dkeith@psasys
CF10 64bit  Apache connector (mod_jk.so) does not work for Apache2.4.3 (windows)
Dec 3, 2012 10:08 AM
CF10 64bit  Apache connector (mod_jk.so) does not work for Apache2.4.3 (win64), where can I get a module that works?
I get this error from Apache :
C:\www\Apache2.4\bin>httpd -t
httpd: Syntax error on line 741 of C:/www/Apache2.4/conf/httpd.conf: Syntax error on line 2 of C:/www/Apache2.4/conf/mod_jk.conf: Cannot load C:\\ColdFusion10\\config\\wsconfig\\1\\mod_jk.so into server: The specified procedure could not be found.
I have already tried manually extracting the pre-built mod_jk22.so from the wsconfig.jar with same results.
If I switch to Apache 2.2.22 64bit, it does work.  what I need is to be able to run on Apache 2.4.
