I'm trialling Premiere CS6 and there are loads of presets missing on the sequences! XDCAM, Red, AVCHD, Canon.... all missing! Any suggestions appreciated. I have CS5 and that's all fine!
same here!
Yes, they are MPEG based and latch on to your already installed CoDecs from your old versions. You will have to deactivate your CS5 temporaily to make them work. Off hand I'm not sure, but I believe some of the CoDecs will still remain unavailble then due to licensing restrictions. A lot of that has been lifted in CS5.5, but not all. some stuff requires a serial number. And then of course the usual: If you use any other CoDecs on your system that handle these file types, they may interfere and may need to be uninstalled.
Mylenium
I had a very helpful email from a techie friend which I'll share. It's ridiculously easy to fix this as it turns out. Search out the "cache.db" file and delete it. Next time you run Premiere it regenerates and suddenly everything is available. Soooo simple. And relax....
i am on windows
Moving this discussion to the Premiere Pro CS5, CS5.5, & CS6 forum.
So am I, so this fix should work for you too
I got it to work.
I uninstalled cs6 including any other versions
uninstalled anything that was adobe related including Adobe Flash, litterally anything with adobe in the title.
used adobe removal tool
then did a search on my computer and deleted everything related to adobe.
restarted.
reinstalled Adobe CS6
Did this 2 times, deleted everything...
Still no presets available.
Help anyone!
Presets won't be there until you active Premiere.
Same problem here. Uninstalling all adobe software didn't help. Fiddling with the cache file didn't help either.. (win7x64).
Please verify that your copy of Premiere Pro is activated online. This is essential in making sure this content is properly installed.
My presets were there and then after 3 weeks of workin perfectly fine, they have disappeared. I am activated and was running smooth and now i've spent about 60 hours tryin to figure this out
Is there an alternative to activating online?
I'm using a machine that's not wired to a network (and can't be), and I don't have any of the presets I need. Uninstalled, ran Cleaner 6 times, reinstalled, and it looks like they're still not there.
If I can't activate it offline, it's going to be a huge problem for me.
I would contact Adobe Customer Service (not Technical Service), and ask for their assistance in Activation, without an Internet connection.
Good luck,
Hunt
Have you managed to activate offline and to get all codecs and presets? I have the same problem.
I'm working on a Mac and I have the same problem. Nearly all my sequence presets are gone, I have no idea why. Can anyone help and say how to restore these presets? I looked in the Premiere Pro application folder and all the presets are still there, It seems that Premiere Pro can't find them…
Try deactivate, exit PR, reboot, start PR and activate again.
Did it like you said, nothing changed, the presets are still missing…
Are you logged in as the root?
Yes.
Try to find this file on your Mac and delete it.
C:\Program Files (x86)\Common Files\Adobe\Adobe pcd\cache\cache.db
It worked on Windows.
Sorry, but this file and folder doesn’t exist on my mac. I’ve searched every folder that Premiere seems to utilise, but no matches…
The smartest dumb folks at Adobe seems hell bent on creating problems for its users. At last I had begun to like some of the CS6 products such as Premiere Pro and After Effects. Too soon I guess.
Can someone from Adobe please respond? or is it too much to ask?
haha... I couldn't find the cache.db, magically it has appeared again. I am assuming some of you folks have seen it too.
