Playing external sound (iOS app)
Aug 31, 2012 6:00 AM
Tags: #air #app #as3 #3.0 #ios #button #sound #action #3 #actionscript #code #as3.0 #random #ac3 #actionscript3 #ipa
Hi everyone, so I've got a problem, I am making some play btns that will play a sound when it's pressed,
I have the mp3 file in some folder that i refer to in the code:
it plays well when testing, but when i "publish" the app as an .ipa and put it in my iPhone the play button doesn't work,
and i added the folders to the app exactly as it is in the code, which is this:
Random_btn.addEventListener(MouseEvent.CLICK, playRandomSound);
var random_sound:Sound = new Sound();
random_sound.load(new URLRequest("random/randomness/randomsound.mp3"));
var my_randomchannel:SoundChannel = new SoundChannel();
function playRandomjSound(event:MouseEvent):void{
my_randomchannel = random_sound.play();
function stopSound(event:MouseEvent):void{
my_randomchannel.stop();
Any reason why it shouldn't play that i dont know?
I reapeat i added the "random" folder with the "randomness" sub folder with the "randomsound.mp3" file to the app in the AIR iOS settings..
Thanks for any responses to help
    Aug 31, 2012 9:26 AM   in reply to iden_tidad
    Try to use the File class to reference the file.
    var randFile:File = File.applicationDirectory.resolvePath("/random/randomness/randomsound .mp3");
    // exist?
    if (randFile.exists)
         random_sound.load(new URLRequest(randFile.nativePath));
         // etc
    Nov 18, 2012 10:54 PM   in reply to sinious
    Thank you very much . I had the same problem, I tested with your code and works great.
    Nov 19, 2012 7:55 AM   in reply to l_avanti
    Glad it worked for you. It's a little weird at first but soon you'll appreciate properties like .url and .nativePath. Good luck to you both!
    Jun 9, 2013 4:47 PM   in reply to sinious
    Mr Sinious
    Thanks for your time as above:
    I have:___________________________________________
    /* AIR 3.6.0.5990 for iOS Flash Pro CS6 Mac OS */
    import flash.filesystem.File;
    import flash.filesystem.FileMode;
    import flash.media.Sound;
    import flash.media.SoundChannel;
    var sFile:File = File.applicationDirectory.resolvePath("/alou/sounds/test.mp3");
    var channel:SoundChannel = new SoundChannel();
    var snd_1:Sound;
    if (sFile.exists) {
              trace('File there: ');
              snd_1 = new Sound();
              snd_1.load(URLRequest(sFile.nativePath));
    } else {
              trace('File NOT found: ');
              snd_1 = new p0spop();
    channel.stop();
    channel = snd_1.play();
    from which I get: File NOT found:
    if I move the statement:   snd_1.load(URLRequest(sFile.nativePath));
    outside the if exists, I get: TypeError: Error #1034: Type Coercion failed: cannot convert "/alou/sounds/test.mp3" to flash.net.URLRequest.
    If I add the: (new URLRequest...
    I get:  Attempted access of inaccessible method nativePath through a reference with static type flash.filesystem:File.
    I would really appreciate a hand with this as sound is a major component of my current project. Thanks
    Jun 11, 2013 7:29 AM   in reply to amandasyd
    Moving my house to another state, been busy for months, sorry for a late post.
    I presume the file is relative to the application install directory? Try simply removing the first / to make the final path: "alou/sounds/test.mp3".
    Jun 11, 2013 5:59 PM   in reply to sinious
    Happy new house, or were you actually moving the house itself...
    Thanks, I did try that  and got:
    TypeError: Error #1034: Type Coercion failed: cannot convert "/Users/sesyd/Flash/AuntLou/alou/sounds/test.mp3" to flash.net.URLRequest.
              at soundiOS_fla::MainTimeline/frame1()[soundiOS_fla.MainTimeline::frame1 :25]
    22  if (sFile.exists) {
    23       trace('File there: ');
    24       snd_1 = new Sound();
    25       snd_1.load(URLRequest(sFile.nativePath));
    So I'm guessing the file is found, but I have a different problem. Have tried different configurations for the sound, but haven't hit the right one yet.
    I'd like to be able to have either library based [or file based in one directory "/alou/sounds/test.mp3"] and if the user records or supplies a different sound file [ "/alou/altSnds/test.mp3"], play that instead of the default.
    but I need more help there as well...  (I'm writting time line based - not class etc at this stage)
    Jun 12, 2013 10:27 AM   in reply to amandasyd
    A happy move, getting out of renting to buy while the market is still so/so. You just never know how much stuff you have until you have to move alllll of it .
    You should be able to use the .url property and you want to make a new URLRequest, not type convert.
    e.g.
    snd_1.load(new URLRequest(sFile.url));
    Although .nativePath should work just fine as well. For common sense code reading I like to stick to the same spec, structure, syntax, etc. URLs in this case.
    Jun 12, 2013 3:58 PM   in reply to sinious
    Excellent thank you Sinious, worked a treat.
    We have two young boys... (5&7) have moved 9 times since 2006 inc one international. Understand and feel I understand the same syntax better. Thank you
    Jun 13, 2013 5:02 AM   in reply to amandasyd
    You're welcome and I hope you no longer ever need to move . Good luck!
