First of all let me give you a screenshot of my home PC (running CF10 Developer on Windows 7 x64), as even this page looks different than CF servers we have at work where the update was applied with no issue.
I have tried clicking on DOWNLOAD and DOWNLOAD AND INSTALL and neither do anything. Upon loading the page, I used Firebug and checked the console. It has multiple entries of:
Uncaught ReferenceError: ColdFusion is not defined
(Truth be told I don't Firebug check the CF Admin page often, so I don't know if this is normal. Many times Adobe's admin pages don't use standardized practices, but I just want to put this out there)
I'm familiar with how to manually install updates, but I cannot find a place where Adobe offers manual download of the CF10 Update 8. Can anyone shed some light?
This seems to be a permissions issue or you may be behind a firewall/Proxy server. Please check the permissions on the CF install folder.
Here is the link to download CF 10 Update 8 http://download.adobe.com/pub/adobe/coldfusion/hotfix_008.jar
Anit Kumar
Hey Anit, thanks for your response.
I'm not much of a networking guy (don't understand user rights and what not), but I checked the rights on my CF root folder and here are the users on it: (I am on Win 7 Pro x64)
AUTHENTICATED USERS (Modify and below)
SYSTEM (Full Control)
ADMINISTRATORS (LOCALMACHINE\ADMINISTRATORS) (Full Control)
USERS (LOCALMACHINE\USERS) (Read & Execute, List Folder Contents and Read)
We're not behind a proxy, but I am behind a firewall (and we currently have an issue with JUST ME where every 3 hours, the firewall forgets who I am and requires me to re-authenticate to get to the internet) That is being worked on.
I will download and manually apply the Update 8. Thank you very much for the link.
I manually installed the update and now ColdFusion Application Server Service cannot start. I asks me to check the Event Viewer, which reports back the following:
The description for Event ID 259 from source ColdFusion 10 Application Server cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Can you try starting the services from command prompt.
Anit Kumar
I ran:
net start "ColdFusion 10 Application Server"
and it returned:
The ColdFusion 10 Application Server service is starting..
The ColdFusion 10 Application Server service could not be started.
A service specific error occurred: 2.
More help is available by typing NET HELPMSG 3547
Hi Aegis,
Sorry for the delayed response. Can you please share the Update log file with us.
Anit Kumar
I searched all over Google and could not find any articles which indicate where the "Update log" is. Can you provide me with a path?
I think I found what you were looking for:
/cfusion/hf-updates/hf-10-00008/Adobe_ColdFusion_10_Update_8_Install_03_27_2013_19_47_18.log
Here is its contents
__________________________________________________________________________
Wed Mar 27 19:47:34 EDT 2013
Free Memory: 26501 kB
Total Memory: 46700 kB
java.class.path:
hotfix_008.jar
ZGUtil.CLASS_PATH:
hotfix_008.jar
sun.boot.class.path:
C:\Program Files (x86)\Java\jre7\lib\resources.jar
C:\Program Files (x86)\Java\jre7\lib\rt.jar
C:\Program Files (x86)\Java\jre7\lib\sunrsasign.jar
C:\Program Files (x86)\Java\jre7\lib\jsse.jar
C:\Program Files (x86)\Java\jre7\lib\jce.jar
C:\Program Files (x86)\Java\jre7\lib\charsets.jar
C:\Program Files (x86)\Java\jre7\lib\jfr.jar
C:\Program Files (x86)\Java\jre7\classes
java.ext.dirs:
C:\Program Files (x86)\Java\jre7\lib\ext
C:\Windows\Sun\Java\lib\ext
java.version == 1.7.0_15 (Java 1)
java.vm.name == Java HotSpot(TM) Client VM
java.vm.vendor == Oracle Corporation
java.vm.version == 23.7-b01
java.vm.specification.name == Java Virtual Machine Specification
java.vm.specification.vendor == Oracle Corporation
java.vm.specification.version == 1.7
java.specification.name == Java Platform API Specification
java.specification.vendor == Oracle Corporation
java.specification.version == 1.7
java.vendor == Oracle Corporation
java.vendor.url == http://java.oracle.com/
java.class.version == 51.0
java.compiler == null
java.home == C:\Program Files (x86)\Java\jre7
java.io.tmpdir == C:\Users\amartone\AppData\Local\Temp\
os.name == Windows 7
os.arch == x86
os.version == 6.1
path.separator == ;
file.separator == \
file.encoding == Cp1252
user.name == amartone
user.home == C:\Users\amartone
user.dir == C:\Program Files (x86)\Java\jre7\bin
user.language == en
user.region == null
Installed Feature(s) Standard, J2EE of Adobe ColdFusion 10 Update 8
Install Begin: MARCH 27, 2013 7:46:23 PM EDT
Install End: MARCH 27, 2013 7:47:25 PM EDT
Installed by InstallAnywhere 14.0 Enterprise Build 4349
User Interactions
#Choose ColdFusion 10 Home directory
USER_INSTALL_DIR=C:\\server-root\\app-root
Summary
Installation: Successful.
127 Successes
0 Warnings
0 NonFatalErrors
0 FatalErrors
Action Notes:
None
Install Log Detail:
Check Disk Space:
Status: SUCCESSFUL
Additional Notes: NOTE - Required Disk Space: 15,637,203; Free Disk Space: -1
Modify Text File - Single File: New File C:\Program Files\cfhotfix.txt
Status: SUCCESSFUL
Custom Action: com.adobe.utils.HotFixProps
Status: SUCCESSFUL
Get Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Install Data\Adobe ColdFusion 10
Value Name: CFMXRoot
Status: SUCCESSFUL
Custom Action: com.adobe.ia.customrule.DocRootValidate
Status: SUCCESSFUL
Status: SUCCESSFUL
Custom Action: com.adobe.ia.customrule.ReadXML
Status: SUCCESSFUL
Custom Action: com.adobe.ia.action.UpdatableInstances
Status: SUCCESSFUL
Status: SUCCESSFUL
Custom Action: com.adobe.ia.action.VersionCheck
Status: SUCCESSFUL
Stopping Windows Service: ColdFusion 10 Jetty Service
Status: SUCCESSFUL
Stopping Windows Service: ColdFusion 10 .NET Service
Status: SUCCESSFUL
Stopping Windows Service: ColdFusion 10 ODBC Server
Status: SUCCESSFUL
Stopping Windows Service: ColdFusion 10 ODBC Agent
Status: SUCCESSFUL
Custom Action: com.adobe.ia.action.ServersStartStopAction
Status: SUCCESSFUL
Stopping Windows Service: ColdFusion 10 Application Server
Status: SUCCESSFUL
Execute Command: C:\server-root\app-root\cfusion\bin\coldfusion stop
Status: SUCCESSFUL
Custom Action: com.adobe.utils.InstallDateTime
Status: SUCCESSFUL
Check Disk Space: C:\server-root\app-root
Status: SUCCESSFUL
Install Directory: C:\Users\amartone\668058.tmp\
Status: SUCCESSFUL
Additional Notes: NOTE - Directory already existed
Delete File: Source:cfhotfix.txt
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\update.xml
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\updates.xml
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\bin\cf-startup.jar
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\bin\cfcompile.bat
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\bin\cfcompile.sh
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\bin\cfinfo.bat
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\bin\cfinfo.sh
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\bin\coldfusion.exe
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\bin\coldfusionsvc.exe
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\bin\msvcr100.dll
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\lib\ib6core.jar
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\lib\ib6http.jar
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\lib\ib6swing.jar
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\lib\ib6util.jar
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\runtime\lib\tomcat-coyote.jar
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\runtime\lib\wsconfig.jar
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\_win32\bin\coldfusion.exe
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\_win32\bin\coldfusionsvc.exe
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\_win32\bin\msvcr100.dll
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\_win32\lib\cfperfmon_10.dll
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\_win32\lib\cfregistry.dll
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\_win32\lib\CFWindowsLogin.dll
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\_win32\lib\CFXNeo.dll
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\_win32\lib\DDJDBCAuth05.dll
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\_win32\lib\NeoUUID.dll
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\_win32\lib\PerfmonClient.dll
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\cfusion\_win32\lib\TypeViewer.dll
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\updates\chf10000008.jar
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\adminapi\administrator.cfc
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\adminapi\security.cfc
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\Application.cfm
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_scheduledtasks.cfm
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\controludfs.cfm
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\debugging\index.cfm
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\scheduler\scheduleedit.cfm
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\settings\version.cfm
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\updates\Application.cfm
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\updates\download.cfc
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\updates\index.cfm
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\updates\installer_input.cfm
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\updates\_sysinfo.cfm
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\administrator\updates\_updates.cfm
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\componentutils\cfcexplorer.cfc
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\scripts\ajax\ext\map\GMapPanel3.js
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\scripts\ajax\ext\map\mapiconmaker.js
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cflayout.js
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfmap.js
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfwebsocketCore.js
Status: SUCCESSFUL
Install File: C:\Users\amartone\668058.tmp\dist\wwwroot\CFIDE\scripts\ajax\resources\cf\map\marker.png
Status: SUCCESSFUL
Move Folder: Destination: C:\Users\amartone\668058.tmp\dist\cfusion
Status: SUCCESSFUL
Install Directory: C:\server-root\app-root\
Status: SUCCESSFUL
Custom Action: com.adobe.utils.Logger
Status: SUCCESSFUL
Custom Action: com.adobe.ia.action.InstallData
Status: SUCCESSFUL
Custom Action: com.adobe.utils.XMLUpdate
Status: SUCCESSFUL
Custom Action: com.adobe.ia.action.UpdateConfigs
Status: SUCCESSFUL
Execute Command: regsvr32.exe /s C:\server-root\app-root\cfusion\lib\TypeViewer.dll
Status: SUCCESSFUL
Install Directory: C:\server-root\app-root\cfusion\hf-updates\hf-10-00008\uninstall\
Status: SUCCESSFUL
Install Uninstaller: Adobe ColdFusion 10 Update 8(Install All Uninstaller Components)
Status: SUCCESSFUL
Status: SUCCESSFUL
Custom Action: com.adobe.ia.action.StartServersAction
Status: SUCCESSFUL
Starting Windows Service: ColdFusion 10 Jetty Service
Status: SUCCESSFUL
Starting Windows Service: ColdFusion 10 .NET Service
Status: SUCCESSFUL
Starting Windows Service: ColdFusion 10 ODBC Server
Status: SUCCESSFUL
Starting Windows Service: ColdFusion 10 ODBC Agent
Status: SUCCESSFUL
Also, let me just show you the message that comes up when I try to navigate to a ColdFusion application URL on my server: (btw, I find it somewhat funny since it's bad English... it should say "Service Temporarily Unavailable!")
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Jakarta/ISAPI/isapi_redirector/1.2.32 ()
I now feel that the Update 8 is defective.
I performed a full uninstallation of ColdFusion 10 from my computer. I then re-downloaded the 64-bit ColdFusion 10 file, installed it as Developer Edition and had no issues whatsoever. I launched into the CF Admin, finished auto-configuring the server, and at that point, everything worked fine (though I had 7 update warnings as I was at version 1)
I then downloaded the hotfix_008.jar file, copied it to my CF installation root/jre/bin, opened a command prompt, changed me working directory to the aforementioned and ran:
java -jar hotfix_008.jar
The installer came up and I went through the steps outlined in the process, successfully applying the update and being notified that my CF services are being restarted and to try them shortly.
Sure enough, the CF Application Server Service failed to start (with the same error) and navigating to the CF Admin resulted in the exact same error.
Thank God I tested this on my local machine before having it axe my 2 production servers!
Please check the pm sent to you.
Anit Kumar
I've responded via PM, thanks.
After doing many selective startups, I've found the following:
With ALL SERVICES DISABLED, then manually starting CF10 services, the application DOES load (though VERY slowly more than normal on first load)
We are running Symantec Endpoint Protection and I was on a client install (rather than server-pushed) of version 12.1.671.4971. I uninstalled that, restarted the computer and CF (update 8) was still working. Then, I had the server push down a copy of Symantec Endpoint Protection (v12.1.2015.2015) and restarted.
Upon boot, I tried CF again and everything seems to work.
I have been looking all over Symantec's website but cannot seem to confirm/deny whether version 12.1.671.4971 is compliant with JRE 1.6 (since Update 8 upgrades you to JRE 1.7). This MIGHT be the reason why.
Thank you for the update. Please repost, if you face any issue further.
Anit Kumar
