Adobe Photoshop CS6 Extended is installed on my HP laptop. With the disk and installation code in hand, am I permitted to install the program on my second, smaller (and lighter) computer; a Toshiba.
You are allowed to have activated installs of the software on two machines. The limitation is that you cannot use the same application on both machines at the same time.
Which means that all I need to know is ... how to do that. The CS6 disk does not load so having the product code and serial No's is not a lot of help. On chat I was directed to make contact tomorrow...which I shall do...unless.. oldmaned
If the disk will not load, then download the trial version from the Adobe site and use your serial number to activate it.
thank you very much!
You're welcome
