Specs
See pasted text from CSV at http://pastebin.com/mymhugpN
I am using InDesign CS6 (8.0.1)
I created the CSV by downloading it from a Google Spreadsheet as a CSV. I confirm with the Terminal that the character encoding is utf-8 usnig the file command.
Problem detailed
I am trying to import a CSV file (utf-8) with Data Merge via the Select Data Source... command with Show Import Options checked. When viewing the Data Source Import Options dialog, I set the following options—Delimiter:Comma, Encoding:Unicode, Platform:Macintosh. I leave Preserve Spaces in Data Source unchecked. It fails to import any variables and produces no error message. I have tried other CSV files as well (created TextEdit, Espresso, etc.) and it seems that InDesign will not import any files if Unicode is specified as the encoding, no matter which other options are specified.
Can anyone else confirm this?
Importing as ACSII works, but obviously does not display my content correctly.
Obviously? What's obvious? What isn't being displayed correctly? I'm not sure that pastebin supports non-ascii characters, but I don't see anything in the paste in a quick look that should be a problem if the file is saved in ascii format.
If you want someone to test the file to see the results we'll need a link to a sample file.
It can be any valid unicode CSV file. One column or seven columns, one row or fifty rows, just alphabetic letters or numbers or unicode-only characters... it doesn't matter. None of them will import if Unicode is selected in the Data Source Import Options dialog.
Use what's in the pastebin link or copy and paste this into a new text file and save it as a utf-8 CSV and test:
Variable 1,Variable 2,Variable 3
John,Kevin,yes
Marsha,Jan,no
Roger,Bridget,no
Stephanie,Larz,yes
(And pastebin does support unicode characters—there are several left- and right-double-quotes in my example.)
I'm not going to claim to be an expert on file encodings, but if I copy your text and save in Notepad (I'm a windows User) as UTF-8 I am presented with the following error:
If I susbsquently open in Excel and remove the added characters before the text in the first cell (Which I presume are the UTF-8 binary tag) I am able to load the file as ASCII and do the merge.
I also tried saving as Unicode text instead of UTF-8 in Notepad, and that works fine. As I say, I'm not expert in file encoding, but I think you may be under a misaprehension that UTF is Unicode encoding, and it simply is not a format that ID will read for Data Merge.
Perhaps it is a problem with the Macintosh version.
I don't think so. I think it's a problem with UTF -8 encoding. Can you save as a different flavor of unicode from Google?
I've had a similar problem with text that was generated on Filemaker Pro for Mac. Drove me INSANE. Was with a former employer and has not been an issue since, but I had a somewhat clumsy workaround:
I haven't really investigated what was going on as the job was always red-hot urgent, and I haven't been able to replicate the fault as I don't have Filemaker Pro. If anyone reading would like to try this, have at it!
Google Drive only supports one format for exporting to CSV. I've tried converting the exported file to utf-8, utf-16—no dice. The best I can come up with is to import a unicode file as ASCII and then Find & Replace all out of range characters that were modified (sometimes lots of different characters, depending on the content).
Waht about opeing the UTF-8 file in Text Edit or Text wrangler and resaving from there as Unicode?
I had no problem importing your data as either .txt or .csv. Granted I run CS5.5 but am also on a Mac and it went smoothly. I basically copied your data to TextEdit, saved and then imported through Data Merge. To get the CSV I opened that text in Excel and output as comma de-limited CSV.
It looks like your data (in PasteBin) has 2 different encodings, or at least has been created by 2 different software programs or maybe computers. You can see this in the text:
As you can see, there are two different quotation marks going on - the first looks like it's been copied straight from Word and the second looks to have been generated by a text or HTML program. This is also a common problem with websites when people supply text in Word/Excel and copy straight into HTML - those characters get messed up.
Run a Find and Replace on the first set of quotes in that text and the file should load with no problem.
I think this is the problem, that my content requires all of these characters. UTF-8 supports it, but InDesign won't seem to read UTF-8.
I downloaded your sample. As per my editor of choice, it shows it is UTF-8 format:
After setting up ID to merge it:
Seems to work just fine. Unless I am missing something.
Take care, Mike
What editor are you using?
Hi Peter, UltraEdit. Been using it since the mid 1990s for programming and then later, for HTML, PHP and what not.
As regards this issue, UE will preserve the BOM with UTF files if it is set to do so (and not convert them to the OS' format). Which is how I have it set. If one sees the odd characters at the beginning of a file, it is due to conversion to the OS format one is using. Otherwise the BOM is hidden from view.
Down towards the bottom of their page linked below explains the BOM if anyone cares. For UTF files it is necessary that these be preserved.
http://www.ultraedit.com/support/tutorials_power_tips/ultraedit/unicode.html
Take care, Mike
Thanks.
Did you set it up the exact way I described? What is your InDesign version number and on which platform?
Sorry, been away at a weekend golf tournament. Tried to reply with my phone but up in the mountains I waas cut off on both reply attampts.
I am using CS6.
Your file is a UTF-8 ASCII file. If you want Unicode, it will be a UTF-16 file and as long as you are using Western languages, you really should be using the UTF-8 ASCII.
If you create a UTF-16 format CSV file, you will see that ID automatically determines it is the Unicode import type. Now, they are both Unicode (UTF-8 and UTF-16 that is). But to ID, I think the UTF-16 format(s) are used specifically for non-Western languages, or certainly a mix of Western and non-Western languages.
At least that's what I find.
When I import that utf-8 file as Unicode, nothing imports. When I import it as ASCII, I get various character conversions, such as
“ becomes ‚Äú
” becomes ‚Äù
’ becomes ‚Äô
… becomes ‚Ķ
– becomes ‚Äì
and so on...
Is this the file you uploaded to pastebin? Frankly I do not see those characters listed in post 18 in that file. If the missing characters you list in post 18 are suppose to be in the text, try creating a ZIP file of the text (both the .txt and the source Google Doc spreadsheet, maybe saved as an Excel or other spreadsheet type) and posting it somewhere like dropbox. Then provide a link.
The reason it will not import as Unicode, I believe, is that it is a UTF-8 file and is considered as ASCII for import.
Mike
The source data never existed as a .txt file. It was typed directly into a Google Spreadsheet. Here is a link to a zip containing the originally-downloaded .csv from Google Docs and then a utf-16 version that I converted using TextEdit on OS X.
Ok. I think that we aren't getting anywhere quick at my end. I still do not see any upper-range characters in your file(s).
I went to a web site and copied a bunch of characters and made a table. I added dollar signs where their characters were missing. But I think it illustrates that if the file is set correctly, ID automatically picks the proper format for import.
And the result when merged into a new file:
Converting the source records as an ANSI text file, and importing it, ID chooses:
And the resultant merge equals:
Mike
I downloaded the sample files, and I get the same character mapping issues. I wonder if this might be font-related. Is the font in Google spreadsheet really unincode compliant, or is it some older font that has Windows -Mac character mapping differences?
Google Doc export of the above here:
http://www.wenzloffandsons.com/temp/google_doc_export.csv
It is a UTF-8 ASCII.
Which means if you import it allowing ID to set the import type (Ascii) then it works fine.
Want me to ZIP up a Unicode (UTF-16) version? ID will then automagically pick Unicode for the type and the imports will be identical.
Mike
Mike is having some trouble posting in this thread (and I am too), but he sent me a PM with what he wanted to say:
OK. I think I might have a positive answer for you.
I was getting lost in the upper ASCII characters you showed. In your test file I never could see any--a case of not seeing the trees for the forest.
Your quote marks are getting dropped in your test file. Now, this may or may not affect other factors but it does in some further testing. I believe ID has an issue with dropping quote marks even in a plain ASCII file if the marks are at the beginning of a sentence and the file is tab delimited. Call it a bug.
Because of all the commas and quote marks in your simple file, I think you should be exporting from Google Docs' spreadsheet as a tab-delimited file. This exported file has to be opened in a text editor capable of saving it out as a UTF-16 BE (Big Endian) type of file.
Also, I think you are going to have to use proper quote marks throughout, or change them in the exported tab-delimited file. Best to have a correct source, though.
Here is your sample ZIPped up. I think it works properly. But then again, I think I might be bleary-eyed by now.
http://www.wenzloffandsons.com/temp/merge_psalms_utf-16.zip
Take care, Mike
