Downloaded Lr 4 but cannot install?
Nov 21, 2012 Nov 21, 2012
The below screenshot is the error message I receive when I attempt to install the software. I downladed the software again thinking there might have been an issue during the download, but I experience the same problem with the error messsage? I'm based in Asia and have found Adobe support terribly disappointing. I would appreciate any help in resolving this. Thanks!
5.6K
Adobe Employee , Nov 21, 2012 Nov 21, 2012
Most likely you have a corrupted download of the file. Try deleting it and downloading the latest version of Lightroom (4.2). Lightroom updates are the full installation package.
Adobe Photoshop Lightroom 4.2
Make sure your system meets the specs. Mac OS X 10.6.8 or higher 64 bit.
Regards, Denis: iMac 27” mid-2015, macOS 11.7.10 Big Sur; 2TB SSD, 24 GB Ram, GPU 2 GB; LrC 12.5, Lr 6.5, PS 24.7,; ACR 15.5,; Camera OM-D E-M1
I'm using a Mac - OS 10.8.2 - 2 x 2.8 GHz Quad-Core Intel Xeon - 10 GB RAM.
The probelm is when I click on the installer icon, an error message states "Adobe Photoshop Lightroom 4. pkg can't be opened. You should eject the disk image".
On a side note, I downloaded and installed CS6 without any problems on the same computer today.
Ok the system specs are ok, maybe a Mac expert might chip in and help.
Adobe Employee ,
Jan 30, 2013 Jan 30, 2013
there are others with this problem:  http://forums.adobe.com/thread/1144922?tstart=0
there's a duplicate screenshot in the above thread showing the error and also an explanation that the downloaded dmg file was clicked and the pkg file should be clicked to install lr.
re-downloading was no help.
Adobe Employee ,
Jan 31, 2013 Jan 31, 2013
This issue shouldn't be about when the file was download, but about the specific download itself. Perhaps there was a hiccup in the network at the time of the download. If you have only tried downloading once and this error occurs, definitely delete the file you have and try again. Otherwise try downloading from a different web browser.
I haven't seen that one before, so I'm moving this to the Installer forum.
______________________
The Lightroom Queen - Author of the Lightroom Missing FAQ & Edit Like a Pro books.
I'm facing the exact same problem. I just downloaded lightroom 4 today. I'm based in Singapore and I get prompted the exact same " eject disk image" as you. Have you rectified it? Please let me know. Thanks.
Feb 02, 2013 Feb 02, 2013
The installer's certificate is expired (expiry was Dec 15, 2012). Unfortunately, Apple's installer app doesn't tell this very obviously.
Here's what you can do to install the application:
  1. Open "Terminal" app (you can use spotlight to open this)
  2. On the command line, run the command: open -a Installer
  3. Go to the mounted volume of the DMG (its name should appear as "Lightroom 4.0" on the left hand side), and click on the .pkg file within it
  4. It will give you some warnings about certificate. Click "Continue"
  5. Proceed with the rest of the installation
I faced the same issue today, and eventually figured out the root cause and used the above to install. Can't believe Adobe would ship out a software with an expired certificate.
Feb 09, 2013 Feb 09, 2013
Hi, I am getting this exact same problem.  I am based in Hong Kong and I just downloaded Lightroom today but have been unable to install it due to this error message.
My second problem - I only got my Mac two days ago and I have very little idea how to use it at the moment!  I tried following AmodMalviya's instructions above but I got stuck on the second step... I managed to open the terminal app and I tried typing in the command, but nothing seems to happen.
I am not technically minded at all, so if someone could explain how to do this to me in the simplest terms possible it would be greatly appreciated!!
Thanks in advance!
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5487
Download the 4.2 version. And use the same serial number that you got from Adobe. I can't believe Adobe is sending people a file that is not working.. It should work after that.
Thanks very much for getting back to me so quickly, I'm trying that now....
I know, is crazy... I've found a few threads on here about the same issue, but the only response from Adobe is, 'download again, download with a different browser or try using a wired connection', which by the sounds of it, none of those options work!
I'll report back once the file has downloaded and let you know how I get on.
Worked perfectly with 4.2 - Thank you so much!!
haha no worries, I was so irritated when I had the same problem. kong hei fatt choi! (happy new year in hk cantonese)
