Hello,
I have a list of 8 bulleted items in a single text caption on several of my slides. I would like each of the points to appear one at time and sync them with the Neo Voice that will be presenting each of those points. Is there a way to animate each of these points (no crazy animation -- just simply appear) without making each of them a separate text captions? My biggest problem with making them each a separate caption is lining them up perfectly so that they are directly underneath each other and have the same amount of spacing between them....
Thanks for any help!!
Ryan
No way to do that with one text caption.
But about lining up and distributing the text captions: are they all 'oneliners'?
In that case: create the first text caption and put it in the wanted location. Then follow this routine to create the second one:
If you repeat this for each following caption they will all be aligned perfectly and distributed.
If they are not all oneliners, then choose the biggest text caption (in height), co-select all the others and:
Lilybiri
Thanks Lilybri,
I figured out how to use place holders in my master to make a it a little bit easier...
