Weird transaction issue with implicit struct (and possible array)
Feb 24, 2013 Feb 24, 2013
I have the following 2 files.
mycfc.cfc
<cfcomponent  output="false">
          <cffunction name="set" output="true" returntype="void">
                    <cfargument name="text1" type="string" required="true">
                    <cfargument name="something" type="any" required="true">
                    <cfdump var="#arguments#">
          </cffunction>
</cfcomponent>
mycfc.cfm
<cfscript>
          test = {firstName="Bob in line 2"};
          i=1;
          transaction {
     new mycfc().set(Text1:"hello",something:"Bob in text");
     i++;
     new mycfc().set(Text1:"hello",something:"Bob in text again");
     new mycfc().set(Text1:"hello",something:test);
     new mycfc().set(Text1:"hello",something:{firstName="Bob in line 9"});
     test2 = {firstName="Merry"};
     writeDump(var=test2,label="line 11" );
     new mycfc().set(Text1:"hello",something:{firstName="Jenny"});
     i++;
     new mycfc().set(Text1:"hello",something:{firstName="Jenny 2"});
          writeDump("i = #i#");
</cfscript>
If you run the mycfc.cfm, you will notice 4 weird things here.
1) new mycfc().set(Text1:"hello",something:test); should output "Bob in line 2", but is replace with "Bob in line 9"
2) my dump with label="line 11" is missing.
3) duplication of "Jenny 2", even you remove the writedump, you still get double "Jenny 2".
4) writeDump("i = #i#"); will give you "i = 2", which should be i = 3
This problem only happen when using transaction. It is happen to both CF9 and CF10
Advanced techniques
1.9K
Engaged ,
Feb 25, 2013 Feb 25, 2013
You shouldn't use the colon to separate argument name=value pairs.  It's undocumented, use = instead
should be
     new mycfc().set(Text1 = "hello",something = "Bob in text");
Apart from that I couldn't say for the other strangeness you're experiencing.  I've seen problems using inline structures being passed as arguments, try creating them as variables and passing those instead
Engaged ,
Feb 26, 2013 Feb 26, 2013
The colon _is_ documented and supported in CF10.
Thanks duncancumming.
I just found a workaround for that issue. That is if I don't use the argument name, the problem go away...
<cfscript>
          i = 1;
          transaction
                    new mycfc().set("hello", "Bob in text");
                    i++;
                    new mycfc().set("hello", "Bob in text again");
                    new mycfc().set("hello", test);
                    new mycfc().set("hello", {firstName="Bob in line 9"});
                    writeDump(var=test2, label="line 11");
                    new mycfc().set("hello", {firstName="Jenny"});
                    i++;
                    new mycfc().set("hello", {firstName="Jenny 2"});
</cfscript>
Feb 28, 2013 Feb 28, 2013
I had a look at this, and it's a variation of a bug we (Duncan: you and I) experienced a while back, and that Brad Wood helped me lock down to a decent repro case. I blog about this current example - with links to various bugs and older blog posts - here: http://adamcameroncoldfusion.blogspot.co.uk/2013/02/another-serious-struct-literal-syntax.html
It's more serious (well: less of an edge-case, anyhow) than this example makes it look.
Adam
Documentation
