In a Flash Builder 4.7 pure Actionscript project I'm using graphics built in Flash Pro and adding the swc to the build path. The output in FB 4.7 looks different than in Flash Pro CS6. I just re-installed both FB 4.7 and FP CS6, and overlaid the latest AIR 3.5 sdk. Still no joy.
I've compiled examples and posted them here: http://cldd.athabascau.ca/learning_activities/FB_Bug/
The image below is a composite showing the same graphic rendered in different projects, the first from FP, the others from FB. They should all look the same.
I re-installed FB 4.6 and built the same projects and all the graphics rendered correctly.
It looks like images have actually been substituted for different images, and I can't imagine Flash Builder actually building graphics!
Most likely is some kind of collision between names of classes in different SWC files.
Are you using more than one SWC library in your Flash Builder project?
Are you defining display classes in your Flash Builder project that share similar package name, class name etc?
Have you tried a new FB project that _only_ has this SWC?
G
I did test with a very simple project using only one swc. In the graphic shown at the top of the page, the fourth object from the right "text swc new" is the result. The first object "from fla" is the output from Flash Pro (and the same from FB 4.6). There are still problems in the render: the filters seem to be problematic.
I have re-installed FB 4.6 and will use it for everything but mobile development as everything renders correctly in 4.6.
I am out of the office until Tuesday, January 22nd. If you require an urgent answer, please try contacting me by mobile. Otherwise, I will respond to email on my return.
Gaius
I just upgraded to AIR 3.6 beta with the updated v 2 compiler and the issue appears to be fixed. I'm not sure if it's AIR 3.6 or some tidying I did during the install.
I have exactly the same problem.
Does anyone have a solution ?
