Hey folks, I'm getting the following error when I try to run the script...
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at SAFEBOOT_SIMULATOR_fla::MainTimeline/pm_MouseOutHandler()[SAFEBOOT_SIMULATOR_fla.MainTimeline::frame1:11]
Below is the code, line 11 frame 1 is highlighted to make it obvious... PMODE1 is an image being used as a button with a rollover effect.
//PRESENTATION MODE
PMODE1.addEventListener(MouseEvent.MOUSE_OVER, pm_MouseOverHandler);
function pm_MouseOverHandler(event:MouseEvent):void
PMODE1.visible=false;
PMODE2.addEventListener(MouseEvent.MOUSE_OUT, pm_MouseOutHandler);
function pm_MouseOutHandler(event:MouseEvent):void
PMODE1.visible=true;
//SIMULATION MODE
SMODE1.addEventListener(MouseEvent.MOUSE_OVER, sm_MouseOverHandler);
function sm_MouseOverHandler(event:MouseEvent):void
SMODE1.visible=false;
SMODE2.addEventListener(MouseEvent.MOUSE_OUT, sm_MouseOutHandler);
function sm_MouseOutHandler(event:MouseEvent):void
SMODE1.visible=true;
SMODE2.addEventListener(MouseEvent.MOUSE_DOWN, sm_mouseDownHandler);
function sm_mouseDownHandler(event:MouseEvent):void
gotoAndStop(1, "Scene 3");
//EXIT BUTTON MOUSEOVER
EXIT1.addEventListener(MouseEvent.MOUSE_OVER, eb_MouseOverHandler);
function eb_MouseOverHandler(event:MouseEvent):void
EXIT1.visible=false;
EXIT2.addEventListener(MouseEvent.MOUSE_OUT, eb_MouseOutHandler);
function eb_MouseOutHandler(event:MouseEvent):void
EXIT1.visible=true;
EXIT2.addEventListener(MouseEvent.MOUSE_DOWN, eb_mouseDownHandler);
function eb_mouseDownHandler(event:MouseEvent):void
fscommand("quit");
PMODE2.addEventListener(MouseEvent.MOUSE_DOWN, pm_mouseDownHandler);
function pm_mouseDownHandler(event:MouseEvent):void
gotoAndStop(1, "Scene 2");
stop()
I'm thinking that I have NO clue why this occurs and I will provide love and good thoughts for anyone who can (simply) explain whats causing the error, and point me in the direction of fixing it.
Tim.
PS, Just noticed that it still runs beyond the error... with no obvious ill effects.
OMG.
I'm really not 100% sure I understand entirely why (although I think I get the gist), but I decided that this MUST be something to do with the fact that it's trying to run a script on an image that is no longer there....
let me explain...
I read somewhere that GOTOANDSTOP runs the entire script through (whether a check or actually running it I don't know) but it occurs that the images are no longer avilable in the new frame... So I copied them to a new layer, sent them to the back, voilla.
Err
...Copy link to clipboard
Error 1009 is prominently featured here
Is this error occuring when you first try to test the file or does it happen at some point later after the file has started running successfully? If it's the latter, does it happen when you rollout of PMODE2.
Ned... The file launches, Rolling out and in works fine, but hitting the button PMODE2 is what causes the error. Hitting OK then continues on normally. Also noted that (although no content exists) SMODE2 does the same thing.
Moccamaximum, thanks for that, I'll take a peek from work tonight.
OMG.
let me explain...
Error gone.
Thank you both for your time to read and provide answers, I just wish it had ocurred to me to do the above before posting here! Hopefully this will save someone else a headache!
That's the basic premise of the 1009 error... you are trying to target an object thqt does not exist as far as the processor sees it. There are a number of ways this can happen, but they all basically boil down to indicating that an object your code is targeting does not exist when that code executes.
