Learn about Edge Delivery Services in upcoming GEM session
SOLVED
Issue while configuring LiveCycle
Avatar
Former Community Member
I have windows 7 64 bit.I downloaded the Live Cycle es3 server and tried installing.Installation went fine but when i went to the document to configure i see following missing files in the installation folder.
1)
To run Configuration Manager later, deselect the Start Configuration Manager option before you click Done. You can start Configuration Manager later using the appropriate script in the [LiveCycle root]/configurationManager/bin directory.
**I dont see this files in my installation directory.
2) I dont see any folder named  [LiveCycle root]/configurationManager/export.
3) Below files were mentioned to deply it on JBOSS.. i dont see these files either.
  • adobe-livecycle-native-jboss-[OS].ear
  • adobe-livecycle-jboss.ear
  • adobe-workspace-client.ear (
Let me know if i have misunderstood the doc
regards
Pushpendra
1 Accepted Solution
Avatar
Correct answer by
You have the below line in the logs :-
Caused by: ALC-PDG-30003-000: com.adobe.pdfg.exceptions.ConfigException: ALC-PDG-030-003-User account information for user root is not valid for the machine S4FFDV2 (172.26.32.87).
This means that the username/password that you are giving is invalid. Your windows' machine administrator user is required here.
Avatar
Level 2
[Livecycle root]  is just a generic placeholder. In practice the actual location could be different on each machine.
If you did the default turnkey installation on windows you LiveCycle Root it will be something like C:\Adobe\Adobe LiveCycle ES3
so the location of your file will be ...
C:\Adobe\Adobe LiveCycle ES3\configurationManager\bin\ConfigurationManager.exe
I am guessing because I have the ADEP LiveCycle installation which is
C:\Adobe\Adep\configurationManager\bin\ConfigurationManager.exe
anyway you can go to C:\Adobe and work from there
If you are still having problems go to command line and search from ConfiguationManager.exe
C: >dir /s configurationmanager.exe  - if you don't find it the was a problem with your installation you need to re-isntall
Avatar
Thanks for the reply.I am able to locate the configurationManager.exe but when i am double clicking it to run it, the exe is not doing anything.I checked the background process but i dont see any such process (configurationManager.exe) running.
Regards
Pushpendra
Avatar
Can you try the ConfigurationManager.bat file from a command line?
Avatar
I dont see configurationManager.bat anywhere.I can only see configurationManager.exe
Avatar
If your installation was successfull, you should see the files as shown in the attached screenshot in your <LiveCycle_Install_folder>/configurationManager/bin directory.
Avatar
No, I dont see these files inside the bin folder.I have also installed the same setup on another 32 bit machine but still i dont see these files there as well.
I have downloaded the ES3 setup from the location
http://www.adobe.com/devnet/livecycle/downloads.html
1.4 GB one.
Could you please check if this is the correct, I tried installing twice on different machine but no luch wrt files.
Regards
Pushepndra
Avatar
When you open the said url, you see a screen like
When you click on the link "Download" just above where (1.4 GB) is written, it asks you for login and after you login, you see the screen as shown below :-
Have you downloaded the build that i have marked above?
Avatar
No, I think i downloaded the different one.i will download this and will try installing.
How to uninstall the existing one.
i tried running the exe .Uninstall Adobe LiveCycle ES3.exe but it is not doing anything.
I also tried uninstallaing from the Windows Programs and features but still unable to.
Can i just delete the folder.
Let me know.
Regards
Pushpendra
Avatar
Ideally you should have used the uninstaller. But, if it's not working for you then as the installation is currupt and we have no other option, you can delete the installation folder. And, then go an remove the entry from "Add/Remove Programs".
Avatar
Thanks for the help.Let me try that and i will get back to you.
Avatar
Hi Pgakhar,
Quick question, I am wondering if you could clear a doubt.
My requirement is to convert the XFA form to static pdf (flattened).
I am just wondering that in order to do this, do i need to install the complete ES3 server or any small webService installation will do this part.
Appreciate your help.
Regards
Pushpendra
Avatar
There is no light weight installation available.
After the installation, when you run LiveCycle Configuration Manager, then you can choose which components to deploy on your application server. For your use case, I think you need Forms and Output.
Avatar
Thanks pgakhar,
Now i have downloaded the new installer and it is faliing at
Failed on "Starting service JBOSS_FOR_ADOBE_LIVECYCLE_ES3".
I have checked the eventviewer but dont see and any case there.I have also verified that port 25076 is getting used beofre running the configurationManager.Exe
Let me know the log file which you want to check this issue.
I tried service the service from services.msc but JBOSS for adobe livecycle is failing there as well
Regards
Pushpendra
Avatar
This could be due to the earlier unclean uninstallation.
You can try starting JBoss server and configurationManager from command line.
For JBoss :-
cd c:\Adobe\Adobe Livecycle ES3\jboss\bin
run.bat -c lc_turnkey -b 0.0.0.0
For Configuration Manager :-
cd c:\Adobe\Adobe LiveCycle ES3\configurationManager\bin
If you are still unable to run these, please attach the c:\Adobe\Adobe Livecycle ES3\jboss\servers\lc_turnkey\log\server.log file for jboss and c:\Adobe\Adobe Livecycle ES3\configurationManager\log\lcm.0.log for Configuration Manager.
Avatar
Running run.bat is returning below
C:\Adobe\Adobe LiveCycle ES3\jboss\bin>run.bat -c lc_turnkey -b 0.0.0.0
Calling C:\Adobe\Adobe LiveCycle ES3\jboss\bin\run.conf.bat
\Java\jdk1.6.0_34\bin\java was unexpected at this time.
I dont see any
How to send the lcm.0.log ...i dont see any tab here to attach a file.In only say attach image or video.
Regards
Pushpendra
Avatar
Level 3
I believe you are using a 64 Bit Windows OS.
The error above suggests that your JAVA_HOME is incorrectly set in environment variables.
Please make sure that you are using 64 Bit Java and your environment variables are correctly set.
Sample JAVA_HOME would be : C:\Program Files\Java\jdk1.6.0_34
HTH,
Hina Rastogi
Avatar
Thanks, I have updated the jdk and now i am getting the attached error and followed by couple of other undeployed jar.
Regards
Avatar
I have just installed that same build on my windows 7 - 64 bit  machine. And, I didn't get any such issue.
Could you please try running the configuration manager in custom mode?
do the below steps :-
1.) Choose the livecycle modules that you want to install.
2.) On the task selection screen, select like below :-
if the deploy step fails to start jboss. then, do the deployment of ears manually (copy ear files form configurationManager/export directory to jboss\lc_turnkey\deploy directory, and start jboss manually).
and then, do the remaining steps in order.
Avatar
Now i am getting issue while adding the user.
Admin User credentials for Native PDF conversion dialogs box.
Log file : detailsUntitled.png
[2012-12-03 18:39:20,511], WARNING, Thread-38, com.adobe.pdfg.lcm.configure.users.AddPDFGAdminUserTask, Error while adding user to PDFG :ALC-DSC-005-000: com.adobe.idp.dsc.DSCNotSerializableException: Not Serializable
Caused by: ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error.
          at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.java:152)
          at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor.java:140)
          at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptorChainImpl.java:60)
          at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassivationInterceptor.java:53)
          at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(TransactionInterceptor.java:74)
          at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew(EjbTransactionBMTAdapterBean.java:218)
          at sun.reflect.GeneratedMethodAccessor600.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
          at java.lang.reflect.Method.invoke(Method.java:597)
          at org.jboss.invocation.Invocation.performCall(Invocation.java:386)
          at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionContainer.java:233)
          at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:156)
          at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
          at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
          at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:173)
          at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
          at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstanceInterceptor.java:173)
          at org.jboss.ejb.plugins.SecurityInterceptor.process(SecurityInterceptor.java:228)
          at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:211)
          at org.jboss.ejb.plugins.security.PreSecurityInterceptor.process(PreSecurityInterceptor.java:97)
          at org.jboss.ejb.plugins.security.PreSecurityInterceptor.invoke(PreSecurityInterceptor.java:81)
          at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
          at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor.java:138)
          at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:650)
          at org.jboss.ejb.Container.invoke(Container.java:1092)
          at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:436)
          at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
          at $Proxy269.doRequiresNew(Unknown Source)
          at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:133)
          at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInterceptor.java:72)
          at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStrategyInterceptor.java:55)
          at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateInterceptor.java:37)
          at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterceptor.java:188)
          at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
          at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
          at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:131)
          at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(AbstractMessageReceiver.java:329)
          at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invokeCall(SoapSdkEndpoint.java:139)
          at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invoke(SoapSdkEndpoint.java:81)
          at sun.reflect.GeneratedMethodAccessor612.invoke(Unknown Source)
          at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
          at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
          at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
          at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
          at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
          at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
          at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
          at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
          at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
          at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
          at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
          at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
          at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.doFilter(InvocationFilter.java:43)
          at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
          at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:86)
          at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
          at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
          at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
          at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:183)
          at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:95)
          at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
          at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
          at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
          at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
          at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
          at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
          at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
          at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
          at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
          at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:451)
          at java.lang.Thread.run(Thread.java:662)
          at com.adobe.pdfg.config.PDFGConfigServiceImpl.updateUserAccountsSettings(PDFGConfigServiceImpl.java:879)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
          at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.java:118)
          ... 85 more
          at com.adobe.idp.dsc.provider.impl.base.AbstractResponseHolder.handleException(AbstractResponseHolder.java:150)
          at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkBindingStubUtil.deSerializeResponse(SoapSdkBindingStubUtil.java:132)
          at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher.doSend(SoapAxisDispatcher.java:132)
          at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispatcher.java:66)
          at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
          at com.adobe.pdfg.lcm.configure.users.AddPDFGAdminUserTask.run(AddPDFGAdminUserTask.java:76)
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
