This Message appears after clicking on the icon after installing from creative cloud. Can't try installing again as AAM says that it is already installed.
Installed on iMac OSX 10.6.8
After several days of this annoying me and trying various different things, I finally found the solution!!
Open Terminal and run this command and it will reset the launch services to let it work properly.
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/Support/lsregister -kill -domain locat -domain system -domain user
The problem began for me once I removed photoshop because the update kept failing. So I uninstalled photoshop cs6 using th
...Copy link to clipboard
Please try uninstalling with the uninstaller located in Applications/Utilities/Adobe Installers. If you have the same problem again then please try downloading and installing the trial of Photoshop CS6. Once the trial is installed you can choose the License This Software option and enter the Adobe ID tied to your Creative Cloud account.
Hi Jeff,
Was in the same situation and this advice worked for me.
I have installed it as a trial yet am unable to find the License This Software" option.
Could you please inform me where within Photoshop this option is located? (iMac 10.8.1)
Aarron
Close and re-open PS CS6 and then check if you get that option or not. If not, goto Help Menu and check is Deactivate option is greyed out or not. If it's not greyed out, it means your PS CS6 is activated. No need to worry.
Just relax and enjoy the application.
The problem began for me once I removed photoshop because the update kept failing. So I uninstalled photoshop cs6 using their uninstall script, and then re-installed it with the creative cloud application manager. From then on I could not "double click" on a .PSD to open photoshop directly, but "open with" would work. Very strange.. but the above command fixed it.
Here are some screenshots of the issue:
In the post it looks like the command is on two lines, but it's not. It's on one line.
