I am experiencing an error when attempting to open a PowerPoint file. . Here is the full message: "powerPoint is experiencing a serious problem with PowerPoint com add in. This add-in is incompatible with Data Protection Execution Mode and should be disabled or upgraded to the latest version. Do you wish to disable?" I am using PowerPoint 2010 and Adobe Presenter version 8.
Hello,
Does this error come all the time? Can you tell us the steps you performed in Presenter 8 before you received this error.
Please let us know if there is a specific workflow after which you get this error? We would try to work with you and solve this error for you.
Mukul
Adobe Presenter Engg. Team.
It does not seem to have a pattern. It does not occur all the time. This is the first time I had this occur. One other user had this occur last week but with Presenter 6 and PowerPoint 2010. Unfortunately she hit Yes and it inactivated the Presenter add in to PowerPoint and we could not get it reactivated. I am seeing random cases of this occurring with other users. There does not seem to be a pattern. I tried to open the same file this morning, save it and do other work with and the problem did not occur.
If I get any more information today, I will do an update.
Dave
It appears that Microsoft's Data Execution Prevention software is blocking the execution of the Presenter 8 add-in. In Windows 7 control panel there is a setting to "Turn on DEP for all programs and services except those I select:" Then you need to find and select the executible for the software you want to have not scanned and potentially blocked. My issue is that I don't know the name of the presenter executible. There are loads of executables in the Adobe Presenter 8 folder under Program Files (x86). Which one do I chose to insert in this list?
Thank you, Jorma -- I actually have the most up to date Presenter files. I am going to log another case with Adobe Support with this info and see if I can get it resolved. I have to - I have a whole education program waiting to be launched, but is being held up because I cannot edit or publish my files. This has been the longest month of my life.
NWNITT49, Thanks for info - I will post back here if I have any luck.
I've continually experience the same issues. I have updated to Presenter 8.02.
If I open a project by double-clicking the .pptx file I get the following error message:
"Run-time error '-2147467259 (80004005)
SlideShowWindow (unknown member) :Invalid request. Automation rights are not granted."
If I then enter the Presenter tab and click an option (for instance "Settings") Powerpoint crashes and restarts itself. Once restarted the following error message is presented:
"PowerPoint experienced a serious problem with the 'adobe presenter powerpoint com adding' add-in. This add-in is incompatible with Data Execution Prevention mode and should be disabled or upgraded to the latest version. Do you wish to disable this add-in from loading?"
I can often crash Powerpoint with the same DEP warning by closing the presentation with the window's "X" button - Powerpoint restarts itself and gives the same DEP warning as above.
I normally choose to not disable and continue working. If I then go to "Settings" in Presenter again, it will open without problem. It seems that after four to six occurences like this, Presenter will then be disabled by Powerpoint and require resetting in the File-Options-Addins section.
Alternately, if I open Powerpoint first and then open my project through the File-Open or Recent Presentations list I do not get the Run-time error mentioned above and usually can open a Presenter option ("Settings") without crashing Powerpoint. I can also close the project without incedent if I use the File-Close menu as opposed the the "X" button.
I am running Win 7 64bit, Powerpoint 2010 32bit with Presenter 8.02.
Sincerely hoping support is continuing to monitor these threads, as this one was started in November without much response.
gdffbz51 - yes, you are describing what happens to me exactly... I get the run-time error as well - although, I believe that I have 32-bit build - my system type is X86-based PC - but I also have PPT 2010 and Presenter 8.02. I have updated my case with Adobe and have referenced this string for them in my case update. I am going to try and work today by using only file open and close like you have referenced.
I think I have this problem fixed. After another few Adobe calls, the person asked me to have my IT log in as a local admin and not on the domain... sure enought, I did not get the run-time error and can navigate in and out without issue. From there, my IT guy renamed my temporary files... and it seemed to work... fix here:
Early on, I did have suceess with Adobe support emptying my temporary files, and I was doing that daily... guessing that may be the root of this issue somehow. I hope this fix continues to work for me and it works for some of you that have been having the same problem.
We just bought Adobe Presenter 8 (32 bits version) to run it on Windows 8 64bits, with Office 2013 32bits. Video Creator works fine, but I cannot get Adobe Presenter 8 to start.
In PowerPoint 2013, I see that the Add-In is disabled, because of an issue with DEP:
I tried to deactivated DEP for "MenuLauncher.dll", but Windows 8 denied it (it said that MenuLauncher.dll required DEP). I tried also the solution above, but I do not have the same temporary folders anywhere.
According to the tech specs, http://www.adobe.com/products/presenter/tech-specs.html, Presenter 8 is supported on Windows 8 and Office 2013 32 bits:
Please help ![]()
Have you tried in the Add-ins screen under the :Manage" window at the bottom select the Disabled Items selection, the click "Go" and disabled add-ins will show. Highlight the Presenter Add-in and click on Enable. show. Highlight the Presenter Add-in and click on Enable. This will reable your add-in but will not resolve the issue with the message that causes people to disable the add-in. See the recommendation above several posts that gives a solution that seems to work.
