converting color .jpg image to grayscale
Jan 24, 2013 Jan 24, 2013
I have a color .jpg image that I want to convert to grayscale and then add annotation. Is this easy to do in Illustrator?
23.7K
Adobe
That depends on the nature of your image and what exactly you want to achieve.
Monika,
I've opened the .jpg image in Illustrator. It is a line drawing. Most lines are black but there is also some color shading, e.g. yellow and orange. The shading will probably look good enough in grayscale. I've opened the Links Panel and the image appears to be "embedded". However I cannot edit individual parts of the drawing.
        Tom
Select the image. Use Edit>Edit Colors>Convert to Grayscale to get what you want.
Larry,
Thanks for your help.
Tom
Guide ,
Best way to deal with rastered imagery is in Photoshop. There are several ways to convert color to grayscale, with lots of control over the process.
Those two statements constitute a logical fallacy. A JPEG image is a bitmap, and not, in any way or fashion, a "line drawing". Therefore,
...I cannot edit individual parts of the drawing.
is because the "individual parts" of the image are single color pixels. To "edit" these, you need a bitmap editor.
It's necessary to say "edit" (w/quotes) because you will be editing pixels. Any notion of 'lines', 'planes', and 'shades' only exist in your mind, and not as physical separate objects somewhere inside the bitmap. If you think you can "select" a big black square "object" in the bitmap editor, well, that's because the software only makes you think you can (it's easy to scan for the edge of a single color filled region).
... I just felt you might need to know this.
Actually, the terms "line art" and "line drawing" have been used interchangeably in the reproduction graphics industry since long before programs like Illustrator even existed. In that context it means an original image that contains only solids, and therefore does not require halftoning, as opposed to continuous-tone (often called "contone") which does. Line art (i.e.; a line drawing) can be rendered in a raster image as easily as vector paths. In fact, any 1-bit raster image can rightly be called line art, whether it contains any continuous "lines" or not.
So when Thomas said his JPEG is a line drawing, he could be simply saying it is not an image of continuous-tone artwork or photography.
JET
JET
Tom
Jongware,
Tom
