Service Temporary Unavailable!
Dec 25, 2012 9:32 AM
I install CF 10 on my Win 7 64 bits Home edition which works fine for a while.
I just got the error message while I want to access it
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Jakarta/ISAPI/isapi_redirector/1.2.32 ()
I tried to reboot computer, but get same error message.
I would like to know how to find the problem and to fix the issue.
Your help and information is great appreciated,
iccsi
    Dec 25, 2012 10:49 AM   in reply to iccsi
    A google search on "start programs automatically windows XXX", where XXX is your version of Windows will help you.
    Dec 26, 2012 9:03 AM   in reply to iccsi
    On the server, right-click "My Computer" or "Computer" and choose "Manage".
    Go to Services and look for ColdFusion Application Server; double click to open Properties dialog.  For Startup Type choose either "Automatic" or "Automatic (delayed start)" and then click "OK".
    This should be sufficient to get CF Server starting at boot up.  If the above is already how it is set, then there is another issue.
    ^_^
    Dec 29, 2012 7:19 PM   in reply to iccsi
    I had this issue too, but it was not from the service starting or not starting, but rather from the hotfix not being installed correctly.
    I was able to get around all the little ins and outs by temporarily elevating the account that ColdFusion uses to login. In my environment, ColdFusion has its own local login. I gave it 'Users' and 'Administrators' group roles, and then restarted the services. After that, I was able to apply the hotfix with no issues. After the hotfix was applied, I removed the 'Users' and 'Administrators' group roles
    I outlined the steps here: http://thefusionator.com/index.cfm?blogID=4
    -Michael
