Whenever I try to access links in Flash Builder such as those on the Start Page, Device Connection Help in Run Configurations or even Find and Download other versions of Flex SDK in the Flex Configuration window it opens up a blank Notepad window with an error "The filename, directory name, or volume label syntax is incorrect."
Anyone have any idea on how to fix this? I assume it is supposed to open up a web page.
Wow, problem solved. I thought it was weird when I installed Flash Builder 4.7 and it was still happening. Apparently at some point I set Notepad.exe as the default program to open HTML files and did not realize it.
I feel kind of dumb now but as every other program was working (heck, links even worked in Flash Professional) I was so sure it was a Flash Builder problem.
Anyway, I am just glad to have the mystery solved.
