Hello,
Dowloaded Coldfusion from the Adobe website, both with Safari as with Firefox
I want to install Coldfusion 10 on my Macbook. OS X 10.7.4 ( so not 10.8 ). When I double click the
.dmg file , I always get "“Adobe ColdFusion 10” can’t be opened. You should eject the disk image." error. Never had this before. I've read about setting security on 'non signed packages', but this applies to 10.8.
Is this a known issue ?
Dirk
Hi
Please download the .dmg file from other resource or download it from other machine. Try to use that, it should work. I also faced the same issue and I went through using different installer.
Regards
Swaraj
Hello Swaraj,
Thanks for the tip. What did work for me , is upgrading to OSX 10.7.5. I was inspired by this article. http://forums.adobe.com/message/4843052#4843052
/Dirk
I have the same problem, but I am already on OSX 10.7.5.
Any ideas? I have no InDesign (CS5.5) at present, and cannot work!
I had some errors on In Design, so I though I would uninstall and reinstall. Bad idea.......
Some further background info. I first of all just reinstalled InDesign. But that did not help, and it was on a go-slow, so I thought I would do a complete uninstall-reinstall. So immediately before this problem I had already done an InDesign install without any problem. It was only after I did the uninstal, that the problem started. I tried a 'clean' as the manual suggested, but there was nothing to clean.
I will try redownloading the CS5.5 installation file again. But since it takes 3 hours to down load, I shall go to bed and try to install it in the morning.
R
Same problem here with InDesign CS5.5. Then after downloading it from adobe I get the same dialog box "Install" can't be opened. You should eject the disk image. Which turns out to be a vicious cycle.
