Color issues in Mountain Lion with Acrobat Pro
Sep 01, 2012 Sep 01, 2012
I'm not sure I'm in the right forum, but here it goes.
Since upgrading my OS to Mountain Lion, I've noticed  when viewing PDFs output from InDesign 5.5 that once in Acrobat Pro the colors look muted and inaccurate.  I never saw this in Snow Leopard, hence my posting.  Color in InDesign, Illustrator and Photoshop CS5.5 seem just fine, it's only when a PDF is viewed in Acrobat that I see this muted color issue.
What I'm concerned with is are these problems when viewing only, or is the PDF color range itself screwed up?  I do prepress work and am using an Eizo CG241 display, CS5.5 and Acrobat Pro 10.1.4.
Print and prepress
68.5K
replies 265 Replies 265
Sep 02, 2012 Sep 02, 2012
Choose Acrobat > Preferences > Color Management. Do the settings say Synchronized? This means the color displays is sychronized from Adobe Bridge, and match the color settings in InDesign, Illustrator and Photoshop.
Yes, Steve, everything is synchronized just fine.  But it seems after checking some of the other Web postings on different forums that this problem exists and theory has it it's a bug with either ML's Colorsync or Adobe's s/w.  Also, some are saying it's only a display problem and the real file is just fine.  Apparently Actobat is defaulting to sRGB for display even if the Color Settings are sync'd correctly.  My CS5.5 Color Settings are AdobeRGB 1998, Sheetfed Coated v2, Gamma 2.2 and Adobe Ace as the color converter and all seems fine in the CS5.5 Apps excapt this anomoly.  I filed a Bug Report to both Apple and Adobe as many others have also done.
Thanks for your response, though, I appreciate it!!
Oct 01, 2012 Oct 01, 2012
I have just run into the same problem with wrong colors in Acrobat Pro X. And in my opinion there is some bug on the Adobe side.
I‘m on a Mac and I have upgraded to CS6 and Max OS X Mountain Lion. When I export a pdf file for offsetprinting from InDesign CS6 the colors shown in Acrobat Pro X are definitely not correct. Acrobat 9 shows the same colors as ID CS6 (given the same ColorManagement settings for ID CS6, Acrobat 9 and Acrobat X). The colors in Acrobat X are too dark and too saturated.
I checked the settings via Bridge CS6 – and there is something wrong, too. Sometimes I can click „Apply“ (I‘m one a German system, so maybe there will be different labels) to synchronize and sometimes I can't. And Acrobat X sometimes says it‘s synchronized and sometimes it says it isn't. (By the way: Acrobat X crashes everytime I quit it, so maybe there is another bug, too).
For now I will trust InDesign CS6 in conjunction with Acrobat 9 (as Acrobat 9 has been absolutely fine in softproofing the colors for offsetprinting for years).
The clear conclusion is: There is something wrong with the colormanagement and/or the prepress tools in Acrobat X!
Please help and fix it.
Reinhard
Hi Reinhard,
Well, it is a mess, and there is something wrong, and to solve it for now I've gone back to my Snow Leopard disk and it's all working just fine as it did before.  Mountain Lion and/or Adobe do have a problem with this, and I sent both a Bug Report.  Hopefully they will solve it, as I'd like to be running Mountain Lion to be up to date with my OS.
I do believe that even though your PDFs look wrong, the actual file is fine.  But this doesn't help soft proofing or the glitches in the Bridge Synchronize situation.  I, too, wish I'd stayed with Acrobat 9, but as I said above I've no problems in Snow Leopard with Acrobat X or the synchronize from Bridge.  I'll stick with this plan until Adobe or Apple solve this horrid color issue.  It's a pain to say the least.  And nobody knows who to blame as yet.  Nothing new there, eh?
I'm keeping a watch on the forums and this issue, I'm hoping Adobe and Apple are, too.
Tim
Contributor ,
Oct 25, 2012 Oct 25, 2012
Yup, it's an abomination. This is a perfect example of Adobe dropping the ball that drives me crazy. Even Lion was imperfect, as Acrobat did not sync with the rest of the Creative Suite. It had to be manually set to the correct color management settings. But at least it worked. So well, in fact, that it was more trustworthy for proofing than the originating app. Now it is unusable. This is not a small thing, which makes the failure, especially the fact that it continues, all the more stunning.
Oct 26, 2012 Oct 26, 2012
Right on all counts, especially "this is not a small thing."  Even though the problem seems a viewing problem and the actual PDFs are fine, I don't like the situation one bit.  And Adobe, or Apple, or both, should be on the game to fix it.  But so far nothing has been done.  In a PDF workflow world, it's simply unacceptable they they haven't.  Same as the Pen Tool in the newer Photoshop versions.  What happened to the multicolored path lines we used to get?  Now we have a fixed light gray path that is impossible to see unless you're outlining very dark objects.  I still have Photoshop CS3 loaded just so I can use a Pen Tool that works.
I'm curious: has anyone reported this to Adobe, or heard from an Adobe staff member about this?
I sent Bug Reports to both Adobe and Apple.  And I've seen this issue discussed in other forums, too.  Not sure if anyone is paying attention, but they sure should be.  Last time I tried to call Adobe I could never get to anyone beyond the usual CS reps.  Wish an Adobe monitor would see this thread.  And further the issue to those that can fix the dang problem.
Contributor ,
The PDF/X-1a format is so bulletproof for print jobs that viewing it in Acrobat Pro after coming from InDesign or Illustrator was the final word before sending the job off. It still is, of course, for catching things like white set to overprint in Illustrator (another infuriating dropped ball), for making sure effects have ripped correctly, for viewing color separations (especially whether any spot colors have slipped through), and so on and so forth, except now color accuracy has to be disregarded. That's the supreme irony of the whole situation. After a couple of decades getting there, Adobe finally achieves preflight nirvana, then sabotages it. Users spin their wheels posting on user forums (hoping someone from Adobe will sit up and take notice) and filing bug reports that seem like pushing the Close Door button in an elevator, all the while scrambling to see if there's some way to trick the software into doing its job. I know Adobe has a lot of chaff to sort through to find any wheat, but it has always seemed like they should have a hotline for obvious, easy-to-fix screwups in their products. And that hotline would lead to a patch in the next update, which could be a pretty quick process in their new subscription approach to pushing software out the door. (Yeah, and pigs will fly soon, too. 😉
Nov 06, 2012 Nov 06, 2012
I am really frustrated now.I accidentally noticed that Acrobat Pro XI is out now. So I installed it and hoped that the colors were right again. No, they are not. The problem persists just as it was in Acrobat Pro X: Too dark and too saturated.
I am apt to believe now the problem is on the Adobe side: I was playing a little bit around with the prepress tools in Acrobat XI and I found another bug: The "printing ink administration" (probably wrong translation, in German "Druckfarbenverwaltung"), where you can adjust the density of the printing inks has different settings for yellow (density 0.00)  compared to the correct settings in Acrobat Pro IX (density 0.160). And these incorrect settings in Acrobat X and XI cannot be adjusted – they always go back to 0.00 as soon as the setting is less than 0.5).
So: When there is an obvious incorrect color setting in the density for Acrobat X and XI – there very obviously might be an incorrect setting for the color management and the preview/softproof for pdf-files.
But still there is no solution, yet …
Hmm, I didn't know about XI, but will check it out.  This situation is not only a mess, but an unexcusable mess for a pro app in a PDF workflow world.  I'm sticking with Snow Leopard until this is sorted out.  If it ever is.  Thanks for your info and update!
Nov 15, 2012 Nov 15, 2012
hi! first... excuse my english... but because this problem is so important for me i want to share my experience. it seems that it's not an acrobat issue. there are many indications it's more a mountain lion problem. especially with two monitors (https://discussions.apple.com/thread/4170423?tstart=0) and wide garmut monitors. for me this tool is the solution: https://github.com/iccir/ColorFaker. it really works! i got back same behaviour as in lion. the side-effect, that colors in the dock icons and commands in the programs look strange, is not so important for me. but now i got back my cms... even in acrobt. give it a try.
Contributor ,
That's a thorough and clever solution, but I'm not sure it addresses the problem described in this topic, and it may introduce a new problem. I use a color managed workflow based on Adobe RGB. Files that I proof in Acrobat Pro X (10.x) have been converted to CMYK (and have the North American Prepress 2 profile). Acrobat appears to ignore the profile. Colors on screen appear relatively darker and muted than they actually are, which might indicate that Acrobat is displaying CMYK values as if they were Windows sRGB values (6500K color temp, 2.2 gamma). The same CMYK colors are displayed correctly within the originating application, such as Photoshop or InDesign. In short, the Acrobat problem has nothing to do with actual sRGB files or files missing a profile, other than apparently treating every file as Windows sRGB. The problem you describe is evident in Dock icons, which are relatively bright and oversaturated in Mountain Lion, just as one would expect when a monitor calibrated for prepress (5000K color temp, 1.8 gamma) is presented with an sRGB file that was generated for 6500K color temp and 2.2 gamma and has no color profile. It may be that Color Faker addresses that problem, but based on your description (any automatic "Convert to sRGB" or "Assign sRGB Profile" commands in applications will no longer work) it may also add a new problem by interfering with preparing profiled sRGB files for web use in Photoshop (Save for Web function). Unless Apple is somehow implicated, which may be the case, the problem in Acrobat is something that should be easy and quick for Adobe to fix. Except they haven't done it, and there is no indication they even acknowledge the problem.
I don't know why Adobe, or Apple, can't acknowledges this issue, it's not just us who have it.  Oh well, until they decide to tell the truth and get it sorted out, I am sticking with Snow Leopard.  It works, that's all I care about right now.  Mountain Lion can wait, and so will I.
Thanks for the posts, though, all the information we can get is good information!
i think you are right, that color faker will address a new problem... but this really just concerns the icons and commands in the progamm and not the pictures and files in cs6. but i have to admit, i'm not so into this matter. actually for me it's really working. i'm working with a hardware calibratet quato monitor and i have a color managed workflow based on eci rgb. files that i proof in acrobat have been converted to eci isocoated v2 and acrobat takes this profile. even if i take a screenshot of the files in photoshop, indesign and acrobt and if i verify all screenshots in photoshop... all pics have exact same color-data. BUT... of course color faker is not a final   solution and i think it's really on the side of apple or adobe to give us a really solution. but i worry that they continue playing the game "it' adobe", "it's apple", "it' adobe", "it's apple". by the way... another interesting site about os x color space conversion: http://iccir.com/articles/osx-color-conversions/
Guest
Nov 18, 2012 Nov 18, 2012
The problem is wider. Acrobat XI not only shows wrong colours but in output preview it does show wrong CMYK values - different than Acrobat 9.0. If I preview separations in InDesign, values are different than in Acrobat XI. In Acrobat 9.0 all values are correct and the same as in InDesign.
Contributor ,
Nov 20, 2012 Nov 20, 2012
I haven't checked CMYK values in InDesign CS6, as all colors I use in it are from Photoshop or Illustrator. The CMYK values reported in Acrobat X 10.1.4 Output Preview actually do match the CMYK values in Photoshop CS6 13.0. (The test: a CMYK image created in Photoshop is placed in Illustrator CS6 16.0, and a PDF/X-1a file is generated from there.) Acrobat simply displays colors incorrectly, but does not alter them. (My guess being that it treats all files as Windows sRGB, regardless of the embedded profile.) If an Adobe staffer is monitoring this topic, it sure would be nice if he or she could at least confirm that Adobe is aware of the problem.
I've gotten info from other forums that this is indeed the case, that the colors are actualy correct, it's a display problem  When I create X1a PDFs from any CS app, I don't allow any color conversions or profiles embedded as no printer I use can tell me what they want.  "Leave color unchanged" and "No profiles" seems to work, I've found the output is just fine, and I will not fix what ain't broke.  All my graphics work is pretty straightforward, it's all CMYK Process, maybe that's why my method works.  It's amazing how many printers haven't a clue when I ask about profiles and such.
"If an Adobe staffer is monitoring this topic, it sure would be nice if he or she could at least confirm that Adobe is aware of the problem."
Yes, that would be nice, wouldn't it....
Nov 30, 2012 Nov 30, 2012
Hi, everybody,
I gathered some new information that makes the whole picture even more complicated. Within the last few weeks I had some printed items come back from the print shop so I could check my whole color workflow after having upgraded to Mountain Lion and to CS6.
The results: Maybe it‘s an accident and the print shop has just printed a bit too dark. But it seems that the color preview in Acrobat X and Acrobat XI is correct now (darker colors compared to Acrobat IX). But it also means that the Adobe CS6-Suite of applications previews the wrong colors!
To make it short for Mountain Lion 10.8:
a) InDesign CS6 + Photoshop CS6 + Acrobat IX = same print output preview: but too light compared to the printed brochures
b) Acrobat X + Acrobat XI = correct print output preview: but no match with ID and PS CS6
Does anybody have similar results?
Can anybody here still figure out where the bugs are?
For me it means that I cannot at all trust my color workflow any longer!
Thanks for discussing and helping
Reinhard
This is such a mess, which is why I'm still sticking with Snow Leopard and CS5.5 as long as I can.  I have no clue if Adobe, or Apple, are working on this snafu, but they sure need to, and soon.  Not being able to trust a color workflow is NOT a good thing in prepress work.  And spending hours troubleshooting this stuff is a real pain in the butt, especially when it doesn't solve anything.  I wish I could invoice Adobe and Apple for all the time I've spent researching this rat's nest.  Mostly I'm glad I kept my Snow Leopard volume after I updated my backup OS volume to Mountain Lying.
Dec 14, 2012 Dec 14, 2012
after hesitating a long time I tried Colorfaker, the tool that aktivomat wrote about on November 15 in this thread. For me it completely worked! I have the identical colors back in all my CS6 and CS5 applications. This is incredibly helpful! Thanks to the guy who wrote this app!
I know there are some problems now with Colorfaker, too. But it can be switched back again so at least for now the process isn't irreversible and it does feel good to have a color management workflow again.
But when the problem is identified now – why is there no final solution by Adobe or Apple now? Until then I have to think twice before recaibrating my display or changing anything else in my color management settings.
Reinhard
Thanks for the update!  For now I'm staying with Snow Leopard.  That Adobe, or Apple, or whomever, hasn't fixed this issue yet is unacceptable.  This business is tough enough, and expensive enough, to not have to deal with problems like this one, especially for professional software when it's worked fine up until now.  I'd hoped Adobe would monitor these forums better, apparently they don't care, except about taking our money.  If it's Apple's fault, then Adobe should jump on their butts about it.
There, rant over, I feel better!
Enthusiast ,
Hi All,
We are investigating this issue. Though, I couldn't reproduce it in my lab but I'm in touch with some users and I have seen this odd behavior on their machines.
I'm sending you a private message to collect more information. Please 'Reply Me' so I can create similar test environment at my end. I will post the accumulated information on this thread.
~Sandeep V.
Contributor ,
Hi, Sandeep. Thank you for stepping up! My posts provide what I've determined about the problem, but I'll be happy to help anyway I can.
It sounds like this problem does not occur for some or many users, which surprises me. It suggests a configuration problem or conflict.
For you to reproduce it in your lab, you need to creating PDF files that do not use a Windows sRGB color profile. (For example, use Adobe RGB or SWOP CMYK profiles.) The problem is even more apparent if you are working at 5000K and a 1.8 gamma ("legacy" Mac, which is still the standard for print). If you can set your system to those values (and calibrate your display), that might be a good experimental base.
Rick Meikle
Meikle Communications LLC
Tigard, Oregon
Phone 503-430-8430
