wwwroot\WEB-INF\exception\coldfusion\runtime\Expressio nException.cfm, line: 12 "
Thank you all for the reply. I did Adam's suggestion. [...]The problem I have now is when I updated it to 9.0.1
Hang on... exactly what process did you perform?
I specifically said don't *UPDATE*. I said this:
So just to verify... you did not "upgrade" anything, right? You installed CF9 in addition to your existing CF8, and your use of the word "update" was misleading. Right?
Adam
I'm sorry for the confusion. I shut off CF8 then I installed CF9. Migrated my CF8 datasources and mappings. When I think that evertyhing is good, I ran ColdFusion_update_901_WWEJ_win.exe because I need CF version 9.0.1. After the 9.0.1 update, I encountered the error I mentioned.
That is what I guessed. If you can shut off your CF8 site, it suggests your site doesn't have the usual always-on urgency of a production site. I am also assuming that you, like most developers, don't use Verity. You can therefore afford to go straight to 9.0.2, which involves just one installation.
If you decide to go instead to 9.0.1, be aware that the errors you've just received are only the beginning. There is a plethora of hot fixes you have to install before you get settled with 9.0.1.
Yes.
There's this: http://helpx.adobe.com/coldfusion/kb/cumulative-hot-fix-2-coldfusion-1.html
And even that has the caveat "only install it if you're experiencing any of the problems specifically listed as being fixed". hardly arduous.
That's the only patch for 9.0.1 I can find.
But, yes, if Verity is not a consideration, I'd've gone straight to 9.0.2.
Adam
There's this: http://helpx.adobe.com/coldfusion/kb/cumulative-hot-fix-2-coldfusion-1 .html
There was also the CF9.0.1 Security Hotfix, of course. All in all a total tally of more than 100 folders and 2000 files to be installed, some of them duplicates.
It was quite a headache to install. No wonder CF9.0.2 came along.
That's included in the one I linked to.
Eh? It's not like one needs to copy the files individually! The install process was to unzip a file, upload a JAR file, then copy some files (CFIDE 7 WEB-INF updates). Not arduous.
CF9.0.2 came along due to a legal requirement to remove Verity. That was the only reason it came along. There were a coupla other trivial things that were fixed, but the raison d'etre of 9.0.2 was to get rid of Verity.
Adam
I think one cannot separate the removal of Verity from the rest of the changes. As the release notes say "... ColdFusion 9.0 Update 2 is a full installer. ...ColdFusion 9.0.2 update is a summation of ColdFusion 9.0.1, ColdFusion 9.0.1 Cumulative HotFixes 1 & 2, all ColdFusion 9.0.1 Security HotFixes, but without Verity.". I consider bundling all the fixes in one installer non-trivial. We can leave it at a difference of opinion.
The problem I encountered had more to do with duplication. You've already mentioned one. The link you gave leads to the 2 downloads CF901 and CFIDE_901. CF901 is indeed identical to the security hot fix my link points to. However, it takes some searching to sus that out from the documentation.
If you had already installed the fix my link points to, you only had to install CFIDE_901. My software configuration checker told me that that meant overwriting many files in CFIDE, that originated from the CF901 fix, with versions that had different file sizes and date-last-modified.
CF9.0.2 installer is much easier than CF9 + updater + CHF JAR then manual unZIP steps and you get a more recent Java (1.6.0_29 versa 1.6.0_17).
Cheers, Carl.
Did you google the error?
I did. There's a bunch of matches, but Charlie's one is probably gonna be the best: http://www.carehart.org/blog/client/index.cfm/2011/10/21/why_chfs_may_break
(I didn't read it, cos I don't have the requisite month to spare to wade through it all ;-).
Adam
Yes, I did. But I did not find the solution there. I have not yet installed any 9.0.1 hot fixes and I have checked and verified that my CFIDE location is correct when I did the update.
It's only in the staging server because I will be doing the same process to our prod server.
We are also using Verity in some of our apps.
OK, well I'd perhaps deinstall CF9 altogher and try again. This time:
How are you migrating the config, btw? I'm assuming you're using the archive / deploy facility? Perhaps archive each section of the settings into separate CAR files (eg: settings, DSNs, collections, etc all as separate files)
Doing a reinstall might seem like throwing the baby out with the bath water, but it's sometimes quicker than working out what the problem is (which often yields to a reinstall anyhow). It's worth trying at least once before scratching your head too much.
Adam
using migration wizard
Oh right. Never used it (and only vaguely aware of it existing). So I can't say whether there's any risks there or not, sorry.
Adam
