Hi
I am trying to create "accessible" PDF for which I need to add tags in my FrameMaker document. However, I noticed that I need to create this tags list every time I save the FM book as a PDF. Is there a way I can save these tag settings? I have some 50+ tags and structuring it every time is a very time-consuming task.
Sreekanth
Hi Sreekanth
The PDF settings are saved in the FrameMaker document. Please make sure that you save the document on disk after generating PDF.
Harish
It works at the document level. However, I am creating the entire book as PDF. So, I want these settings to be saved at book level.
I seem to remember a discussion about this on the framers list – the job options settings for bookmarks, etc. are attached to the first file of the book. I don’t remember if you need to somehow import them for all documents in the book or not.
Hi Sreekanth
Don't know if you got this sorted or not but see this discussion:
http://forums.adobe.com/message/5534831#5534831
Laura
