JamieSoloPhoto77
Mac Finder Thumbnail Update Using Save-As External Hard Drive
Feb 12, 2013 10:51 PM
Tags: #jpeg #update #external #cs6 #hard #drive #finder #thumbnail
Hello:
I recently converted to an iMac and CS6 from PC/CS5.  In addition to the Mac OS missing some key file selection tools (like shift select for a range of files), I am having a big problem with thumbnail.  I recently sent a file to be printed that was edited in CS6 on the iMac.  The files were stored on an external hard drive connected direclty to the iMac.  The file I got from the printer did not match the image I sent.  I traced the problem to the fact that when using the Save-as function, the thumbnail was not updated.
I was able to replicate this problem at will.  As an experiment, I moved the file onto the internal hard drive and tried again.  This time the thumbnail did update.  Has anybody else had this problem?  Is this a Mac OS issue, or a Photoshop issue?
Jamie
    Feb 12, 2013 11:19 PM   in reply to JamieSoloPhoto77
    That would have to be an OS issue.  Photoshop either doesn't write thumbnails (if chosen), or writes the current data along with the new file.  There isn't a way for Photoshop to have out of date thumbnails in a file.
    Feb 13, 2013 1:05 AM   in reply to JamieSoloPhoto77
    Works fine for me (Mas OSX 10.6.8).
    And cmd-clicking for non-continuos items in lists.
    Feb 13, 2013 4:21 AM   in reply to JamieSoloPhoto77
    I've never had a problem with out of date "thumbnails" (I guess you mean custom file icons) or missing Shift select functionality in Finder. OS X 10.6.8.
    Feb 13, 2013 8:48 AM   in reply to JamieSoloPhoto77
    That sounds like the file is good, but the OS is not updating it's cache of the file thumbnail correctly.
    Feb 13, 2013 9:27 AM   in reply to JamieSoloPhoto77
    JamieSoloPhoto77 wrote:
    I am starting to consider that maybe it is the format of the hard drive (FAT32).
    That certainly could be a factor in the problem. Unless you have a specific need for the volume to be FAT32, it would be better formatted as Mac OS Extended Journaled, a.k.a. HFS+ Journaled.
    As far as I can tell the shift select method for selecting a range of files only works if you are not in thumbnail view, which is unacceptable for a phototgrapher.
    I see what you mean. In icon view, drag a rectangular selection, like a rectangular marquee in Photoshop. It's not a perfect solution but may help.
