Default Paste Settings
Feb 19, 2010 Feb 19, 2010
Is there a way to set some default paset paramaters for Anchored Frames and Object Properties?
When I paste an image, the Anchored Frame is Below Current Line by default, but I would like it to always be At Insertion Point. Also, the Offset (Object Properties) of the image is .083', .083' by default, but I would like the image to be flush with the top, left corner at 0, 0.
910
LEGEND , Feb 19, 2010 Feb 19, 2010
Check out Bruce Foster's ImpGraph plug-in: http://home.comcast.net/~bruce.foster/ImpGraph.htm
Otherwise, no you can't (re)set defaults. However, some settings in FM are "sticky" and will be retained for the next operation.
Dec 07, 2012 Dec 07, 2012
Arnis,
Here it is two years later and I decided to look for an answer to the same question. I tried the above link but it's broken. Do you or any other forum member know if Bruce Foster moved the web link to another location? Or is there another plug-in available?
I use anchored frames below current line, a fixed with, centered, with graphic objects centered left-right (don't know if that last one is part of the anchored frame).
Yours,
Michael F
Bruce has sadly passed away – check the list of plugins on the links found in the frameusers.com site
Michael,
As Jeff mentions, Bruce passed away and his plug-ins are no longer available. There is a fairly extensive list of plug-ins compiled by Lin Sims and can be found at either http://mif2go.com/framemaker-resources or http://www.microtype.com/links.html
You might want to have a look at Russ Ward's WS utlities plug-in at http://www.weststreetconsulting.com/WSC_Utils.htm  or Felix Ritter's fmGraphicstools at http://www.mevis-research.de/~ritter/awakeideas/fmtools.html
Advisor ,
Dec 09, 2012 Dec 09, 2012
As far as I remember, the Shrinkwrap shortcut esc, m, p sets the anchored frame properties the way you describe … whether you want it to or not. HTH.
