We use Adobe FDK to convert Frame files to XML and pass it as an input to another client. With FDK10 in Visual Studio 2008, the Raw XML was created with no errors. But, in FDK11 with Visual Stduio 2010, the Raw XML gets created fine but every created node is validated against some schema and throws XML parser error in the Error console. This validation brings down the performance of the customized client we use. Suggest me if there is any option to fix the issue or a way to disable the system default XML validation.Also, attached the error console for more details.
Venkat
Any help on this issue would be highly appreciated...
Are you just looking to turn it off? Isn't that just in the Prefs about displaying UI messages or something?
The console that Venketraja is talking about is a "pod" in the Structured mode only and is unfortunately mis-named to be the same as the FrameMaker Console. This "console", AFAIK, can not be turned off in the current implementation of FM11. It has been discussed elsewhere, so Adobe engineering is aware of this issue.
@Venketraja, please file a bug report on this indicating that the inability to turn this off is drastically impacting performance. File it here:
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform&product=63
You could also ask in the Yahoo Frame Developer's Forum, in case anyone ese has come up with a workaround. See: http://groups.yahoo.com/group/frame_dev
