I know this was an issue that was supposedly fixed in the first update, but I applied that and I'm still experiencing the error. Any ideas?
Version says ColdFusion 10,283649
CGI.PATH_INFO should be empty for a request URL like http://myserver/index.cfm
In case your URL is like http://myserver/index.cfm/hello, you will get the CGI.PATH_INFO as “/hello”
JRun which was the underlying server for CF 9 and earlier was actually giving a wrong value for PATH_INFO and that is why you see this change in behavior. You can also see this http://docs.oracle.com/javaee/1.2.1/api/javax/servlet/http/HttpServletRequest.html#getPathInfo().
Thank you for your response, but that is not the issue. CGI.PATH_INFO is always blank, no matter where I am within the directory structure. This was a bug (3305486) in CF10 but was supposedly fixed in updater 1:
http://helpx.adobe.com/coldfusion/kb/coldfusion10-update-01.html
I have installed that update. In fact, I have installed and reinstalled it several times. It has never fixed the issue for me, and I'm wondering if there are any other suggestions.
My machine is:
Windows 2008 R2
IIS 7.0
Can you please reconfigure the connector after applying the update (CF 10 Update 1) and check if this still does not work for you?
It works OK for me on CF10 using the inbuilt web server. Can you test whether it is likewise with you? It might be something peculiar to IIS that is still broken, or a vagary of your config..?
Adam
Hi ColdFusionSmurf,
I just verified that ColdFusion 10,282462 (w/ 0 CF updates installed) on IIS7.5 correctly returns CGI.PATH_INFO as "/foo" for "http://localhost/index.cfm/foo"
#3305486, which Update 1 fixed, was specific to URL Rewriting.
Can you please post an example of a URL path for which CGI.PATH_INFO is empty but shouldn't be?
-Aaron
I just discovered this problem after migrating from CF9 to CF10. I have applied all of the patches and have been relying on CGI.PATH_INFO in a breadcrumb tag. That tag is all over my website and now returns only the 'home' link which doesn't use the CGI.PATH_INFO tag.
This page is testing the the CGI.PATH_INFO and is returning nothing
http://www.ute-sei.org/English/sue.cfm
Sue
Hello,
As per the Servlet spec, CGI.PATH_INFO should be empty for a request URL like http://myserver/index.cfm
JRun which was the underlying server for CF 9 and earlier was actually giving a wrong value for PATH_INFO and that is why you see this change in behavior. You can refer to http://docs.oracle.com/javaee/1.2.1/api/javax/servlet/http/HttpServletRequest.html#getPathInfo().
Anit Kumar
I am getting NOTHING regardless of how deep the path is. The breadcrumb code which was working in CF9 relies on this and right now a page like:
http://www.ute-sei.org/English/committees/tech-change/2012/minutes-sub-nov-21-2012.cfm
has no breadcrumbs because that path provides nothing.
This is broken and means I'm going to have to make coding changes that I shouldn't have to.
Sue
@sduncanute
Sorry to hear you're running into the same problems. Unfortunately, I was never able to fix it and the people around here don't seem to believe me and therefore aren't very helpful. I don't know how much plainer you can say "I'm never getting a value in my PATH_INFO" but apparently it's not getting through.
My suggestion to you would be to replace all instances of CGI.PATH_INFO with something like request.cgiPath and then set that request variable in your application.cfc. I ended up doing:
<cfset request.cgiPath = getPageContext().getRequest().getRequestURI() />
That pretty much gave me the same thing, and I really needed to solve the issue immediately. I don't know about you but I couldn't afford to wait around for someone in these forums to actually believe me.
Hello,
JRun was the underlying server for CF 9 and earlier was actually giving a wrong value for PATH_INFO. In CF 10 there is a change in the behavior. Thus with CF10, you will have to use http://myserver/index.cfm/hello, you will get the CGI.PATH_INFO as “/hello”
Anit Kumar
I don't have ANY urls have have a /anything after the .cfm file so Anit, repeating your message over and over is not helpful, nor does it add anything to this thread.
Again, there is nothing in that variable no matter now many subdirectories down the file is.
Sue
p.s. @ColdFusionSmurf, thanks for the message and I'll look at implementing something like that.
Hello Sue,
Apologies for being not of much help to you. You can alternatively use PATH_TRANSLATED.
Anit Kumar
I think rather than getting snippy, you should perhaps actually read what Anit has been saying. They explained the situation perfectly well. The problem is that you're either not reading it, or not understanding it.
Precisely. Given CGI.PATH_INFO is specifically for returning the stuff after the .cfm file, it stands to reason that it's empty if you don't have anything there.
You need to understand that the behaviour on previous versions of ColdFusion - wherein CF supposedly put the file path (eg: /path/to/the/file.cfm) into CGI.PATH_INFO - was a bug. It was never supposed to be in there. CF10 fixed this.
To try to repeat what Anit and Aaron have said, given this path:
/physical/path/to/file/on/the/file/system.cfm/some/other/stuff?param=value
That is how CF10 behaves, and that's how it's supposed to behave. This is correct behaviour.
(that said, that's exactly how CF9.0.2 behaves for me as well).
Does that make sense?
And is this not what you too are seeing?
Adam
Excellent explanation, Adam I think the color-coding did the trick nicely!
Yes, Adam, the colour coding does help. The problem is, I was dealing with a chunk of code that was written by someone else, years ago and it worked fine up until recently.
Your colour coding shows that the CGI.PATH_INFO will no longer work for me and should not have worked before (but it has been since... 2004 or earlier).
If I use getDirectoryFromPath(CGI.SCRIPT_NAME) it gives me what I used to get from CGI.PATH_INFO.
Sue
Hi Anit,
CF10 still returns CGI.PATH_INFO as CGI.SCRIPT_NAME when default document is omitted.
Example: CGI.PATH_INFO for http://domain.com/dir/ is /dir/index.cfm
However, getPageContext().getRequest().getPathInfo() is empty for the same.
-Aaron
Hi Sue,
Looks like getDirectoryFromPath(CGI.SCRIPT_NAME) is what you want then, right?
-Aaron
Hi Aaron,
This is an example set which you can try to see the functionality:-
<cfoutput>
<h1>Test CGI Outputs</h1>
<div id="videogallery">
Software: #CGI.SERVER_SOFTWARE#<br />
ColdFusion Version: #server.ColdFusion.ProductVersion#<br />
Path Info: #CGI.PATH_INFO#<br />
Script Name: #CGI.SCRIPT_NAME#<br />
Path Translated: #CGI.PATH_TRANSLATED#<br />
<cfdump var="#CGI.PATH_INFO#">
</div>
</cfoutput>
Anit Kumar
Hi Anit,
I see CF10's CGI.PATH_INFO is still incorrect in IIS6 and IIS7 when URL does not contain a file name or extra path info, and when the directory contains a default document.
Steps to Reproduce:
1) Place this code into C:\Inetpub\wwwroot\dir\index.cfm
<cfoutput>
IIS: #CGI.SERVER_SOFTWARE#<br />
Script: #CGI.SCRIPT_NAME#<br />
Path Info CF: #CGI.PATH_INFO#<br />
Path Info Java: #getPageContext().getRequest().getPathInfo()#
</cfoutput>
2) Browse to URL http://localhost/dir/
3) See CF10's CGI.PATH_INFO is incorrect (/dir/index.cfm) in IIS6 and IIS7 and correct (empty string) in IIS7.5 and IIS8.
IIS: Microsoft-IIS/6.0
Translated: C:\Inetpub\wwwroot\dir\index.cfm
Script: /dir/index.cfm
Path Info CF: /dir/index.cfm (bug?)
Path Info Java:
IIS: Microsoft-IIS/7.0
Translated: C:\inetpub\wwwroot\dir\index.cfm
Path Info Java:
IIS: Microsoft-IIS/7.5
Path Info CF:
Path Info Java:
IIS: Microsoft-IIS/8.0
Path Info CF:
Path Info Java:
I did not check the same on IIS5.1, so this should probably be verified as well since CF10 is also supported on IIS5.1.
-Aaron
Updated: Added "And getPageContext().getRequest().getPathInfo() is always correct, regardless of IIS version."
Hi Anit,
Do you see the same? Just want to verify before logging a bug. Repro is simple..
itisdesign wrote:
Hi Anit,
Steps to Reproduce:
Btw, IIS7.5 and IIS8 are correct. And getPageContext().getRequest().getPathInfo() is always correct, regardless of IIS version.
Thanks!,
-Aaron
The behavior of CGI.PATH_INFO attribute will remain the same irrespective of the version IIS with ColdFusion 10.
And if you look at the screen shot below, the functionality is still the same in IIS8 as well for getPageContext().getRequest().getPathInfo().
Thanks!,
-Aaron
Anit Kumar
Hi Anit,
Sorry for the delay; I am on vacation. Did you check IIS6 and IIS7?
IIS6:
- CGI.PATH_INFO: /dir/index.cfm
- getPageContext().getRequest().getPathInfo(): [empty string]
IIS7:
IIS7.5:
- CGI.PATH_INFO: [empty string]
IIS8:
- CGI.PATH_INO: [empty string]
That is what I was trying to say. Sorry if there was any confusion. Should I log a bug for CF10's CGI.PATH_INFO in IIS6 & IIS7?
Thanks!,
-Aaron
I'm also getting [empty string]
CF 10,0,11,285437
Update Level | /C:/ColdFusion10/cfusion/lib/updates/chf10000011.jar |
IIS 7.5 w/ CF connector reinstalled
URL : http://localhost/test/test.cfm;lat=50;long=20;scale=32000
getPageContext().getRequest().getRequestUri() : /test/test.cfm;lat=50;long=20;scale=32000
related quesiton: http://stackoverflow.com/questions/19253722/is-it-possible-to-access-the-matrix-parameters-name-valu...
