Hi
I have problem install/update LR 4.3!
I have unlock the file.
The error is(transleated from Danish):
Problem under extractin, there is no space or the rights at the destination is wrong.
There is 1.6GB free on the drive.
I am admin and run the program as admin.
Br.
Kim
Where are you choosing to extract the install files too? Also which operating system are you using?
Hi
OS is windows 7 64 in danish version.
I have try to 2 different disk all with loth of space more then 1T.
And more the one location. Default and in my work array.
Br.
Kim
Sendt: 19. februar 2013 19:51
Til: Kim HUC
Emne: LR 4.3 install problem on WIN 7 64 DK
Re: LR 4.3 install problem on WIN 7 64 DK
created by Jeff A Wright <http://forums.adobe.com/people/JeffAWright> in Downloading, Installing, Setting Up - View the full discussion <http://forums.adobe.com/message/5085444#5085444
I have try to 2 different disk all with loth of space more then 1.6TB.
Please try extracting to your User folder. If you still continue to face difficulties then the download itself maybe corrupt.
I have try download 4-5 times.
I have try many diffrent install location.
I have try normal start and as administartor.
It still fail the same way.
It look like it fail before the real instalation, when it extract the file. But when extract the file to the temp location.
Is there a place where i can download a zip file with the install files and not a exe(zip)?
The exe file is just an extracter for the 7zip archive which you are downloading. Kim HUC I would recommend you contact our support team so they can walk you through the process. You can reach our chat support at http://adobe.ly/yxj0t6.
