Gary__F
How to create a Java array for use with jsoup addAttributes() ?
Feb 2, 2013 4:56 PM
Tags: #java #coldfusion #jsoup
Hi. Has anyone used jsoup for cleaning up user-submitted HTML?
When I ask jsoup to add some extra attributes to its whitelist I get this error: "The addAttributes method was not found."
The addAttributes() method requires an array. I tried using a CF array, a Java array, and even a string, but nothing worked.
I'm using CF8. My test code is:
<cfset jsoup = createObject("java","org.jsoup.Jsoup")>
<cfset whitelist = CreateObject("java", "org.jsoup.safety.Whitelist")>
<cfset html="<div style='font-size:24pt;'>This is BIG text</div>. This is an unwanted script: <script>alert('Boo!')</script>.<br>">
<cfset myAttribsArray=[":all","style"]>
<cfset myAttribsArray=javacast("string[]", myAttribsArray)>
<cfset sanitized = jsoup.clean(html, Whitelist.relaxed().addAttributes(myAttribsArray))>
<cfoutput>
<textarea rows="10" cols="60"> #HtmlEditFormat(sanitized)#</textarea>
</cfoutput>
The code works if I don't bother with addAttributes(), but I need to add the style attribute to the whitelist. Can anyone help please? Thanks.
The API reference for addAttributes() is here:
http://jsoup.org/apidocs/org/jsoup/safety/Whitelist.html#addAttributes
    Feb 2, 2013 7:59 PM   in reply to Gary__F
    I looked at the reference you posted and did not see anything about the requirement for an array.
    Mar 29, 2013 1:06 PM   in reply to Gary__F
    You can see the setAttributes() method signature like so:
    <cfdump var="#Whitelist.relaxed()#" />
    If you run that you will see setAttributes() expects a string and a string array.
    addAttributes(java.lang.String, java.lang.String[])
    Given that, you need to do something like:
    <cfscript>
    jsoup = CreateObject("java","org.jsoup.Jsoup");
    whitelist = CreateObject("java", "org.jsoup.safety.Whitelist");
    html="<div style='font-size:24pt;'>This is BIG text</div>. This is an unwanted script: <script>alert('Boo!')</script>.<br>";
    myKeys=["style"];
    sanitized = jsoup.clean(html, Whitelist.relaxed().addAttributes(":all" , JavaCast("string[]", myKeys)));
    WriteOutput("<textarea>#sanitized#</textarea>");
    </cfscript>
