I'm unable to rename methods or classes in Flash Builder 4.7. Attempting to refactor gives this error:
"An unexpected exception occurred while performing the refactoring. See the error log for more details."
This happens in all my projects. I've recreated my workspace from scratch and the error persists.
I recently overlaid the AIR 3.6 SDK in Flash Builder. I tried reverting to AIR 3.5, which I'd backed up, but that did not fix the problem either.
The error in the log follows:
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDialog2.run(RefactoringWizardDialog2.java:331)
at org.eclipse.ltk.ui.refactoring.RefactoringWizard.internalPerformFinish(RefactoringWizard.java:605)
at org.eclipse.ltk.ui.refactoring.UserInputWizardPage.performFinish(UserInputWizardPage.java:153)
at org.eclipse.ltk.ui.refactoring.RefactoringWizard.performFinish(RefactoringWizard.java:678)
at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDialog2.okPressed(RefactoringWizardDialog2.java:455)
at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:472)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4128)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3974)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3613)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at com.adobe.flexbuilder.editors.derived.refactoring.FlexOpenRefactoringWizardOperation$1.run(FlexOpenRefactoringWizardOperation.java:144)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at com.adobe.flexbuilder.editors.derived.refactoring.FlexOpenRefactoringWizardOperation.run(FlexOpenRefactoringWizardOperation.java:157)
at com.adobe.flexbuilder.as.editor.ui.actions.refactoring.SimpleRenameRefactorAction.run(SimpleRenameRefactorAction.java:78)
at com.adobe.flexbuilder.as.editor.ui.actions.refactoring.RenameRefactorAction.run(RenameRefactorAction.java:89)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler.java:185)
at org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execute(LegacyHandlerWrapper.java:109)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeCommand(WorkbenchKeyboard.java:468)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(WorkbenchKeyboard.java:786)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEvent(WorkbenchKeyboard.java:885)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequenceBindings(WorkbenchKeyboard.java:567)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(WorkbenchKeyboard.java:508)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter.handleEvent(WorkbenchKeyboard.java:123)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1069)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4127)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1494)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1490)
at org.eclipse.swt.widgets.Canvas.sendKeyEvent(Canvas.java:463)
at org.eclipse.swt.widgets.Composite.keyDown(Composite.java:594)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5473)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:220)
at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:2092)
at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:2252)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5535)
at org.eclipse.swt.widgets.Display.applicationSendEvent(Display.java:4989)
at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5138)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApplication.java:128)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3610)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:79)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.NullPointerException
at org.eclipse.core.runtime.Path.isPrefixOf(Path.java:632)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.resourceForLocation(FileSystemResourceManager.java:286)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.containerForLocation(FileSystemResourceManager.java:266)
at org.eclipse.core.internal.resources.WorkspaceRoot.getContainerForLocation(WorkspaceRoot.java:120)
at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGateway.loadProject(SearchIndexGateway.java:414)
at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGateway.loadProject(SearchIndexGateway.java:422)
at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGateway.createQuery(SearchIndexGateway.java:376)
at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGateway.getOccurrences(SearchIndexGateway.java:188)
at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGateway.access$4(SearchIndexGateway.java:172)
at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGateway$SearchIndex.getOccurrences(SearchIndexGateway.java:556)
at com.adobe.flexide.refactoring.core.ASRenameProcessor.checkFinalConditions(ASRenameProcessor.java:199)
at com.adobe.flexide.refactoring.core.VariableRenameProcessor.checkFinalConditions(VariableRenameProcessor.java:139)
at org.eclipse.ltk.core.refactoring.participants.ProcessorBasedRefactoring.checkFinalConditions(ProcessorBasedRefactoring.java:224)
at org.eclipse.ltk.core.refactoring.CheckConditionsOperation.run(CheckConditionsOperation.java:85)
at org.eclipse.ltk.core.refactoring.CreateChangeOperation.run(CreateChangeOperation.java:121)
at org.eclipse.ltk.core.refactoring.PerformChangeOperation.run(PerformChangeOperation.java:209)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.ltk.internal.ui.refactoring.WorkbenchRunnableAdapter.run(WorkbenchRunnableAdapter.java:87)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
confirm this issue, i can reproduce by try to refactoring by move folder to other folder e.g.
at first
/com
/something/manythinghere
then and want to refectoring to...
/com/somthing/manythinghere
then error throw up, 100% reproduce able here.
I just overlaid the 3.6 SDK and tried reproducing the issue, with the steps mentioned above. But refactoring seems to work fine for me.
Are you using some other plugins with Flash Builder 4.7 ?
Can you try switching to a new workspace and try the scenario in a newly created project?
If it still happens. Kindly provide the steps to reproduce the issue and we'll look into it. Thanks.
Hi Guriya,
i also can't reproduce this at my home computer, but 2 of office computers still have this issue, seem like it happend only will deep nested package in some certain case
fyi : i had http://sourceforge.net/projects/flexformatter/
installed all of 3 computers
btw, make sure you check "Include subpackages" while moving to reproduce (Just in case you didn't check it) and try it with more complex and deep neted folder e.g.
i attach reproducable project here http://www.sendspace.com/file/cmltm8
and here's how to reproduce (move "data" folder to "com" folder and checked "Include subpackages")
Thanks for assit
I'm experiencing the same issue with FB 4.7 x64 - a fresh install with AIR updated to 3.7. Anyone from Adobe able to comment on this? Will there be a patch released to fix it?
Stack trace:
at org.eclipse.ltk.ui.refactoring.RefactoringWizard.createChange(RefactoringWizard.java:631)
at org.eclipse.ltk.ui.refactoring.RefactoringWizard.computeUserInputSuccessorPage(RefactoringWizard.java:470)
at org.eclipse.ltk.ui.refactoring.UserInputWizardPage.computeSuccessorPage(UserInputWizardPage.java:74)
at org.eclipse.ltk.ui.refactoring.UserInputWizardPage.getNextPage(UserInputWizardPage.java:114)
at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDialog2.nextOrPreviewPressed(RefactoringWizardDialog2.java:497)
at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDialog2.access$2(RefactoringWizardDialog2.java:494)
at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDialog2$1.widgetSelected(RefactoringWizardDialog2.java:693)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at com.adobe.flexbuilder.as.editor.ui.navigator.FlexPackageExplorerRenameAction.run(FlexPackageExplorerRenameAction.java:141)
at org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEvent(BaseSelectionListenerAction.java:168)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.runtime.Path.isPrefixOf(Path.java:636)
at com.adobe.flexide.refactoring.core.TypeRenameProcessor.checkFinalConditions(TypeRenameProcessor.java:199)
Root exception:
I'm convinced that Adobe just doesn't give a shit. Buggy, beta-quality releases are par for the course for Flash Builder. Maybe they'll fix 4.7's issues in the next paid release.
Hopefully someone from Adobe disagrees? This issue is almost a showstopper - it's something that needs to be dealt with via a patch or at least a FAQ entry with instructions on how to fix it, not the next version.
Creating a fresh workspace solved the issue. Turns out if the workspace points to directories outside (not under) its root this happens.
