1
Adobe InDesign Middle Eastern CS6
May 13, 2012 May 13, 2012
Hi
Where is the link to Adobe InDesign Middle Eastern CS6 Trial Download?
Thank you
38.2K
New Here , May 23, 2012 May 23, 2012
Here is what many don't know: the Middle Eastern version is indeed available on InDesign (and for Creative Cloud users). In order to take advantage of the ME options you need to:
1. Sign onto Adobe Application Manager.
2. Click on your name and go to Preferences
3. Change your language from English to "תומך עברית English" or the equivilant for Arabic etc.
4. Double check to verify that the language settings took place by going into Preferences once again (it didn't work for me first time around).
Now
There are no ME editions anymore. It's all done natively now:
http://www.adobe.com/products/indesign/features.html
Mylenium
But I installed the trial from adobe, and I don't see Middle Eastern specific features, like Direction, Diacritics, Kashida or other features.
Should I install some extra package for arabic options?
Thank you
Adobe Employee ,
Moving this discussion to the InDesign forum.
May 06, 2018 May 06, 2018
to enable me feature, you can apply this method (at found at website):
1) close indesign
2) open regedit (press windows logo + R simultaneously)
3) on regedit -> hkey_local_machine -> software -> Adobe -> Indesign -> click 8.0 folder, then double click "Feature Set Locale Setting", change the value data from 100 to 103
3) close regedit, then open your Indesign
hope this help. cmiiw.
Jul 02, 2020 Jul 02, 2020
Thank you, samsul_depok!
From that page:
"... as well as complex script languages such as Arabic and Hebrew.§
§ For a broader range of typographical controls, use the Middle Eastern version of InDesign."
It seems "broader" should be interpreted as "any at all".
Now, any application you download (I've tried it only with InDesign so far) will automatically be with Hebrew or Arabic support.
Good luck!
Note that that the תומך עברית English option has one problem with InDesign. Although the UI is in English, if you invoke Help (F1), you will end up with Hebrew-only Help. I've reported that as a bug.
          - Dov
- Dov Isaacs, former Adobe Principal Scientist (April 30, 1990 - May 30, 2021)
Nov 30, 2012 Nov 30, 2012
Adobe Middle Eastern CS6 Software can be purchased from www.languagesource.com
Jan 31, 2013 Jan 31, 2013
Please clarify. Do I understand correctly that I can convert my Indesign CS6 to Middle Eastern at no additional charge?
Other than the problem with the Help feature, will all features work the same with the addition of working from right to left?
Feb 01, 2013 Feb 01, 2013
No I don’t believe you can convert your Indeisgn CS6 into Middle Eastern support you will need to purchase middle Eastern edition which will have the right to left support built inn. This can be purchased from www.languagesource.com
If you are a Creative Cloud subscriber, then yes, you can uninstall the version you have and download and install the ME/North Africa version. The non-ME versions have RTL capabilities, though, that can be unlocked by script or by using the World Tools plugin from In-Tools.com which may be a more cost effective solution if you are not a cluld subscriber and you only occasionally need the ME features.
I currently have CS2 which is why I am looking to upgrade. If I need to upgrade anyway, do I understand correctly that Creative Cloud is the best way to go? Are there any disadvantages I should be aware of why I may prefer to purchase a full version?
Creative Cloud will give you access to EVERYTHING including CS7 when it's released.
Do you have any CS3 or later applications? If so, you'd qualify for intro pricing.
You can also try it all for free for month http://www.adobe.com/products/creativecloud.html
Bob
Nobody but you can say what the best option for you will be. If you use more than one or two of the applications and would actually spend money to keep versions current in the future, then the cloud is an amazing bargain, as it would be if you want access to Muse or other applciations or services that are not offered except on the cloud.
Im not sure about the creative cloud but you no longer can upgrade from CS2
thank you Peter Spier your are most welcome
Feb 02, 2013 Feb 02, 2013
Thanks everyone for your help. It seems like I may be better off with purchasing CS6 (I quality for educational license and don't need to always have most updated edition) with a plugin. Does anyone know about ScribeDoor compares to World Toosl? Do they both serve the purpose of seamlessly converting my programs to Middle Eastern capability?
Feb 04, 2013 Feb 04, 2013
No, they both have seams, in different places.
I am seriously in favor of World Tools - it suits my needs pretty much perfectly. In fact, what I'm really in favor of is World Tools Pro (although I'm stuck on World Tools on CS4 until my clients upgrade). But if you tell us what you're trying to do, then I'll try to be neutral in making a suggestion, and I'm sure that there are other posters who will be able to be more neutral than myself. Both plugins have strengths in different areas, and unless we know what kind of work you're doing, it's impossible to comapre and contrast.
Wow. I really appreciate your time.
My usage is very basic so I imagine that either would be fine. I primarily use it to typeset invitations (I type backwards in Hebrew and when text needs justifying I have to manually adjust the correct number of words - not very efficient, although I'm doing it for 15 years, so I'm a whiz at typing backwards!) If I would have Hebrew capabilities, I would use it to typeset Hebrew pamphlets, primarily text based.
So whichever works smoother would probably be fine.
Thanks again
Feb 05, 2013 Feb 05, 2013
I personally think that the interface for World Tools is better, but it costs more. (Also, the guy who wrote World Tools is a forums regular.)
If you know anything at all about installing and using scripts, or if you can tweak the styles in a template so you can use 'em, then you can get RTL text direction for free! But if you want easy access to tools in a well-designed interface, then scraping together a set of scripts and templates makes less sense when there are free demos for both World Tools and for ScribeDOOR. In your shoes, I'd buy World Tools because of the obvious Hebrew-leaning direction of the other tools made by the same company. (Winsoft's stuff seems to be more aimed at Arabic typography, viz. Tasmeem, whereas in-tools.com offers Hebrew-specific stuff like Drop Words in addition to the World Tools plugin.)
No doubt! I always love running into fellow old-school complex-script typesetting folks. I got my start in this business right around when you did, but I was operating a creaky old Letraset machine with an irreplaceable stock of old Arabic Letraset sheets. Or typing Hebrew backwards in Pagemaker. The major advantage of upgrading your toolset here is that revisions are So. Much. Easier. if you are used to the contemporary methods of handling bidirectional text.
Guru ,
There are a lot of easy scripting solutions.
You can type your hebrew forward and then select it and then run this script
app.selection[0].contents=app.selection[0].contents.split("").reverse().join("")
before
after
There are better ways of doing this but I'm scared Harb's will beat me up or even worse not answer my questions on the forum so you should go for In-Tools plug in.
It seems that one can get creative cloud in Israel now and if not it must be coming very soon as the adobe Israel site is full of it.
If you have a US, UK etc. address then you can for sure sucribe to it from Israel.
החלצהב
Trevor
If you're going to script solutions for Hebrew you may as well go all the way:
app.selection[0].characterDirection = CharacterDirectionOptions.rightToLeftDirection
I think that's the syntax, anyways - scripting on the fly is a real weak spot for me.
Guru ,
Joel, you forgot to check your script
It will only work if you change the composer to
"Adobe World-Ready Paragraph Composer" or to "Adobe World-Ready Single-line Composer"
