Photoshop Elements 11 does not install
Nov 24, 2012 Nov 24, 2012
When I install photoshop elements trail  I recieve the following error:
Exit Code: 7
Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DF027, DW063 ... WARNING: DW016, DW036 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 16 error(s), 3 warning(s)
I have already restatred and tried again a number of times and tried on a different browser. I m having similar troubles with photoshop CS6 (tried this as an alternative). Also I already turned off verifying checksum due to previous issues. Any help would be greatly appreciated.
Anna
2.4K
Adobe Employee ,
There is not enough specific information in the install log summary to advise you.  I would recommend you review your installation logs to determine the cause of your installation failure.  You can find details on how to locate and interpret the installation logs at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html.
Nov 25, 2012 Nov 25, 2012
Here is the full error
xit Code: 7
WARNING: DW016: NOTE: Cannot set action to the payload {F6F5021E-0548-43C1-82CC-C5C7A6906585} Camera Profiles Installer 7.0.0.0 as it is already upgraded by the payload {539AEF15-3A2B-4A31-A587-7E90F7D9C700} Camera Profiles Installer 7.0.0.0
----------- Payload: {FA19351D-E98C-48C1-B5E1-0C8C42B5E11C} Adobe Photoshop Elements 11 11.0.0.0 -----------
ERROR: DF027: Unable to copy file from "/private/tmp/.tempdirTtCuFpXK/Assets1/Adobe Photoshop Elements Editor.app/Contents/MacOS/Adobe Photoshop Elements Editor" to "/Applications/Adobe Photoshop Elements 11/Support Files/Adobe Photoshop Elements Editor.app/Contents/MacOS/Adobe Photoshop Elements Editor" Error 0(Seq 960)
ERROR: DW063: Command ARKCopyFileCommand failed.(Seq 960)
ERROR: DF023: Unable to delete file "/Applications/Adobe Photoshop Elements 11/Support Files/Adobe Photoshop Elements Editor.app/Contents/Info.plist". Error 0(Seq 2)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 2)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Photoshop Elements 11/Support Files/Adobe Photoshop Elements Editor.app/Contents"(Seq 2)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 2)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Photoshop Elements 11/Support Files/Adobe Photoshop Elements Editor.app"(Seq 2)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Photoshop Elements 11/Support Files"(Seq 2)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Photoshop Elements 11/Adobe Photoshop Elements 11"(Seq 1)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 1)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Photoshop Elements 11"(Seq 1)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 1)
WARNING: DW036: Payload cannot be installed due to dependent operation failure
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Adobe Photoshop Elements 11_AdobePhotoshopElements11_en_US: Install failed
ERROR: DW050:  - Adobe Photoshop Elements 11: Failed due to Language Pack installation failure
Adobe Employee ,
Nov 26, 2012 Nov 26, 2012
The DW063 error is indicating you have a permission issue with Applications/Adobe Photoshop Elements 11.  The installer is unable to write to these locations.  Please adjust the permissions for Applications/Adobe Photoshop Elements 11 and all enclosed items and then try the installation again.
I have the exact issue, with the same error messages regarding permissions.  The installer does not install an Adobe Photoshop Elements 11 folder at all (only the Organizer) and then fails.  I have restarted several times, have no other apps running.  I cannot adjust the permissions for the folder as it does not exist.
Full error message:
Exit Code: 7
- 0 fatal error(s), 17 error(s), 3 warning(s)
WARNING: DW031: Payload:{F6F5021E-0548-43C1-82CC-C5C7A6906585} Camera Profiles Installer 7.0.0.0 has been updated and has been selected for repair. The patch {0449467E-102A-4514-9F4D-91BCEE129390} Camera Profiles Installer_7.1_ElementsCameraRawProfile7.0All 7.1.0.0 will be uninstalled now.
ERROR: DF024: Unable to preserve original file at "/Library/Fonts/NuevaStd-BoldCond.otf" Error 0(Seq 1834)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 1834)
I finally got it to install by deleting the referenced font in the list above
I then restarted in Safe mode and the application finally installed.
Not sure which solved it but that worked.
Nov 27, 2012 Nov 27, 2012
Thank you for this. I tried both and I'm still having problems.
Does anyone know what the 'payload' is referring to? This was the last error when started in safe mode with the font removed. I could not find the permissions to turn them off?
Exit Code: 7
- 0 fatal error(s), 12 error(s), 11 warning(s)
----------- Payload: {64191879-379D-4ADF-9D1E-929FC71E7218} Elements 11 Organizer 11.0.0.0 -----------
ERROR: DF027: Unable to copy file from "/private/tmp/.tempdirWM8s2AjK/Assets1/application/Adobe Elements 11 Organizer.app/Contents/Required/PDFL/Fonts/AdobeHeitiStd-Regular.otf" to "/Applications/Adobe Elements 11 Organizer.app/Contents/Required/PDFL/Fonts/AdobeHeitiStd-Regular.otf" Error 0(Seq 4198)
ERROR: DW063: Command ARKCopyFileCommand failed.(Seq 4198)
ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS5: Install failed
ERROR: DW050:  - Photoshop Camera Raw for Elements 11: Install failed
ERROR: DW050:  - Elements 11 Organizer: Failed due to Language Pack installation failure
ERROR: DW050:  - Elements 11 Organizer_AdobeElements11Organizer_en_US: Install failed
ERROR: DW050:  - Adobe XMP Panels CS5: Install failed
ERROR: DW050:  - AdobeTypeSupport CS5: Install failed
ERROR: DW050:  - Adobe Linguistics CS5: Install failed
ERROR: DW050:  - AdobeCMaps CS5: Install failed
Adobe Employee ,
PollyannaStewart the DW027 error is still indicating you are facing permission issues with /Applications/Adobe Elements 11 Organizer.app/.  It appears the installer is unable to AdobeHeitiStd-Regular.otf font into the package.  Error "Exit 6" or "Exit 7" | Install log | Read, write, system file errors | CS5, CS5.5 - http://helpx.adobe.com/creative-suite/kb/error-exit-6-exit-7.html details how you can adjust your permissions.  You may want to consider adjusting permissions on the Applications folder and then clicking on the gear icon and choosing to Apply to enclosed items.
Alternately you may want to try creating a new administrator account and see if you still experience installation difficulties under that account.  It is possible that the file permissions for your current user account have become compromised which is why you are continuing to experience installation difficulties.
Got me but I see it is referring to another font/font folder early on in the error list:
I'd try deleting that font (the whole folder if it has one) and attempt it again.
Adobe Employee ,
Peg it is installing into the Elements package.  You can try deleting the folder but in order to view it you will need to right click on the Adobe Elements Organizer and select Show Package Contents.
Dec 11, 2012 Dec 11, 2012
I was having very similar issues. My issue turned out to be a corrupted installer. Originally downloated from Amazon when purchased. Kept getting 23 permission issue errors at the end of the install from items failing to be written or deleted during installation.
Finally, redownloaded the trial from Adobe's site which gives option of installing with license. This install went flawlessly.
Problem solved. I would never have guessed that the problem was the original installer.
