Hello alltogether.
I've installed Design Premium CS5.5 Student for Mac fresh from Disc.
And directly after the Setup, all apps would run perfectly fine.
But Dreamweaver is the exception.
Everytime I want to start Dreamweaver, an error occurs.
This Error tells me, that i can't run Power PC Applications on Mountain Lion.
Today I tried to run the new Update.
I hoped that this Update would correct this.
But the Adobe Updater shows the error U44M1P7 for Dreamweaver.
I tried to install it manually with a download, but this throws the same error.
Is there a Solution for this?
I hope there is someone that can help me.
Greetings,
Fabian Grunau
Narwahls did you receive any error messages during the install process? You can check your installation logs by following the steps listed at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html. There is information in this document for how to locate and interpret the log files.
