CS6 Bridge/Win 7 freezes
Jun 05, 2012 Jun 05, 2012
First week or so of using Bridge CS6 all went well, now having lots of slow downs/freezes/delays that eventually clear up (when browsing a folder of files). Once I'm able to open a file in ACR performance is fine, but this is making Bridge unsuable for workflow. Is this a known problem and is a fix coming?
JW
18.2K
Add this to the problem, even clicking on drop down menus causes bridge to freeze & eventually come back to life...
Guest
Not a known problem.  My first guess would be interference with your anti-virus program.  Try disabling it temporally and see if that corrects the problem.  If it does you need to contact software co.
No luck wioth AntiVirus diable, though I did begin to notice this after update to new version of ACR (not sure if that's relevant).
Any interaction  (mouse click, keyboard arrow movement to next image, right click to open ACR) causes delay - about 6 seconds - then not repsonding message - then it evetually clears (seems to also depend on amount of images in folder).
Bridge that came with CS5.5 is working well...
Guest
You say it worked well the fist week.  What have you added, changed since then.  Major updates, software, hardware additions?
Also, check you space on HD.  Should have 10-20 % free space to work well.
Do you have seperate drive for cache?  If you have HQ thumbs enabled and save 100 % previews that can eat up a lot of space in a weeks time.
No major updates (only update was ACR)
HD free space 30-35%
Am unable to designate separate drive for cache (Bridge only lets me point to C:/Users...AppData etc.)
Turned off 100% previews & cleared cache, no change.
Guest
So in edit/preferences/cache when you try to change drive to different location is that option grayed out?
Are you running on a network?
It's not grayed out, but there are no other choices for drives (just desktop on C drive), it's attached to a network but all drives I work off of are local, none shared.
Jun 07, 2012 Jun 07, 2012
I've had the same issue with windows 7 x64
Bridge CS6 (32 bit and 64 bit) hangs when opened for 20-30 seconds. Every operation after that (even clicking on the file menus) results in the same delay.
More than one operation (ie clicking on an image then trying to navigate to a folder) causes teh window to "white out" and show a "not responding" status in the title bar.
Mini-bridge in photoshop is the same.
I've tried updating the app, disabling scripts, editing ACR settings, running as admin, checking temp file paths, disabling antivirus/anti-spyware, checking firewall settings, pulling out hair, doing a rain dance, voodoo dolls and uninstalling/cleaning/re-installing the suite (production premium trial)
No effect at all
Bridge CS6 sucks right now. Please fix it Adobe
Please?
I use CS5.5 as it is and bridge is an essential part of my workflow.
I have managed to figure out a work-around though. I run the program in compatibility mode for Windows Vista (any version) and it runs fine
Jun 08, 2012 Jun 08, 2012
Thanks - Will give that a try, or use 5.5 (it's also essential or me workflow-wise),
Guest
Please?
I know the pain of buying a program and then not having it work.  But for Adobe to fix a problem it must first be identified.  Then it must be reproduced on Adobe's computer so fixes can be written and tried.  And it looks like you have tried  everything I can think of.
At this point all that is known is that the program does not work on a least 2 machines.  It could be something in the OS that is not playing fair as in AppHangTransient.
Inakretep, do you also have AppHang Transient error?
If you narrow down problem be sure to post back.
I have completely abandoned LR because of similar - and actually worse performance - though I may try compatibilty mode with LR even though there are other UI issues that won't take me back to using it. Interesting to see if this could solve LR browsing speed issues.
Guest
Sometimes weird problems are solved by establishing a new user account.  You might try this, as sounds like everything else has been tried.
Here is a link on how to http://helpx.adobe.com/x-productkb/global/create-local-administrator-account-windows.html
Compatibility mode seems to have fixed both Bridge and Lightroom.
Guest
That is really weird as Abobe says Vista is not supported in CS6.  But hey, if it works go for it.
Jun 15, 2012 Jun 15, 2012
I tried Setting the Compatability Mode to "Vista (SP2)" and it seems to have fixed the problem.
I am going to clean out all the caches and recache just to make sure.
Guest
Jul 02, 2012 Jul 02, 2012
Have you had any luck finding a fix for your CS6 Bridge?  I have the same problem.  Have you tried the Compatibility Mode "fix"?  If so please let me know how that worked for you.  Thanks!
Guest
I've had no success with any compatibility mode with Bridge.
Jul 03, 2012 Jul 03, 2012
I read in another post (either here or another site) to disable TIFF Support in the Camera Raw Settings. That coupled with the compatibility mode and perhaps clearing the Bridge Cache may work out.
Guest
This is what worked:  I re-installed CS4 and use that Bridge.  Of course I need to change the "file extension associations" to CS6 from CS4.  Works great...feels like a weight has been lifted off.  Hey you people are more helpful that Adobe Support - pretty much a waste of time, but hey I got a case number!...thanks much..........
That's a disappointing but helpful answer. Anyone from Adobe on this yet?
Feb 01, 2013 Feb 01, 2013
I have been having exactly the same problems as this and have given up on using bridge until I read this. I have set mine to run in compatibility mode for vista (service pack 2) and am delighted that it is running perfectly normal now. Thank you so much for this workaround. I find it amazing that Adobe haven't addressed this problem after the length of time people have been having severe problems using it. Poor show Adobe.
Guest
The CS6 compatibility mode solution did not work for me.  I reinstalled CS4 and use CS4 Bridge - it works fantastic.  The down side of this is that I can't start batches from CS4 Bridge to run the job in CS6 Photoshop.
Mar 06, 2014 Mar 06, 2014
We facing the same problem with Bridge CS6 and Windows 7 (64bit). Could you solve the problem?? We don't know what to do.
