Locked
Need Detailed description of the differences between Adobe Flash Player Plugin and Shockwave Flash
May 21, 2012 May 21, 2012
For many years now I have been in a quandry over Adobe Flash (plugin) and Shockwave flash. The quandry is also somewhat exacerbated by the variety of subsetted versions supplied for each.
You know, it is sorta like the name and namespace dilemna provided by Adobe's continuing use of "Macromedia" when sometimes referring to, or distributing, their products... eg still creating Macromedia folders during installs.
I have been told that Shockwave Flash actually contains the Flash plugins. If that is the case should I be upgrading to a newer Shockwave Flash version if  Adobe announces or (as recently occurred) denounces
a newer version of Adobe Flash.
Will you please provide me with details for, and distinctions between, these two products?
Hoping you can respond in a flash ... er... two flashes.
5.3K
May 22, 2012 May 22, 2012
Shockwave Flash == Flash Player.
Flash Player is a browser add-on that consists of two components:
  • Flash Player ActiveX control for Internet Explorer
  • Flash Player plugin for all other browsers
There is also another product from Macromedia: Shockwave Player, a completely different tool.  Not as widely used as Flash Player.
May 23, 2012 May 23, 2012
OK Thanks I silly-goofed in describing what I meant in my initial post. I needed to say what's the diff between Adobe Flash (=Shockwave Flash) (plugin) and Adobe Shockwave Player.
So will you please detail the differences between Adobe Flash (=Shockwave Flash) and Shockwave Player?
I have been told that Shockwave Player actually contains the Adobe Flash (=Shockwave Flash) plugins. Is it both
that are contained therein?
If the above is indeed the case, should I be upgrading to a newer Shockwave Player version if  Adobe announces or (as recently occurred) denounces a newer version of Adobe Flash (=Shockwave Flash) .
Here's where I am headed will all this:
I have been asked by one of your coworkers Chris Campbell,  to prepare an Adobe Bug report and paste back to the Adobe Forum thread:
http://forums.adobe.com/message/4428382#4428382
Since I have Adobe Shockwave Player 11.6.4.634 and Adobe Flash (aka Adobe Shockwave Flash) ver 11,1,102,55 currently installed and since
Adobe Flash 11.2.202.235 will not install without a "...The  procedure entry point ... kernel32.dll ..." error for my Windows 2000 Professional configuration
I want to uninstall Adobe Flash (=Shockwave Flash) ver 11,1,102,55 and the then further troubleshoot the MLB.TV media player "abnormal spinning circles" problem.
Will the MLB NexDef detector actually detect the "Flash version inside Shockwave player"?  Will the MLB.TV NexDef software actually work nicely with Shockwave Player Flash?
First, to clarify: I am not an Adobe employee, just a volunteer in these forums.
Regarding Shockwave Player: no, it does not contain the Shockwave Flash plugin.
And about the Windows 2000 install problem: see this topic, especially towards the end http://forums.adobe.com/thread/965334
May 25, 2012 May 25, 2012
Pat
Thanks again,
First of all the link you provided http://forums.adobe.com/thread/965334 is just great. It is so interesting; and spot on!
It has helped me understand not only why the Adobe Flash Adobe Flash 11.2.202.235 will not install without a "...The  procedure entry point ... kernel32.dll ..." error for my Windows 2000 Professional configuration. The discussion thread makes me want to talk once again with Microsoft about their Microsoft Update "redistributable C++" security patch problem. They have a generic http://support.microsoft.com/kb/142606  kicking around out there with the error:
"... The procedure entry point SomeProcedureName could not be located in the dynamic link library KERNEL32.dll ..." that led me astray a bit and that's when I verified an overlooked aspect for W2KP users on the C++ redistributable (patches) security updates.
On my W2KPSP4, I try to set all my installs within my Visual FoxPro 9 database by calling binary (or blob) memos of install exes or 7-zipped installed packages.
I call and run with my embedded VFP code on the same record. I think I am going to try your Item #21 entry in the aforementioned link and give it a go after a few more careful rereads of the discussion. Wish me luck!
Chris Campbell has also been helping us with concomitant MLB.TV problem
So ... when I was getting emails from you both showing up, one after another, I mistakenly thought you were both Adobe employees.
Hope Adobe really appreciates your input to the forum.
Adobe Employee ,
We do!!  Pat has been an invaluable asset to this community!
Jun 04, 2012 Jun 04, 2012
Update :
I have now written a VFP stored procedure to sequentially call the hack components- HxD Hex Editor  and the 11.2.202.235 executable, edit/save the hex edit of the exe file and then run the install  of 11.2.202.235 exe successfully
Mar 14, 2013 Mar 14, 2013
I am so confused. I have a laptop with windows 7 and sometimes i use internet explorer and sometimes google. Although google has been really confusing me lately. Am I to understand that there is not just ONE flash player that will work for all IE, google, firefox, etc.? So if I download the flash while in IE and then try to go to the site I want in google, will I get a message saying that I do not have the flash player plug in installed? This is the message I get and I have downloaded flash player about 5 times in the past few days.
Just off the subject my curser has been jumping all over and moving to other text I have already typed while I am typing. so constantly I have part of the word I am typing moved somewhere else on my page and I have to go up and correct that word as well as move curser back down to my latest point and make a correction there. as soon as i start typing again for awhile it will do the same thing again. Any ideas.
I am not a computer whiz, just trying to chug along and do the best I can with my novice knowledge. Thank you
Google Chrome comes with Flash Player preinstalled; you don't need to install it.  Update Chrome to update Chrome's Flash Player.
how do I update chrome? I am pretty sure that it is but tell me anyway. thank you
Sandra J. Barrientos
[private data removed]
I have been having some issues with google/chrome lately. It seems like I keep getting myself more involved with stuff when I am on google that I don't need to even be messing with so I end up with my computer a mess and more confused. I find IE much more simple to use or else I am just very familiar with it. If I want to use IE what can I do plus I can not even log into my site on google chrome. It keeps saying my password in incorrect but on IE I am able to log in it just says I do not have the flash plug in. Is plug in different from just flash?
This is a public forum; please do not post your email address and other private data (by sending the entire forum notification message with all its headers back to the forum).
See my reply in your other topic.
