I need to transfer my CS6 upgrade and, I assume, my original CS5 Windows versions of Photoshop to my new laptop that has no disc drive. This feature takeaway is increasingly common in new laptops, so I thought this would be an easy search, but I got nothing. Anyone out there know a practical way that doesn't involve ripping a disc? If ripping a disc is my only option, then what is the easiest and cheapest way to do that?
Just download the Photoshop CS6 trial and install it. You don't have to have the previous version of the software installed. When you don't have the previous version installed, you are asked to enter the serial number for your previous version to verify.
If you already have the upgrade disks from adobe then you could buy a USB version of DVD drive and this can be used to install your software. Alternatively, if you have access to a machine with the CD/DVD drive then you can copy the entire CD/DVD to a USB flash/Pen drive and use this to install your software.
However, I always thought that Adobe normally provide downloadable upgrade programs and if this is so then log into your account and see if there is a link to download the software.
Trial software won't be of any use because your Key must be for upgrades and not full version.
Hope this helps.
Not sure what that means.
You can download the Trial version, enter a CS6 upgrade serial number then a CS5 serial number (upgrade or full) and the software will be licensed.
Another option is to put the disc in a drive in a computer you have on your local network, then access it through the network.
Surely you have such a system handy. If not, I'm curious: Did you think about this before you bought a computer without a disc reader?
-Noel
Noel,maybe the computer was a gift....That part of your answer was very rude.
Noel hasn't contributed to the forum in many years. Yes, some of his comments can seem abrasive, but he is extremely knowledgeable with PS, and his input is missed.
If you want to put CS6 on the new computer just download the trial and type in the serial number, or re-download. When asked for qualifying product type in s/n of CS5. You do not need cs5 on machine unless you want it there to use.
I find it hard to believe that your new laptop has no disk drive. I can not believe it boots off some network device. It is quit normal to download or copy Photoshop installation files to a Laptops internal hard disk or ssd using an external DVD or network shared. Then install Photoshop from the copied or downloaded installation files. I haven't installed Photoshop from CD or DVD in many years. Normally you do not need to copy prior versions of Photoshop to do an upgrade. You will need to be able to enter your upgrade eligible version of Photoshop serial number.
I think the idea of network computers without disk drives went out vogue many years ago it was a concept that never took off.
"Disc" is not the same as "disk" as used in this context, JJ.
I believe he's speaking of an optical drive, such as what you might put a CD or DVD or BluRay disc (note: spelled with a c) into.
-Noel
Does it make any difference Optical Disk CD, DVD, BluRay, memory stick, hard disk, sd, solid state disk, flash menory etc all contain File systems some removable media may be read only. Applications are installed from files they can be local or remote. As long as the laptop can connect to a network applications can be installed into its file system where ever it may reside as long as it is read/write and has the required free space.
You may still be missing the point. The machine of course HAS a disk drive, on which gyhstnnnr can store files and install applications. He's asking how to install applications for which he has optical disc media, without the machine having an optical disc reader (which he called a disc drive). And of course the questions have already been answered.
-Noel
I have to admit that I knew what they meant by when they started this thread. They also more or less answered the question posed by stating that their configuration is a common configuration these days. It not unseal at all. If it was not possible to install applications on such a system it would be a very unseal configuration and would not sell. Often users ask questions without putting any thought into the matter. All I was trying to do was to jar their gray matter.... If they has install Photoshop from a DVD on their old machine and now want to transfer Photoshop from their old machine they still have their old machine and the optical disk drive they used to install from. All they needed to do IMO was to use a little of their gray matter.
I have just purchased a beast of a windows laptop, 2 grand, beautiful and no disc drive, loads usb3, thunderbolts and others!!
Plug in DVD drives are an essential add on for your beast unless you are happy for all your valuable software on CD to become coasters. Yes, you can download some, but that’s not the point: just because computer makers choose not to offer an optical drive doesn’t make us helpless.
You can only have 2 copies installed at once, so you should deactivate the software from the old computer first.
To deactivate the software from your computer:
To install the software on the new computer:
I just followed this process over the past 2 days, moving CS6 from an old Macbook that had a disc drive, to a new Macbook Pro that does not have a disc drive. I wasn't able to install directly from the USB stick from some reason, but that might also be possible. For my case, once I copied all files to the the new laptop and installed from there, it worked.
~Ken
