I have been struggling with installing PS Elements 11 on a Win 7 64-bit machine for over a day. The Shared Technologies portion of the install is where the process fails. The following is the error from the log file. Any suggestions on how to proceed?
[ 1748] Sat Dec 08 19:22:14 2012 INFO
Visit http://www.adobe.com/go/loganalyzer/ for more information
START - Installer Session
RIBS version: 5.0.65.0
Win OS version: 6.1.1.0 64 bit Type: 1
::START TIMER:: [Total Timer]
CHECK: Single instance running
CHECK : Credentials
Load Deployment File
CHECK : Another Native OS installer already running
Create Required Folders
Assuming install mode
Looking up install source path
Sync Media DB ...
::START TIMER:: [Sync Media DB]
Pre check media db sync
End of Pre check media db sync. Exit code: 0
:: END TIMER :: [Sync Media DB] took 912.45 milliseconds (0.91245 seconds)
Ready to initialize session to start with ...
::START TIMER:: [CreatePayloadSession]
-------------------- BEGIN - Updating Media Sources - BEGIN --------------------
Updated source path: C:\temp\Adobe Photoshop Elements 11\PSE 11\ElementsSTIInstaller
Updating media info for: {0449467E-102A-4514-9F4D-91BCEE129390}
Ignoring original data since install source is local
Type: 0, Volume Order: 1, Media Name: Adobe Photoshop Elements 11
Path: C:\temp\Adobe Photoshop Elements 11\PSE 11\ElementsSTIInstaller\payloads\ElementsCameraRawProfile7.0All-16051 2123011\Install.db
Updating media info for: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA}
Path: C:\temp\Adobe Photoshop Elements 11\PSE 11\ElementsSTIInstaller\payloads\AdobeXMPPanelsAll\Install.db
Updating media info for: {3A8D4A3A-5E08-4E33-8831-50CB4DC101E6}
Path: C:\temp\Adobe Photoshop Elements 11\PSE 11\ElementsSTIInstaller\payloads\ElementsCameraRaw7.1All-x64\Install. db
Updating media info for: {5A73BC84-244A-48B4-ADDB-99CE9E2DBBE7}
Path: C:\temp\Adobe Photoshop Elements 11\PSE 11\ElementsSTIInstaller\payloads\ElementsCameraRaw7.1All\Install.db
Updating media info for: {98CE8819-87AA-4814-8167-ADDDD513485F}
Path: C:\temp\Adobe Photoshop Elements 11\PSE 11\ElementsSTIInstaller\payloads\PSE11STIInstaller\Install.db
Updating media info for: {D1B83970-7269-48BE-8B0E-5120D9327E52}
Path: C:\temp\Adobe Photoshop Elements 11\PSE 11\ElementsSTIInstaller\payloads\AdobeAPE3.101-mul\Install.db
Updating media info for: {F6F5021E-0548-43C1-82CC-C5C7A6906585}
Path: C:\temp\Adobe Photoshop Elements 11\PSE 11\ElementsSTIInstaller\payloads\ElementsCameraRawProfile7.0All\Insta ll.db
-------------------- END - Updating Media Sources - END --------------------
Supported RIBS version range: [0.0.66.0,5.0.65.0]
----------------- CreatePayloadSession: machine is x64 ---------------
Setting ignore refcount for '{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 5.0.65.0' getting upgraded by '{F6F5021E-0548-43C1-82CC-C5C7A6906585} Camera Profiles Installer 7.0.0.0'
[ 1748] Sat Dec 08 19:22:14 2012 FATAL
Payload '{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 5.0.65.0' information not found in Media_db.
:: END TIMER :: [Total Timer] took 1730.37 milliseconds (1.73037 seconds) DTR = 4.6233 KBPS (0.00451494 MBPS)
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 0 error(s), 0 warning(s)
FATAL: Payload '{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 5.0.65.0' information not found in Media_db.
Please search the above error/warning string(s) to find when the error occurred.
These errors resulted in installer Exit Code mentioned below.
Exit Code: 7 - Unable to complete Silent workflow.
END - Installer Session
Did you try installing after deleting the folder C:\temp\Adobe Photoshop Elements 11\
Also you might want to turn off your antivirus program while installation
If the folder is hidden: follow the post http://forums.adobe.com/message/4849350#4849350 to turn hidden folders visible
I have tried numerous scenarios. That particular folder is where the downloaded software is. I tried installing from the CD, then downloaded a copy and tried that too. You will notice in the error that is can not find Camera Profiles Installer 5.0.65.0 in the media_db database so it knows what to do to upgrade to version 7 of the profiles I believe if I can get this corrected the install will finish properly.
Sorry about not replying earlier. No I am not having the issue any longer.
It took two live chat sessions and a remote session with Adobe tech support to come to the conclusion I needed to figure this out on my own. That was a wasted 6 hours one night...
Anyway, the clue to the solution is in the error message. The install process could not find information on Camera Profiles Installer 5.0.65.0 which is not the version that was installed on my system I believe when Lightroom was upgraded on my system the Camera Raw version was upgraded to 6.67 but was not the correct version for a system with PS Elements installed. I downloaded the latest update of Camera Raw specifically to work with Elements, upgraded the software and re-ran the PS Elements 11 installer. Everything worked...
Thanks for checking back with me!
